How do I remove door switch on washer model wtw4800xq
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Take a look at this video.
Posted on Nov 28, 2012
Wirlpool wtw4800xq washer frequent out of balance
Check the spring rods on each corner make sure not broken or came off pull basket make sure nothing in between silly question is it level also check the balance ring to make sure it is not loose
Feb 17, 2015 | Whirlpool WTW4800XQ Top Load Washer...
Model WTW4800XQ Whirlpool top load washer will not fill. Only hums when on button is pushed. what is the problem?
Does it do it on hot and cold water. Check the water filters where the hose screws on to the washer.
Oct 06, 2014 | Whirlpool WTW4800XQ Top Load Washer...
Whirlpool WTW4800XQ Washer The drum has sunk way down . It is only a year and a half old is there a way to fix it myself?
take the back off of washer and see what broke or came loose. then u will know if its something u can fix
Apr 06, 2014 | Whirlpool WTW4800XQ Washer
Changed lid lock switch and won't work
Is the plunger attached to the lid? It is the little prong that goes into the lid switch.
Apr 05, 2014 | Whirlpool WTW4800XQ Washer
Wtw4800xq1 lid lock bypass
You can bypass for trial by shorting the switch but this being a safety feature it is important to get the switch replaced.
Feb 12, 2013 | Whirlpool WTW4800XQ Washer
Whirlpool Model #: WTW4800XQ making a loud grinding noise during or at end of spin cycle. Help!
I have a similar model (WTW4850XQ1) that was making a very loud grinding/screeching noise during the agitation and sometimes the spin cycle. I unplugged and turned it on its front to get underneath and exposed the motor/transmission unit. Took the cover off the belt drive assembly and my drive gear was loose. Simple tightening down of the nut was an easy fix for me. But some times those plastic gears between the drive pulley assembly and transmission crack or the teeth wear down (think it's called the CAM). That is a fairly cheap and easy fix as well ($35). Repair Clinic website has free videos on how to diagnose and fix issues and parts as well. Worth a look.
Jan 08, 2013 | Whirlpool WTW4800XQ Washer
Whirlpool wtw4800xq.....locking mech...how do you replace this switch? Can't figure out how to raise top panel so i can reach it. are there clips holding, or screws?
Hello Bobbie,
Place a putty knife in the small gap between the top and the top of the cabinet at the left&right end and depress the clip that attaches the top to the cabinet they will pop up about a inch once both sides and free pivot the top back (dont worry its hinged in the back and wont fall off)
Gene
Aug 05, 2011 | Whirlpool WTW4800XQ Washer
Brand new Whirlpool WTW4800XQ out of box . Set up plugged in , loaded load pushed start lid locked hummed lid lock started flashing. waited till lid lock went off Still nothing
Before you attempt to do anything please check if the drum lock is removed, check the power plug, connect the water line inlet. and finally check the settings of the program.
Read through the manual and DO NOT ATTEMPT TO DO ANY REPAIR AS BEING A NEW SET you have warranty.
Call your dealer if the set hums even after the initial checks were done.
Aug 04, 2011 | Whirlpool WTW4800XQ Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
