Question about Miele M625EG Convection Microwave Oven
How can i remove control panel from a MIELE MICROWAVE M625EG
The buttons of START and STOP on the control panel are pushed back(i think the hole control panel is pushed back) so i would like to open the box of the oven and push it back to its first position
3 Suggested Answers
SOURCE: Buttons work hardly on my Miele M625EG
I have the same problem with my M625EG-ed from about the same period. My repairman said that it would be at least 300 € for a new unit. I opened it myself and cleaned the keypad with alcohol or aceton. It's not working perfect afterwards but it is better.
There's a fuse you have to take out when opening. Otherwise you can have problems with electricity (be carefull). The fuse I had, broke down and I had to buy a new one for 20 eurocents. Also watch out with the parts where the door closes. I had some problems with that too and now (after a few months), I had to buy a new connector part on the door (its the part of the door that closes the door and gives connection for the lights). This costed 12-13 € but I'm trying to install it now.
Andy Mahieu, Jabbeke Belgium
Posted on Oct 14, 2008
  • 52 Answers
SOURCE: sparking roof of my miele M613G microwave
these ovens are favourite for this, it is something to do with the stirrer blades. the top casing can be removed and replaced
Posted on Feb 23, 2009
What do i do?m625 eg miele oven smoke from top and turntable ceased working
Impossible to say what the problem is but if the turntable has stopped you could check the turntable motor. This is easily accessed from the bottom of the unit but you have to actually break the sheet metal tabs that retain it in place and replace using the screws only.
May 14, 2014 | Miele M625EG Convection Microwave Oven
How to remove frame ER 629 from Miele 626 EG
First, I'm not a Miele tech. But I have worked on commercial espresso equipment and table top units.
*** The following is for information only ***
* I found this link that may help. Note that many of these table units require special tools to access. If your trying to access a panel with these special screws then removing them will probably void your warranty. Call your vendor or MFR for service.
* follow the link for more information.
Aloha, ukeboy57
https://www.bing.com/videos/search?q=miele+espresso+machine+repair&&view=detail&mid=CCE1F05D2886FF9F3826CCE1F05D2886FF9F3826&&FORM=VRDGAR
Apr 28, 2014 | Miele M625EG Convection Microwave Oven
Miele M625 lightbulb replacement
If the owner's manual doesn't cover it and there's no obvious cover on the side or rear, you'll have to remove the outer wrapper.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
Often on a unit whose bulb is not meant to be replaced by the customer, the light is located on the right side in the air duct attached to the magnetron or on the top of the oven cavity.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Dec 11, 2012 | Miele M625EG Convection Microwave Oven
Turntable not rotating on my microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for about 5 minutes. You can download your owner's manual here: http://www.miele.co.uk/Resources/OperatingInstructions/M%20625%20EG.pdf On the last page it has the contact information for various countries. You can locate servicers or spare parts. The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray. You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58 If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Jun 11, 2009 | Miele M625EG Convection Microwave Oven
Start button intermittent eg press many times (maybe 20) to start
Problem identified as plastic pushbutton on control panel, solution: interchanged with turntable on/off button (nevrer used). Had paid Miele €115 call out (for person who knew nothing about microwaves), Miele operate a closed shop. Local repair service say Miele will not supply parts, Miele designated repair agent will not repair microwaves, Miele will only send "engineer" to customer, no drop off facility. Was forced into buying new microwave oven from Miele as only way of recouping callout charge. Subsequently had a go myself with above positive positive result - now have a spare microwave cooker.
Mar 18, 2009 | Miele M625EG Convection Microwave Oven
Aug 26, 2008 | Miele M625EG Convection Microwave Oven
Miele M625EG Convection Microwave Oven Logo
94 people viewed this question
Top Miele Microwave Ovens Experts
William Miller
William Miller
Naveen Sistla
Naveen Sistla
Level 1 Expert
Are you a Miele Microwave Oven Expert? Answer questions, earn points and help others
