Question about GE Spectra JBP78 Electric Kitchen Range
Unable to remove oven door
Trying to replace front glass
    Top Expert:
  • GE Master
  • 9,472 Answers
Look at this video.
Posted on Nov 28, 2012
4 Suggested Answers
SOURCE: how do I replace the shattered glass in my GE oven door
No doubt this is a double paned glass panel. Two panes of glass with a divider strip separating the two for a "thermal break". Okay, you will need to remove the door from the hinges, and along the sides of the door, or possibly under the door gasket, you will find multiple screws that hold the two sandwiched halves of the door together. There should be a front panel, formed sheet steel, and an inner formed sheet steel panel which is coated with porcelin. When you have the front and back halves of the door separated, inside of one or maybe both of the panels you will find the clips, screws, or materials that hold this glass panel in place. Possibly it is in it's own frame, and the frame and glass both remove as one unit. Then it will be a matter of contacting Customer Service and Parts for your product, giving the Model #, Serial # and any other data that may be needed in order to replace the part with the correct one. Since this should be tempered glass, it will be quite heavy and at least 1/4" thick or so. The "thermal break" or space between the panes is so that heat does not transfer readily to the outside panel. Watch for any electrical connections for a door switch for the oven lamp, and be careful when removing the springs which allow the door to close and seal when in the closed position. And it might be helpful to take some photos of the disassembly process so that you can have a reference when you are ready to re-install the door. Be careful when removing the broken glass, and dispose of this carefully. Take your time, be patient, and don't force any thing, and you should be fine. Good lock. Kindest regards, Slats.
Posted on Sep 26, 2009
  • 206 Answers
SOURCE: Replacing outer glass of oven door
This is glass because glass does not burn, does not melt at oven temperatures, and is a pretty good insulator. Also allows the cook to watch the cake rise.
I would not replace with anything but factor glass. Too dangerous, even regular glass is not properly treated to be safe in this environment.
The cash for clunkers gets extended to appliances soon, perhaps this makes a new one more affordable?
Posted on Aug 24, 2009
  • 80 Answers
SOURCE: how do I repace the glass on the front of oven door
Click on this to view the diagram.
Put a thick towel on the counter (or table). Remove the door from its hinges and set it on the towel. Be careful not to damage anything, especially glass and door handle. Remove the door handle (#10 screws). Remove the bottom screws that hold #4 outer panel to #9 inner door panel. You can then set the outer panel aside. Collect broken glass pieces if any and install the new glass. Set the outer panel back on, and repeat the other steps in reverse.
That's about it.
Let us know how it goes...
Thanks
Posted on Apr 02, 2012
How do we replace the shattered inner glass of the oven?
Anne,
Most oven will have a series of screws that hold the door halves together and you would need remove those so that you can gain access to the glass panel. Some doors only have two screws that also hold the door handle on and you would have to remove just those to gain the access you need. Hope this helps!
Aug 11, 2015 | Combi Ovens
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
Ariston oven window pane out
Take a look at http://ovendoorglue.co.uk/fix-oven-door-glass/ whish should help explain how to remove the oven door, take off the fascia and glue the inner glass.
Oct 28, 2012 | Ovens
How do i remove and replace the internal glass of the oven door for cleaning?
Most ovens have screws around the oven door. Remove them and the front will come offa. Be careful you don't bend any ears or catches.
After the front is off you will see a keeper that holds the glass in place. Re that and take the glass out.
Make sure you watch the way it comes apart.
Nov 17, 2011 | Ovens
Cleaner has gotten behind the front glass, how can i remove the front glass? thankyou
Here is a tip that I wrote about the oven door glass replacement...
You can use it for getting to the glass also...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Dec 10, 2010 | Ovens
I need to replace the outer glass on my Advantium oven
contact GE; they should have replacement glass in stock.
Apr 28, 2008 | GE ZSC2001FSS Advantium Electric Single...
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Top oven front glass broken want replacement
WHERE CAN WE BUY REPLACEMENT GLASS FOR AN OVEN
Dec 10, 2007 | Zanussi ZHQ575 Electric Double Oven
Jenn air double ovens
First, with the door closed, find the screws at the bottom of the door and remove. With an assistant, open the door and remove any side and inside screws you find. The door will separate into two halves. Be aware that most glass is not clipped in...they can fall and break. Remove the front panel from the door...the door may try to slam shut. To clean the glass, use a blue cleaner and a scrubby or very fine steel wool rubbing gently. Scratches are not allowed! Take pictures of what you're doing so you can replace. Be careful of brittle door insulation.
Oct 30, 2007 | Jenn-Air JJW8230D Electric Double Oven
GE Spectra JBP78 Electric Kitchen Range Logo
305 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
