Question about Huawei Sonic Plus U8661 Dual Sim 2 Line Number Android Mobile Phone Smartphone
Firmware failed unpaking is ok installing failed
  • 166 Answers
Are you installing a rom from .zip file?
I assume you are doing that.
To follow these steps, you will need ClockWorkMode and rooted stock rom. In recovery mode, load CWM, Clear dalvik cache and data partion and then install ROM .zip fike. Try to obtain new package of ROM files. The one you may have may have some internal configuration problems.
Now, if your phone doesn't load any OS, try flashing with ODIN with stock ROM packages. You can download it from xda-developers or by searchibg it in google.. Note, try to watch some demos from youtube before actually doing it. It will help you to know correct procedures.
Posted on Nov 28, 2012
How to solve the problem huawei C8812 firmware update fail ....
please tell me.. my gmail is " dvlike.nuclear@gmail.com "
thanks!/
Posted on Dec 26, 2012
I have a Panasonic TH-L42U30 LCD TV and the HDMI input seems to have failed. Do you know what might be causing this and what a solution could be. Thanks
Try by change the HDMI cable first. If the cable has any internal break, HDMI signal would fail. If it is found OK, the firmware should be checked. If firmware to HDMI hasn't installed, or it is corrupted, this kind of fault can occur. It will be best to contact any service technician. http://electronicshelponline.blogspot.com/
Sep 21, 2014 | Panasonic Televison & Video
HP 9250c digital sender is giving error login failed code 22 using common access card
Depending on what operating system your running. You need to make sure your product is plugged in through a usb connection. Now if your computer doesn't find the product that's ok you just need iticon1.pngto be plugged in. then you need to download the proper drivers for it. For instance if your running windows 7 64 bit, you need to download the drivers making sure you have 7 64bit drivers. In this case you want to install the firmware update make sure you see a yellow smiley face after the firmware is installed to your Digital Sender
[img src="http://i.fixya.net/uploads/images/1422807-h20565.png">Drivers Software Firmware for HP 9250c Digital Senderh20565.www2.hp.com
Jun 29, 2011 | HP 9250c Digital Sender (CB472AABA)
Hi , I tried to installed many drivers for my
Try upgrading the motherboard BIOS to the most current version. You can download the bios from the ASUS website. If you have not done so, also download the most current audio drivers from the same place. (I assume you have already done this but if not, you should).
Update the BIOS first. Then, install the most recent audio drivers.
Mar 06, 2010 | Computers & Internet
Firmware Update problem.(Failed) hi i have Creative Zen 4GB Mp3 player. When i plug it via USB on my PC i can't upgrade frimware.İt always run in recovery mode.i start firmware upgrade and...
When i plug it via USB on my PC i can't upgrade frimware.İt always run in recovery mode.i start firmware upgrade and installer says "firmware upgrade failed.".Media explorer says Storage Media is 50 mb.Please help i don't know anything to repair it...
Feb 21, 2010 | Creative Labs Zen Digital Media Player
Nuvi 265t: no sound or bluetooth after update
Your last upgrade fail.
Load V5.00, wich install the bluetooth driver.
http://www.garmin.com/software/nuvi2x5_regionfileonly__500.gcd
Load this one to your nuvi F:\GARMIN\ and rename to GUPDATE.GCD.
After disconnect your nuvi from PC and downgrade firmware test bluetooth and sound. Then retry to update (Manual as above __530, WebUpdater or Garmin-Website).
Good Luck
Jul 29, 2009 | Garmin nuvi 265 Car GPS Receiver
Lite on cd/rw/dvd rom (SOHC-5236V) fails to read dvd's
your dvd lense might be dusty OR laser might have became weak
try upgrading FIRMWARE
Jan 31, 2009 | Lite On SOHC-5236V CD-RW/DVD-ROM Combo...
Fs-3900 intermittently not printing
for FS-3900DN the latest firmware is the one what you have. BUT there is a separate update firmware for the Network Card !!
Check if you have installed the latest print driver in ALL computers and the OS updated with the latest patches.
Q1: The printing issue is consistent when you change computers ? IF yes THEN the issue is within the printer or the network.
Then:
Check if you have same issues when printing using the USB (not the network).
IF is printing OK when you use the USB but you got trouble using the network THEN something is wrong with the network printing so:
-> connect the printer straight to a PC/laptop using a crossover network cable that so you bypass the whole network (LAN) hardware.
--> IF is printing OK THEN the problem is within the network hardware(LAN) - you may try to pinpoint by replacing the network cable between the hub/router and the printer.
--> IF printing using the crossover cable is NOT OK then the problem is in the printer's network card. Check if the jack or the cable fit well into the printer or if the connector is not loose.
IF printing using USB is NOT OK then the problem may be into the printer. Reload the firmware engine and system + network card... it may help.
Q2: When you say: "fails to print unless it's powered OFF / ON" you mean the print job what you sent is waiting into the computer print spooler = the printer is being seen as NOT READY ? or the print job is just missing and you have to restart the printer and after that resend the print job ? ou can chack the printer stat by going to her IP address = open any internet browser and type the ip address. You should see a web page. Check the printer status before sending any print job.
Oct 27, 2008 | Kyocera FS-3900DN Laser Printer
Zen micro firmware problem
I just got a ZEN Micro 4GB player for free due to Firmware problem. This totally fixed the firmware issue. Windows XP PC with Media Player 10 and the latest driver and firmware from creative. Once I had all that I plugged in my player, let it recognize and then re-flashed to latest firmware. BAM now the play is working perfectly and I can sync music to it. Thanks for the fix.
Jun 25, 2008 | Creative Labs Zen Micro MP3 Player
Creative ZEN MICRO
OK to everyone who messed up the firmware of Zen Micro and run vista, u r all idiots, including me. my zen was stuck in recovery mode and recovery menu as everyone experienced and tried to upgrade the firmware via the firmware updater that didnt work, right? ok through research and time i came to realize that what was causing the updater to fail (...please connect your media player...) is windows media player 11 (ELEVEN !!) zen update firmware will work only with windows media player 10 (TEN !!) installed. y? i dont know and i dont care anymore now that my micro is fixed up and running with the latest released firmware.
method 1:
u can find smne with xp and wmp10 (rare) install drivers and run the updater or
method 2:
u can DIY and since it is impossible to uninstall wmp11 i did the unthinkable, no no not format and install xp to use wmp10 no no.
instead i used a program called VIRTUAL MACHINE WORKSTATION 6.5 (for links keep confidential suppling ur email to me) this program will allow u to install and run several operating systems at a time regardless of your current hardware, it will run as an application in vista O/S. so i installed xp pro (on vmware 6.5) that i had handy somewhere, and then the drivers from the creative disc. then i run the firmware updater and yes it recognises my zen for the first time and loads a brand new firmware. easy as that, zen reboots and main menu appears, what a joy.
so all i used was:
vmware 6.5
xp pro (wmp10)
creative disc
firmware updater by creative
installing operating systems on vmware is very easy and doesnt require restarts etc.. u can switch through vista and xp like a window application just like that.
hope this helps, zen micro is by far the ultimate mp3 player for its sound breathtaking performance and loudness, totally worth the trouble. this is 100% fixable
Mar 31, 2008 | Creative Labs Zen Touch MP3 Player
Huawei Sonic Plus U8661 Dual Sim 2 Line Number Android Mobile Phone Smartphone Logo
514 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
honeybun1986
john h
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
