Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
Hitachi Rear Projection TV 60V 500A-checked bulb-looks good-replaced a while back-can it still be bad
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
The lamp or even the ballast that powers it can look perfect and be bad.
Posted on Dec 22, 2012
  • 1153 Answers
SOURCE: picture on tv flickers on projection tv
more info at ctechnicians.com email
Posted on Dec 23, 2007
SOURCE: Hitachi 53SDX01B Rear Projection Television - No Picture
i have a 50" r.p. Hitachi, kinda had the same problem, it would go off at different times and i't hit on the back and get it to come back on,but after awlhile i'd have to hit it more and harder to get it back on till it quit, the menu would come on and would show the video 1 ,3 and that in the corner.After paying $75 for a guy to say it wasn't worth fixing i tried myself. Not knowing what i was doing, i checked all wire plug connections. Found 2 that wasn't seated good replugged them and still didn't work then tried the bulbs, just kinda jiggled all 3 one didn't feel the same so just tapped on it alittle and it popped, i guess back into place, anyway turned on the tv and it worked. Had moved it recentlly so i don't know if that is what moved the bulb. Hope this helps, also mine is a '94 model.
Posted on Apr 04, 2008
ctf1800
  • 4402 Answers
SOURCE: cleaning tv screen of hitachi rear projection tv
http://serviceman.site88.net/index.htm
Posted on Jul 07, 2008
  • 4234 Answers
SOURCE: Hitachi 43FDX Rear Projection TV
If the picture was good prior to the 3D images, I would fix it. The convergence ICs either have poor connections or are defective. The IC is an STK392-110. There may be 2 inside the set. If you have this repaired, expect a labor cost in the $200 range. Request that the ICs be replaced rather than the board changed. This will maintain all of the internal settings and require only part replacement not a complete re-convergence adjustment.
Keep us posted.
Dan
Posted on May 01, 2009
johnnydiode
  • 647 Answers
SOURCE: hitachi rear projection tv will not turn on. what
Here are a couple of common faults for this model from the hitachi Sevice Website
Symptom: INTM GOES DEAD
Cause: SOLDER K088,89,90,91 (JUMPERS)
Symptom: POWERS UP; SHUTS DOWN
Cause: CHECK C922, C921, L708, CONNECTION AT PIN 1 OF I907
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below.
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
The only way to determine the real cause is :
By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour.
Posted on Sep 26, 2009
My 59" Hitachi Rear-Projection TV
You have a bad light engine (optical block). This is the most expensive part of the TV. Do a search with the model number on Google or Ebay and even type the words "light engine" in your search. You can then find the price of the part. You can find a service manual by typing in the model number followed by "service manual". This will show disassembly instructions.
Jun 04, 2011 | Hitachi 60V500 60" Rear Projection...
WILL NOT TURN ON. GREEN LIGHT; TWO RED LIGHTS
check the projectors lamp.look like to need replace
May 05, 2010 | Hitachi 60V500 60" Rear Projection...
We have a 50 inch Hitachi tv. Last night when we turned it on the lamp light and the temp light started blinking red and the tv would never come on. What do we need to do to fix it?
Probably needs the bulb replaced. Look in your manual for a bulb replacement number, surf the net, there is a lot out there to choose from. But.... make sure you buy a original hitachi replacement bulb. Hope this is helpful.
Oct 29, 2009 | Hitachi 51F500 51" Rear Projection...
My hitachi turns on and has a red/green glow, but no picture on it. It sounds like it is running, but there is no picture or sound. It recently had a power surge go through it. What could have gone wrong...
have you checked the bulb in the tv? sounds like the bulb is no good they are around 40-60 bucks...make sure tv is off and unplugged before checking and dont touch it just look to see if its blown
Jun 04, 2009 | Hitachi 60V500 60" Rear Projection...
Hitachi 50ux58b 50"
hello. it sound like a power supply problem to me .!!! it could be a bad solder joint.!!! or a bad fly back transformer.? "good luck"
Jul 27, 2008 | Hitachi 50UX58B 50" Rear Projection...
Apr 04, 2008 | Hitachi 53SDX01B 53" Rear Projection...
Hitachi Rear Projection LCD TV Lamp
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Oct 17, 2007 | Hitachi 50V720 Television
Hitachi Rear Projection TV Flickers Red
No, this could mean a loose connection on crt board(red of course) Look also and check to see if lines going to board are connected correctly. If nothing, then there could be something trying to short itself out on crt board. look for burnt resistors and bad capacitors.
Jan 19, 2007 | Hitachi 51G500 51" Rear Projection...
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
29 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
