Question about Epson Perfection 4490 Film / Flatbed Scanner
Epson scanner film lamp failure
There is only a very faint light fron one end of the lid carriage when slides are scanned.
5 Suggested Answers
  • 110 Answers
SOURCE: Epson perfection 4990 photo scanner
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Posted on Aug 22, 2008
SOURCE: Epson 4490: where'd my "film" option go?
I had this problem, turned out the cable between the lid and the main chassis of the scanner had pulled out slightly. Plug it in and problem solved.
Posted on Jun 02, 2009
mohanchennai
  • 490 Answers
SOURCE: I have vertical lines in my photos when i scan them
If the lines are in the same location for all scanned outputs, it is clearly dust on the scanner glass. Clean it thoroughly.
S. Mohan, India
Posted on Jul 09, 2009
SOURCE: Epson V500 scanner will not scan film
You're problem is Vista, not the v500!
Posted on Jan 01, 2010
I need an all in one printer that also has a negative scan facility. Any suggestions, I have 2000 slides to scan .
Do you want a recomendation?do you want new or used? Typically all in one users don't scan slides or film, but flat prints, so they don't have the lighted back lid needed to scan film.I know that the Epson Stylus PHOTO RX-620 & 700 had a holder for 4 slides or 1 strip of film about 8 inches long
Sep 01, 2012 | Epson Office Equipment & Supplies
Scanning in Epson 4180 perfection - trying to scan slide in home mode - positive film - when it scans the slide in its holder it scans the holder & the slide. What do I need to change?
Make sure the white document matt has been removed from underneath the lid. Then make sure that the document type has been changed from reflective to Film etc. If film is greyed out then check the cable is connected properly from the lid to the base of the scanner.
Jan 21, 2010 | Epson Office Equipment & Supplies
Scanning slides produces black images. Slide
Make sure the white document matt from uner the lid has been removed. Also in Epson scan make sure you have changed the document type from reflective to Film and Colour positive.
Jul 03, 2009 | Epson Perfection V350 Flatbed Scanner
EPSON Perfection 4490 - Ireflective media scans, film doesn't
There are two lamps with this model. One in the base for reflective and one in the lid for negatives and slides. If the base one is going out then it will be trying to use the one in the lid. You must remove the white document mat from underneath the lid to expose this lamp so it can scan your negatives.
Jul 01, 2009 | Epson Perfection 4490 Office Flatbed...
How do I make photos from slides
Scanning slides is a tricky thing, because the light comes from the wrong side. What you would need is a flatbed TMA (Transparent Media Adapter, sometimes called a film adapter).
This is basically a lamp in the lid (or a replacement lid) of a scanner, to allow it to scan film. The film is placed on the scanner glass bed, but instead of being illuminated by reflected light from below like a print, this lamp shines down through, from behind the film. Then everything else pretty much works the same, we scan film using the same basics as for prints.(source)
You can give it a shot at a high resolution (1200dpi+) and see if that gets acceptable results.
I personally was never satisfied with my scanner, so I just went to a photo shop and let them do it for me.
Dec 30, 2008 | HP Photosmart C4580 All-in-One InkJet...
4990 scanner
Nothing is wrong if your scan turns out good
Jan 22, 2008 | Epson Perfection 4990 Flatbed Scanner
Cannot scan film and slides
Check the cable that connects to the lid of the scanner. If it is disconnected, you won't get the Film options.
Jan 21, 2008 | Canon CanoScan 8600F Flatbed Scanner
Scanner wont scan transparencies properly
I have the same problem with my 4990. This began when I moved to a new computer running Vista. I've updated all drivers to the latest version including Epson Scan for Vista but the only thing the 4990 "sees" is reflective documents. Negatives are not recognized at all. I know this is probably a different problem from what you are having but the effect is the same.
Apr 27, 2007 | Epson Perfection 4990 Flatbed Scanner
Epson Perfection 4490 Film / Flatbed Scanner Logo
41 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
