Question about Saeco Magic De Luxe Espresso Machine
Saeco magic del uxe brew unit problem
I have an old saeco magic de luxe espresso machine. the central unit led is flashing (not light continuous). i tried to reposition it but doesn't work. need some help
Brew unit warning light keeps flashing even when brew unit is properly engaged
Hi
Try pushing on the upper left side of the brew unit when its installed. If you hear a click, it should have cleared the light. If so you need to lubricate the outlet pipe on the brew unit. It is dragging on the brew unit when you are trying to install it. This will allow it to seat correctly. Use a food grade lube like what came with your Saeco.
Nov 18, 2010 | Saeco Magic De Luxe Espresso Machine
The central unit LED blinks green and the machine does not turn on
Hi
The LED should be blinking red not green on a magic delux. The only green light is the boiler light for warming up or ready. If its the brew unit light it means its missing.
Open the door on the right. The brew unit is the thing with the handle that has the “press” on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Apr 09, 2010 | Saeco Magic De Luxe Espresso Machine
Steady Brew Group Light: Old Saeco Magic deluxe
Open the door on the right. The brew unit is the thing with the handle that has the push on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Dec 08, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Delexe water light flashing
The brew unit is blocked, check the shower screen under the red o-ring.
Dec 03, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic de luxe not grinding beans
Try setting the grind to the coarsest setting, if you still have the same problem, check the wire connections to the board, it might have been reversed.
May 05, 2009 | Saeco Magic De Luxe Espresso Machine
Central unit does not connect due to misalignment with axel
You should be able to realign the central unit to the correct position using the T shaped key provided. Align the two arrows on the side of the brewer and reinstall
Dec 28, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Machine coffee grinds drawer overfills with water
Hi The thumb screw on the brew unit is stripped. If you remove the brew unit and you have water where the thumb screw is its stripped. you just need to remove the old one and replace it.
Oct 13, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe dregs light problem
Make sure that both the tray and dump box are placed correctly- otherwise the machine will not start. Both have a switch and when that switches are not engaged, the machine will not turn on.
Mar 09, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic deLuxe Central Unit Light is steadily on...
Central unit should almost "snap" into place, gotta push hard, maybe not all the way in.
Dec 29, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
29 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
