Question about X10 2.4ghz Wireless Color Video Camera Model Xc18a Home Security Indooor Outdoor
How to hook up my xc18a security camera's
I lost the software installation cd that came with my vivtar camera
if you have a usb cable that came with camera, put it in the camera & put the other end in the computer, turn the camera on, the computer should read the memory chip in the camera. or take the memory chip out the and put in in a card reader and hook it to the computer
Jun 24, 2013 | Vivitar Digital Camera V69379
Where can i find a user manual
Try doing a google search, going to manufacturer's website, or if offline, call a library for manufacturer contact information.
May 28, 2013 | X10 2.4ghz Wireless Color Video Camera...
How to download pictures from the vivitar
Hook your digital hd video camera up to your computer, & turn it on. If that dialog box doesn't appear, open Windows Explorer, and see if it shows up (it might show up as "Removable Drive"). If so, drag & drop the files from your camera to your HD.
Jan 10, 2012 | Vivitar ViviCam 25 Digital Camera
I purchased a DXG model 305v off Craigslist & it came with absolutely nothing. luckily i had a USB cord that fit in the camera but when i hook it up my computer doesn't do anything & my camera...
Copy and paste this address in your browser. It will take you to the pdf of the owner's manual that you can download to your computer. http://www.dxgusa.com/CustomerService/Manuals/DXG305VE.pdf
Sep 07, 2011 | DXG Technology DXG-305V Digital Camera
I have a Javelin home security monitor and cameras. The date on the back of the monitor says it was manufactured 1999, can I still get additional cameras for it? The Model # FAMYC1400C.
Not being a specialist in home security, here's what I would suggest:
Don't go by the monitor alone. Every monitor has a certain number of camera connections on it. If you have used all the connections, then that's where you stop. If you have a couple of extra connections available, look instead at the cameras themselves. Check the power & data wires and look for a camera with comparable connections. You may not be able to find the exact make/model of camera, but I'm sure you can find cameras that will work.
Aug 12, 2011 | Computers & Internet
I Hook Up My Camera To The Computer & Turn It On So I Can Import Photos To The CPU . When I Do This It Ask To Select USB Mode I Select " PC " & Nothing Happens ... Its Suppose To Showup...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Nov 25, 2010 | Panasonic DMC-ZS1 Digital Camera
Try NOT connecting your camera to your computer.
I am trying to hook up my camera polaroid i834 to my computer so i can see my pictures and file them. i have hooked up the usb cable but my epson printer workforce 610 says connection error. i have...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jul 09, 2010 | Polaroid i834 Digital Camera
X10 2.4ghz Wireless Color Video Camera Model Xc18a Home Security Indooor Outdoor Logo
779 people viewed this question
Top X10 Video Cameras Experts
Are you a X10 Video Camera Expert? Answer questions, earn points and help others
