Question about Ovens
Can the oven door catch be adjusted on the HOTPOINT HUD 61 COOKER
5 Suggested Answers
  • 174 Answers
SOURCE: Hi. Just need to know
Hi there is no adjustment. to fix it you will need to change both hinges on the door. Some models have a roller which may need changing (on the oven frame where the hinges are located)if the door is creaking when opened or closed. wherever you go for parts you wil need the model and product no from the oven located around the door area.
Posted on Jan 20, 2011
SOURCE: my oven door does not close tight
These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
Then reassemble.
My door now feels like a new one even though it is 15 years old.
Posted on Feb 04, 2011
barkencoa
  • 3463 Answers
SOURCE: Hotpoint ew81n cooker. Non working
Hi.
Unfortunately, the oven thermostat is non adjustable.
However, it is normal for oven temperatures to vary by + or - 10% of the setting.
This is acceptable, so to compensate, set the temp 10% less of the required temp setting.
Make sure you have the sensor fitted correctly inside the oven compartment
Make sure that the thermometer is accurate if you are checking the temperature with one.
Posted on Feb 23, 2011
SOURCE: oven door lock pin broke
how did you fix it?? i have the same problem!! :(
Posted on Feb 24, 2011
My Hotpoint SY36 oven has started making a clicking noise behind the control panel. The temperature light does not come on although the oven does heat up still.
If you have a problem with your hotpoint cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Dec 11, 2014 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint ew81n cooker. Non working oven thermostat has been replaced. The cooker temperature is hotter than the dial reading. What can I adjust to make them the same?
Hi.
Feb 23, 2011 | Hotpoint Ovens
The main fan assisted oven on a Hotpoint BD35 double oven stopped working so I replaced the element, thinking that would be the obvious answer. Unfortunately it is still not working and I notice that the...
Is there a black pole sticking out that goes in when you close the door, my Hotpoint freestanding cooker has it on the right hand side, once this is pressed in the fan and heat starts, i had to replace it on my cooker as it went faulty and stopped things working (all I had was the main oven light on, these are usually like a little black box that are situated on the side of the oven just behind the main metal panel on the outside and will normally have 2 pull off spade connectors connected to it.
i don't have the same model as you but hopefully this mig help you.
Oct 22, 2017 | Hotpoint DY46 Style Line Stainless Steel...
Door came off the hinge
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 04, 2010 | Whirlpool RBS305PDS Electric Single Oven
Locked oven door to clean. Need instructions to
These might help you get the door off
Mar 04, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Can I get replacement door for my top oven, and new door seals for Creda Cachet Solarplus Model 48182, serial 60.1.00082
we should be able to help if you contact the office
Mar 04, 2010 | Ovens
My oven door won't open and its not locked or on clean. what do i do
Mar 03, 2010 | Ovens
Unable to get cooker out of automatic mode
If your oven has timer and it is flashing AUTO then you need to reset it to manual for it to work.
If no timer then it could be a faulty door micro switch, located at the front left side..\Hope this helps, please leave feed back.
Thanks
Nov 25, 2008 | Hotpoint Ovens
Ovens Logo
162 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
