Noise from fan in modem - Computers & Internet
    Sergeant:
  • 206 Answers
Hi'
Normally dust gets caught up in the fan you can try blowing it out to free the dust or the bearings are getting worn and the fan needs to be replaced.
You can by silent fans for desk top pcs as well.
cheers
Posted on Nov 27, 2012
Testimonial: "Thanks for your quick response Aries. I have been cleaning the fans as regular maintenance. I can't replace the fan because of the age of the computer. On the phone for two hours w/HP before they gave me that little tidbit of info. I called my technician to see what he may suggest. He built the tower to my specifications in 2008. Other than this fan issue the computer is fine."
  • 1 more comment
  • Aries Nov 27, 2012
    Hi its so true fans can drive you crazy, ive had a few early model desk tops that bring back some memories lol, if your pc is built in an original hp case you will only need to change the case and motherboard everything else you can swap over then you can put any fan in you want and upgrade the cpu ram hard drive video card etc. cheers
  • Jayne R Chandler Nov 29, 2012
    Final Solution: I took the fan out of the case and lightly sprayed the bearings with WD40. Worked like a charm.
  • Aries Nov 29, 2012
    Hi i like it, i have to remember that one cheers
Starcom modem sip has noise on the line
Line noise comes from several conditions such as a bad cable connection, a bad in/out port, a bad power transformer, communication line failure, etc. Check all conditions and if none of the suggested are defective, the modem has a defect and needs attention.
Jan 20, 2014 | 2wire StarComm 1442E-003-2 Stand alone,...
My dell pc fan make a loud noice
There are 13 possible noise on hardware issues
1) Power supply crackling sound
2) Fan sound that sounds like a motor noise dragging
3) Harddisk clicking sound
4) CD rom spinning sound
5) Modem noise pinging sound
6) Application software resident in memory
7) Technician Neighbour drilling holes from your ceiling to do
special wirings late at night, installing transformers
8) Ceiling fan with unstable modified electricity makes noise
on motor issue
9) Sound that comes from switchboxes and transformer
upstairs lighting up free electricity from your fan wires
in your apartment unknown to you tapped by upstairs
residents
10) Voltage regulator malfunction noise issue
11) Monitor crackling sound issue
12) Wirings crackling sound issues
13) Power socket crackling sound issues
Be sure you know where the source comes from, call PC vendor if you are uncertain, you will have to dismantle your
hardware device in vendor's place to find out. Vendor will test one by one.
If computer fan is your issue, it is just a small issue
there are many replacement at PC vendors based on quality
corresponding to the price you pay
Nov 01, 2012 | Computers & Internet
ATT dsl netgear n150 when using computer can not use the phone.
Try to turn the modem off, if the noise on the line disapears when the modem its off you need to contact you service provider in the INTERNET deparment regarding the noise on your line.
If you turn the modem off and the noise on the line is still there, you need to contact the PHONE deparment, they will send you a technician for free to resolve your problem, it's a problem with the line. ;)
Apr 24, 2010 | Computers & Internet
I think I have noise issue on my cable line, so my new Motorola modem does not connect. I have the Motorola SB6120 SURFboard DOCSIS 3.0 eXtreme Broadband Cable Modem Can I add a noise filter inline to get...
Has your cable provider "provisioned" the new modem. Some cable providers require you to call them and let them know you have a new modem. The cable provider then registers the modem's MAC address with its servers so that it is seen as a legitimate connection (this is done to prevent someone tapping into your cable to get free interenet).
If your modem has been provisioned, then try disconnecting all other connections to the cable service to see if the noise problem goes away ( you can log into your modem 192.168.100.1 and look at the signal, the critical item you're looking at is the signal to noise ratio - it should be above 30). Add back the connections one at a time to see what it changing the SNR. Also, if you have a lot of splitters or even have an amplifier in line with your cable and the modem, this could be causing problems if it is not the type that allows return signals or is not in the proper frequency range. A noise filter will not fix these problems, the noise source itself must be eliminated.
Feb 01, 2010 | Computers & Internet
The fan in modem makes loud noises at times
Modems don't have fans.
I think you mean your fan in the computer makes a loud noise. Some computers have settings where the fan speeds up if you are doing a lot of things--making the computer work harder.
Some fans make noise just before they fail. Depends on the type of noise. If it's a sound that has a lot of rattling in it or maybe a high screeching sound, I'm thinking you'll be needing a new fan. Probably a CPU fan is the culprit. Also, fans on video cards often go bad--so you'll have to open the case and listen to where the sound comes from.
Oct 25, 2009 | Dell Dimension 8400 Desktop P4 630 3G 1GB...
Fans work but pc wont power up
refix ram and reattch all connection to mother bord.
ASlo remove cmos cell for 15 minutes from mother bord
also check smps is working fine
Apr 21, 2009 | E-Machines eMachines Desktop PC
3750 send snmp Fan problem
open up the covers at it may be a fan that is not visible or the rpm of the fan is not enough. Change the fan
Mar 04, 2009 | Cisco (VWIC-2MFT-E1) Modem
Compaq Presario SR1750NX
bad psp power supply cheak that add new one or maby ad dnew video card also could be going bad on u is it pushe dit all the way in pci slot also nicely also add alot fans if u can anyware u can open for a fan tohelp you heat issue
Jan 06, 2008 | Compaq Presario SR1050NX (DW257A) PC...
Computers & Internet Logo
David Payne
David Payne
