Question about Delta 28 276 14" Band Saw W/ 3/4 Hp Motor & Open Stand
Delta 28-160 band saw 3 wheel, blade keeps coming off
I have a 28-160 Delta band saw with 3 wheels Blade fits ok I presume and have it faily tight. When I turn it though the blade falls off.
Sounds like your tracking screw needs adjustment, located right beside the knob used for tightening after adjusting the tension on the blade. Allen wrench required. Turning right pushes out and turning left pulls it in. A little is a lot when adjusting this screw. Always turn the blade in the same direction as the cut while adjusting.
Posted on Nov 28, 2012
  • 1 more comment
  • John Weber
    John Weber Mar 03, 2014
    I have a similar problem. The only way I can keep the blade on is to tighten that adjustment screw where it rides on the back edge of the upper right and lower right wheel.
  • John Weber
    The lower left wheel seems to ride toward the front of the wheel, so I added a washer behind it. I don't like that solution as the manual doesn't show a washer there originally. I even wondered if that lower left wheel should be reversed, but I can't tell by the manual or the parts list. I bought this on Craigslist and it worked great til the blade broke. I replaced the blade, then the rubber on the wheels, then the Left Handed screw on the lower left wheel. Should have just bought a new one I guess, but too far in to quit now.
  • John Weber
    Would love any more insight as to a solution to getting the blade to ride in the middle of all wheels.
4 Suggested Answers
  • 21 Answers
SOURCE: My 16" Delta band saw blade is drifting how can I fix it?
The blade guides are not intended to prevent your blade from drifting they are there to ensure proper blade path while cutting forces are being applied. There is a tracking adjustment for the upper wheel. Unplug the saw. Start with light blade tension. Turn the upper wheel by hand while adjusting the tracking knob. When the tracking is close set proper blade tension and check tracking again. You can make fine adjustments to tracking with the machine running.
Posted on Jan 13, 2009
agent91
  • 2100 Answers
SOURCE: I have a delta band saw model 28-185 that uses a
Was the blade custom made or did it come in a box? A lot of these guys cut and weld blades, you could have easily gotten one too big. Run a tape around it and see what it measures, If it is 56 1/8, something is wrong with one of your wheels. Grab a hold of your wheels and see if the bearings are shot. Check out the tightener, make sure it is moving up and down.
Posted on Feb 24, 2010
heatman101
  • 43501 Answers
SOURCE: I inherited a Delta model
I think you will find that you have a bad bearing in the wheel(s)....the first hint is when you look your tool up in a site like this and then on the right it has popular parts and the second one listed is the bearings...
Click here...
First thing I would do is pull the wheels off and check the bearings...
heatman101
Posted on Sep 14, 2011
Delta 28-160 3 wheel band saw and the blade slips off after 1-2 rotations of the wheel. I have replaced the tires with the blue tires.
one of the wheels will have an adjustment that aligns the wheel correctly
bands/belts always run to the highest point so one of the wheels is not true and presenting a high point causing the blade to run off
Sep 03, 2016 | Olson Cool Blocks 5008 Delta 28-180, 160 &...
What makes a delta 28-243F 14" band saw blade keep coming off?
The most common is wheel misaligment. The top wheel has an adjusting screw or the equivalent somewhere, and you can turn that to align the blade to the center of the wheels.
Second most common is guide problems. There are some guides that are supposed to hold the blade "just right" above and maybe below the table where you are cutting These must be set to support the blade in it's correct position as you are cutting through the material you are cutting.
3rd problem is a saw blade that has lost it's tension from being
" worn out ".
Be blessed.
May 20, 2014 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
The blade on my delta 28-276 keeps riding off the bottom tire
The blade on a band saw stays on the wheels because they are aligned in a way to keep it there. Several things can be wrong to make the alignment off enough that the blade won't stay on. Check the condition of the tire and that the wheel isn't bent. Then check that the bearings and lower drive shaft are not damaged. Another remote possibility is a bent frame that throws the alignment out of wack.
Oct 08, 2012 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
I have a 28-560 can not tighten blade, new blade 82 and new rubber on wheels blade rubbs against switchs
Then you either need a blade shorter than 82" or the blade that you think is 82" is actually longer than that. It is also possible that the new tires you put on are a little thinner than the ones you took off.
Aug 04, 2012 | Delta Urethane Tires For 28-560 3 Tire Set...
Tire comes off top wheel almost all the time. Tire comes off bottem wheel sometimes. Don't know how to set up this saw.
My jet bandsaw did same thing only fix was new tires .Tires are supposed to be tite on wheel .get wood dowels between tire and wheel and roll new tire onto wheel. If desperate could glue on with weather strip adhesive.put bandsaw blade on both tires spin wheels with power off till blade is running in center of wheel by adjusting top wheel in or out. When done adjust blade guides to blade and bearings to back of blade .This is top and bottom of cutting area
Jan 16, 2011 | Delta Woodworking Delta Rockwell 14 Inch...
How do you keep the blade on the wheel? Mine keeps coming off. It is a Rockwell product. The blade came off while I was using it and I can put it back on both wheels but as soon as I turn it on, the...
Sounds like it could be quite a few different things. My suggestion is to go to you tube and look at Band Saw setup. I haved viewed the one from the wood whisper and it covers set up in detail, there are also other videos that may help.
Sounds like a setup problem - wheels,tires,guides,and even blade tension can cause this.
Does the blade track true when turning top wheel by hand?(unplugged of course)
Is the blade tension correct?
Are the tires in good shape?
Are the guides and back up bearings set correctly?
I hope this will get you headed in the right direction.
Nov 14, 2010 | Delta Rockwelldelta 14" Hinged Wood Band...
28-276 Delta bandsaw blade keeps coming off?
Unplug the machine, gain access to the two wheels. On the back of the machine you should have a tilt adjustment knob. Manually turn the wheels in the direction of the cut and at the same turn adjust the tilt knob on the back of the machine. This should solve the problem.
Sep 27, 2010 | Delta 28 168 Bench Band Saw Blade 56 1/8...
I have a delta band saw model 28-185 that uses a 56 and 1/8 in blade. I bought a blade of thet size from vermont corp but it does not fit, it's too big. What's going on? Thank you. Larry Haynes
Feb 23, 2010 | Delta Saws
Band saw blades keep coming off the reels and
if it is a Delta (as it is listed) this site should help.
-->click here<--
please take the time to give this solution a fixya rating.
Any questions, just ask.
clarkco
Mar 31, 2009 | Delta 28 168 Bench Band Saw Blade 56 1/8...
Jan 07, 2009 | Delta Saws
Delta 28 276 14" Band Saw W/ 3/4 Hp Motor & Open Stand Logo
1,246 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
John Trevino
Are you a Delta Saw Expert? Answer questions, earn points and help others
