SOURCE: flashing 3 times orange then green?
4 step to Reset waste counter CANON PIXMA iP 1500
STEP 1:- Disconnect printer from AC power(unplug it from all source of power supply leave it for 5min then back after))
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
SOURCE: The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before
resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
SOURCE: Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
SOURCE: light kee flashing orange/green and says computer
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
SOURCE: flashing orange light 5 times followed by green
I am also having this problem, would love someone to give us a solution before I through it out the window.....
