SOURCE: Oven will not heat
Hello, your problem is going to be a bad igniter. you should replace it. Good luck! Mike
SOURCE: Maytag Gemini Electric stove fault code F 1-2 when using the oven(s)
The oven temp sensor has gone bad. F1-2 would be for the lower oven and F1-1 would mean the upper oven. If you give me the model # from the sticker on the oven I can direct you to a diagram, part #, and price. These are very easy to replace. Should be located inside the oven in the upper right or left hand side. It looks like a silver rod about 4-8 inches long and crimped on the end. Most of them can be removed from inside the oven by removing the two screws, pull out the sensor (harness and all) plug in the new sensor, put the screws back in and your done. Some have to be removed from the back of the oven by removing the lower, larger back panel and follow the same process as mentioned above. Hope this helps.
SOURCE: Maytag Gemini MER6772 keypad/ovens not working
I had same problem, error code F 1-8, shorted keypad. I was so frustrated I went ahead and tore it apart. There was a surprising amount of gunk and moisture between the plastic face and the actual contacts. I cleaned it up and let it dry out. It worked OK for a while, but the seal is not good, and moisture from baking is still getting into it. When it goes bad again, I'm going to take off the plastic face and just press the sensors with a pencil eraser. I'll probably replace the range within the year. No way I'm paying $385 for new pad + installation on 10 year old stove.
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
