Question about Whirlpool Washing Machines
Whirlpool cabrio model WGD6-400SW1 no heat, drum does move
Cabrio model WGD6-400SW1 no heat, drum does spin, timer does move, circuit fine
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Does the igniter glow?
Posted on Nov 27, 2012
  • 39 Answers
SOURCE: Whirlpool Cabrio W10106470 has an F51 code. What
F51 error is a rotor position sensor error, two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197)
Posted on Jun 23, 2009
  • 175 Answers
SOURCE: Whirlpool Cabrio has started displaying error F50
hi..the reason to this problem is the RPS(Rotory positon
sensor).
check it out..
thank u..
kindly rate my response..
Posted on Jun 29, 2009
SOURCE: shirt caught between the drums on my whirlpool cabrio washer
1. Unplug and take off the top of the washer.  There are two pressure clips in the front inside the crack between the top and body of the washer.  Use a stiff putty kniff to depress the clips and flip the top up out of the way.
2. Pry the top plastic shroud off the tub.  There are a series of plastic retainers clips around the shroud.  Pry them up and remove the shroud.
3. On the small agitator on the bottom of the washer, use your putty knife to remove the domed plastic cap in the center.  Pry it up with the corner of the knife to expose the nut.
4. Use a socket wrench to remove the center nut.  It will likely take a good deal of force to loosen it.
5. Once you have removed the center nut, get another person to help you lift the stainless steel inner tub out of the washer.  Place it aside.
6. In the bottom of the outer plastic tub, you will find the shirt (or other garment) caught in the drain.  Remove the screws on the top of the plastic drain cover, and lift up the drain cover.
7. Remove the stuck item(s).  For all the coins and small part that have fallen into the drain tub, you may have to open up the back of the washer and remove the drain hose to access the items in the drain.  Luckily the drain hose is held on with cheap hose pressure clamps, so you can do this relatively easily.
8. Call or email whirlpool and tell them that the washer is pulling clothes into the space between the inner and outer drums.  They will respond by telling you they have never heard of this problem before and if you need service, call "A&E Factory Service toll-free at (800) 771-3029."
9. Be frustrated and vow never to buy a Whirlpool product again.
Hope this helps
Posted on May 05, 2009
SOURCE: F50 error code and Whirlpool Cabrio
JUST SPOKE WITH WHIRLPOOL ABOUT THE F-50 CODE. THEY SAID THAT THEY ARE AWARE OF THE PROBLEM AND THEY ARE PAYING TO FIX IT. ALSO THE CONTROLL BOARD AND THE RPS SENSOR MUST BE REPLACED TO FIX THE PROBLEM. THE OWNER MUST CALL WHIRLPOOL, NOT THE TECH, TO GET THEM TO PAY FOR IT. HOPE THIS HELPS.
Posted on Mar 29, 2010
  • 57 Answers
SOURCE: whirlpool cabrio loud noise during spin cycle
The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
Posted on May 18, 2010
Cabrio washer wtw5500xw0 loud spin and grease on floor
FIXED Cabrio has loud noise during spin - ApplianceBlog
www.applianceblog.com/.../16339-Cabrio-has-loud-noise-during-spin
Aug 21, 2009 - 10 posts - ‎5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
How to tell if your bearings are bad on a Whirlpool Cabrio ...
? 1:01
https://www.youtube.com/watch?v=5rHn13lKjzc
Jan 19, 2012 - Uploaded by RenewAppliance
http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
Jan 16, 2016 | Washing Machines
Whirlpool cabrio washing machine doesn't spin
Try to turn the drum by hand, if it hard to turn, there may be something stuck underneath spin basket. If it does turn freely but makes a loud growling sound, you probably have a bad bearing. You should notice black oil and water mixture at bottom of washer, on the rotor. It will usually throw a f51 error code. This unit has service bulletin on this problem.
Apr 05, 2014 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool cabrio loud noise
Check your bearings. This post will show you most of what you need to know about your bearings:
http://www.squidoo.com/how-to-replace-bearings-in-a-whirlpool-cabrio-maytag-bravo-or-kenmore-oasis
Nov 06, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio makes excessive noise during spin cycle
Your model has a bearing under the tub which is probably going bad and needs to be replaced. cabrio washer bearing replacement YouTube
Oct 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio loud noise during spin cycle
May 15, 2010 | Washing Machines
Whirlpool Cabrio F50 Error
Most likely the RPS sensor or the control board. Originally they had trouble with the RPS sensors.
Aug 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't drain or spin
the timer may need to be replaced.. it might not be clicking on the spin cycle. try moving the dial manually to the spin mode.
Jul 30, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio will not heat up....
there is usually a wire diagram inside the rear panel near the timer.
Jul 24, 2009 | Whirlpool Dryers
Washing Machines Logo
221 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
