Question about Microwave Ovens
Interior bulb out in microwave oven (built -in)
The unit is working. The interior light is not coming on. Would like to replace bulb.
  • Anonymous Mar 13, 2014
    How do you get to the bulb in the interior of a built in Electrolux Icon mucrowave to replace it ? Model ~ E30MH65GSS
  • Microwave Ovens Master
  • 9,047 Answers
It all depends on that all-important model number. So without that, we can only give a broad, generic answer.
The first step is to unplug the oven before changing bulbs!
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It's at http://031d26d.namesecurehost.com/mwd/ge_lamp_replacement.jpg
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph, except to unplug the oven.
See these links before proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs (or 20A ceramic fuses) can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Posted on Nov 28, 2012
  • 4 Answers
SOURCE: GE microwave interior light bulb replacement.
It's pretty simple as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Posted on Dec 26, 2007
MicrowaveSvc
  • 9047 Answers
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
There may be a panel on the bottom covering the light(s), too.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
THENTHEREWER
  • 131 Answers
SOURCE: How do I replace a lightbulb in my Kitchenaid microwave?
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
Posted on Nov 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: light bulb replacement for sanyo ems3553 microwave oven
If you don't have your instructions, please reply back with your brand and model number.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Posted on Mar 06, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: I need to replace light bulb in Whirlpool built in
It looks like it, but if you look at the diagrams, maybe not.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven
here.
You can download Whirlpool owner's manuals and installation instructions here.
Posted on Oct 02, 2010
Interior light bulb burned out
make this test and fix it. GOD BLESS YOU
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Oct 31, 2013 | Samsung SMH8165STE Microwave Oven
Tip
Change light bulb GE MOnogram Advantium Microwave oven
I have included a schematic of the interior of the built in Monogram Advantium Microwave oven Model KSC1001. The interior halogen light burned out and had to be replaced. GE service wanted $138 to come out & service it. I tried to find instructions on how to take it apart and remove the bulb & replace it on the WEB but had no luck with the Monogram series so I went to the dealer in Denver, CO and talked with their technicians and they gave me the schematic and sold me 2 bulbs for $11.00. The halogen bulbs can be purchased at Home Depot for about the same price. They are 35 watt with wide metal connectors.
Mine has 2 side trim pieces so these have to be removed first. They have latches on the top that slide behind the sides of the microwave and attach at the top. After removing the 4 screws holding the trim pieces, slide these upwards and then pull out to the sides. 2.) pull the microwave out and set it on a solid surface. 3.) there are approximately 23 screws that need to come out before you can slide & life the cover off the microwave 4.) Then look inside towards the front and left side (looking from the rear forward) for a small metal cover. There are 2 screws that hold it down. 5). Unscrew the 2 screws and gently lift the metal container up. This is the housing for the light bulb. 6.) gently pull the old bulb out and using gloves or a cloth insert the new bulb.You need to keep oils from your fingers from getting on the bulbs. The oils make the bulbs burn out quicker 7.) Put the container back and screw in the 2 screws being careful not to dislodge any wiring 8.) Slide the cover back on and replace all the screws 9.) plug it into an outlet and open the door to make sure the light works 10.) replace the microwave, plug it in and put the trim pieces back on. 11.) go to a movie with the money you just saved
on Feb 17, 2009 | GE Monogram ZE2160SF Convection /...
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
The light in my microwave went out. how do i replace the light bulb?
Some have a plate on the interior of the oven that can be removed for easy bulb replacement but if yours does not you will have to remove the entire outer covering to access the bulb. If you have a combination microwave/Range vent you will have to remove the entire unit from the cabinet, then remove the outer cover, replace the bulb and re-install the combination unit.
Dec 13, 2011 | Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
GE PEB1590 microwave oven. Interior light burned
Remove the screws from around the rear of the oven and slide the cabnet off to the rear. You should be able to access the bulb from here.
WARNING: any time you work on a microwave you have to be careful of the capacitor. Unpluge the microwave and discharge the capacitor with a large screwdriver with a plastic handle.
Be careful.
Dec 31, 2009 | General Electric PEB1590SMSS Stainless...
Kenmore micowave oven interior light
THe microwave has to be removed from the wall and then the outer cabinet has to be removed to get to the bulb. Do not do this with the unit plugged in and do not do this if u don't know how to work on a microwave as there is a shock hazard.
Jan 26, 2009 | Kenmore Microwave Ovens
Interior Microwave doesnt come on..Burned out?
If it doesn't have a door you have to remove the cover. Its likely a special microwave bulb and the socket will have to be replaced with the bulb. the bulb is built onto the socket.
Jan 14, 2009 | Sharp R-1514 Microwave Oven
Jun 03, 2008 | GE JES1289SK Microwave Oven
Replacing lightbulb in Sharp R953M combi microwave oven
most microwave ovens built in the last 20 years do not have an
access panel to the light bulb. you must remove the screws on the back of the microwave that hold the outer sleeve in place.
Then pull upward and backward on the sleeve to disengage it
from the front lip of the chassis. the light bulb should be close to the front of the microwave behind the control panel. Some lights
are not unscrewable from the socket, but the socket and bulb
come as an assembly.
Mar 26, 2008 | Microwave Ovens
Microwave Ovens Logo
97 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
