Question about Toshiba Satellite L455D-S5976 Notebook
My disk drive burns slow - Toshiba Satellite L455D-S5976 Notebook
  • Toshiba Master
  • 7,627 Answers
Well that depends on the computers specs,DVD drive specs, or the media being burned. It burns , right?
Posted on Nov 27, 2012
HOW CAN I TOTALLY FORMAT MY HARD DRIVE WHEN MY TOSHIBA SATELLITE WONT LOAD OPERATING SYSTEM?
All HD manufactures provide disk uility disks Find what type of hard drive you have and go to their web site download the disk and run it this should include a format uility For a sucure format download AUTOCLAVE burn it to disk and run it this one is slow but will put the hard drive back to a preformatted state
Mar 29, 2013 | Toshiba Satellite Computers & Internet
It is running very slow . It can't read a little bit old cd\ dvd. When a cd/dvd is inserted system has encounted a problem amd hang up for several minutes .............. and it can't burn disc...
This sounds like a simple problem to fix. You need to get a cd/dvd cleaner disk and place it in the drive. Allow the disk to perform as indicated by the audio instructions included on the disk. All modern lens cleaning disks have the audio instructions that play as the disk is in the machine, so that the customer knows what to do, and in what order to do it in.
After running the disk, get a NEW blank cd, and try to burn some files onto it. If it works right, then that was all that was wrong, if not, then you have corrupted firmware, which is also a relatively easy procedure to fix. Just go to the drive manufacturers website and download the latest firmware fore your drive.
Jan 22, 2011 | Office Equipment & Supplies
I have Seagate 200GB HDD "ST3200820AS ATA" I have very slow data transfer now a days.I use licensed antivirus scanned my all drves cleaned few spyware's now everything is clean but still slows.I have tried...
only a low level format can fix the issue...
save all data from this drive to a new drive,
use an application called KILLDISK
download from my shared drive...
the application that u will downlaod is a auto boot and dos utility...use any burning software to burn a CD using the "ISO-burner" in the downloaded file.....
u need to boot the PC using this disk in the CD drive, so change the boot seq in bios to CD as 1st boot drive
use a new empty CD to make this system disk, read the "Read me first file there" and then wipe ur disk clean with the DOS utility of KILLDISK
this will make ut disk as good as new...
Sep 26, 2010 | Seagate Barracuda 7200.8 200 GB Hard Drive
My dvdr/rw wont burn dvds properly
There are many reason for this.Try following steps to look out for solution.
1>Use better quality Dvd to burn .DVDs are just a few cents worth of plastic, manufactured in massive quantities. Sometimes you end up with a bad disk or a bad batch. Try a new disk, or a whole new brand, and you may have more luck burning your DVDs
2>Dust in your DVD burner can prevent it from burning DVDs correctly. Buy a lens cleaning disk and use it in your DVD burner drive. This can clean things up and give you a clean, successful burn.
3>For better quality burn at slow speed.It’s always tempting to burn DVDs at the highest speed possible. In theory, you’ll save time and can get more DVDs burned. In practice, though, higher speeds can result in unreliable burns.
Slow things down and set your DVDs to burn at 4x or even 2x. This may eliminate errors.
I hope this will solve your problem.
Mar 22, 2010 | Computers & Internet
My computer is slow and the is not reading or burning CD/DVD
Slow computer problem would be different then that non reading disks. Slow computer could happen in many cases, a virus is taking up all the memory, or defragmented hard disk, programs that required more memory and cpu speed. CD, DVD could fail to read due to loose cable, BIOS setup or damaged drive.
Sep 16, 2009 | HP Pavilion a800n (PP163AA) PC Desktop
An unknown error interupts the burning of my cd.
try slowing the speed of the drive, before u burn does it ask what speed? change it from maximum to say 25. see if this helps, if not try to update driver for ur cd drive
Jun 01, 2009 | Computers & Internet
Disc Drive issue.
very likely it is a memory issue... try to close down as many programs as you can while you are burning a disk... if possible you may want to upgrade the amount of memory you have
Robert
Please take a moment to rate this solution thanks
Feb 01, 2009 | Dell Dimension 8400 PC Desktop
Burning errors
Try different media. I find DVD burners to be very finicky about the DVDs it will accept. Try 3 or 4 different brands until you find one that doesn't error out, and stick with it.
Jan 03, 2009 | Ulead DVD Workshop 2 for PC
Write delay slows computer and then stops
Please find the name of the hard disk drive, found on the white label on the hard drive. Ex: Seagate, Western Digital, Samsung ECT. Got to their web site & download their tools or drive setup utilities & create a bootable floppy disk or bootable CD disk.
Their dos like software will test & repair most hard disk problems. Back up you're personal data, picture, and address book ECT. & burn to CD before running software.
If it finds problems it will erase you're data to repair the drive. You'll find other settings you can turn on or off that may increase the drive speed. The slowness is all about the hard drive & not you're system. If you're lucky all you'll have to do is a fresh install of windows.
Good Luck!
Mike
Jun 18, 2008 | ASUS P5GD1 Motherboard
Toshiba Satellite L455D-S5976 Notebook Logo
19 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
