Question about ASUS P5LD2-VM Motherboard
Asus p5ld2 connect to front panel
I have asus motherboard p5ld2 and i want to connect the sound and mic exits to my front panel in the thermaltake soprano and i dont knoe what to connect and where on the mother board ?!
will be glad for some tips.
  • e_ohanna Jan 11, 2009
    that i know, i just dont know what to connect and to where there are several connectors that mark (on the fron panel) but its not the same as the mother boars tags..
    President:
  • 1,179 Answers
The front panel connections are on the same side as the SATA connections about halfway down the board on the edge. They should be labled in small print. Hope this helps & please remember to rate my answer. Thanks.
Posted on Jan 10, 2009
  • Roy Lonsinger
    Roy Lonsinger Jan 13, 2009
    Sound & mic should be on one plug. My asus board has both of these wired together from the front panel & plug into the hd sound on the mb.
Hello. When I plug my headphone with mic into the front panel jacks, it does not work. Now if I disconnect my speakers and plug it in the back jacks, it will work. However, the front joacks are there for...
Open up your case.
You should see cables running from the front panel to the motherboard. On the motherboard you will see a multi-pin connector. What is your exact ASUS motherboard model? Here's a generic ASUS one. You will see this on the motherboard where the front panel connects to the board. A bunch of pins will terminate here.
Notice the pin labelled MIC. You will see GND etched on the motherboard. Use this to orient yourself. The Mic one is just below the GND pin. Connect it here. Notice the entire top row is devoted to FP_Audio or Front panel Audio. There are other places to connect it (e.g., if you just want stereo sound, there's a left and right FP_R and FP_L).
Move the mic connector over to the Mic pin if there is one. If not, you can get a cable at your local computer supply shop. As you can tell from the others, they are very basic wires with simple terminals.
Sep 03, 2010 | ASUS Computers & Internet
Driver sound card ASUS P5LD2-VM Motherboard for windows 7 ?
u can find ur driver here:
http://support.asus.com/download/download.aspx?model=P5LD2-VM&SLanguage=en-us
select os vista remember version 32 or 64 bit,most probably vista drivers will work on windows7, and then download audio driver.
Mar 29, 2010 | ASUS P5LD2-VM Motherboard
My cpu dont see new hdd wd5000avvs ,motherboard Asus P5LD2 SE. i trying omost everything. help;/
are you using ide or sata connection? if your using sata conection between your motherboard and harddrive, you must enable it in your bios, just reboot your pc and keep pressing F2 while its booting to prompt your bios. There you can look for IDE/SATA configuration. After enabling your sata, save any changes before you exit and reboot... Just give it a try...
Jun 22, 2009 | ASUS P5LD2-VM Motherboard
Mic not working in Asus-KPLCM motherboard
This MIGHT be a driver related problem, but it could also be build problem. Are using the front panel outlets or the rear on-board outlets?
If its the front ones make sure they are going to the right sockets on the motherboard.. if its rear outlets from the motherboard then its definitely a driver issue.
However, check where the CD audio cable is going to on the M/B first.
Mar 19, 2009 | ASUS P5LD2-VM Motherboard
S/PDIF IS DISABLED
maybe the driver of your sound is corrupt of missing try to reinstall your driver of the sound card
Feb 12, 2009 | ASUS P5LD2-VM Motherboard
MOTHER BOARD DRIVERS
All drivers are available here but chose your OS & download
http://support.asus.com/download/download.aspx?modelname=P5LD2%20Deluxe&SLanguage=en-us............sodeep
Jul 01, 2008 | ASUS P5LD2 Deluxe Motherboard
Sound problem with asus p5ld2-vm series motherboard
Vista 64bit drivers: http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5LD2-VM/RealtekALC888_Audio_V6015384_Vista.zip
XP 64 bit drivers: http://dlsvr01.asus.com/pub/ASUS/misc/audio/RealtekALC888_Audio_V51005294.zip
Dec 14, 2007 | Intel D865GBF Motherboard
Front sound and mic pins
Hi, The motherboard connection points to the front panel audio jacks are shown in the diagram below. It was cropped from a page of the user's manual. A downloadable version of the English version of the User's manual is at http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5RD1-VM/e2440_p5rd1-vm.pdf Hope this be of help to you. Post back how things turned up or should you need additional information. Good luck and kind regards.
Oct 05, 2007 | ASUS P5RD1-VM Motherboard
ASUS P5LD2-VM Motherboard Logo
302 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
