Question about Goldstar Microwave Ovens
Oven quit working on model mv-1320w
Everything else working on unit. Timer shows min. being used but oven wont turn on.
  • Goldstar Master
  • 9,085 Answers
That would be a defective door switch, most likely the bottom one.
(It's either the top or bottom switch (not the middle one) and whichever one has thicker wires, not the one with the thinner wires.)
See my help text file on door switches here.
To order other Goldstar / L.G. parts besides door switches, visit Encompass. You'll probably have to call them at 866-779-5835 to get part numbers.
Posted on Nov 28, 2012
  • mike agustynowicz Dec 02, 2012
    Thank`s for the help, not sure yet if I want to bother with 14 year old oven or just replace it. I`m not joe handyman.
SOURCE: Hood lights
my microwave won't heat. I want to remove it and replace. How do I do this.
Posted on Jul 20, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Kenmore Galaxy Microwave Hood Combo Model 72180002400
Since it sounds louder than before, it is probably a bad high voltage diode or magnetron.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
Sears may send you a magnetron to install yourself since it's under warranty. For that or warranty service, contact Sears at http://www.sears.com.
You can save about $75 by taking it to the shop yourself, as opposed to an in-home service call.
Posted on Aug 08, 2008
MNTECH
  • 1543 Answers
SOURCE: My Goldstar Microvave (model MV-1526W)
You probably don't want to hear all this, but:
Microwave ovens are generally not a fix it yourself item. You need the proper test equipment and knowlege in order to service them safely.
(if, for example, the bleader resister inside the high voltage capacitor fails, the capacitor can hold a 400+ volt charge long after the unit has been unpluged, which can be hazardous) A guess without being able to work on the unit would be that the magneton tube (6324W1A001A) has failed, which does carry an 8 year part warranty on that part (for your model), but labor is not covered beyong the first year. The unit has to come off the wall, and the outer case removed just to get to the mag tube. Of course you could have a bad capacitor, rectifier, high voltage transformer, or a bad motherboard. I'd recommend calling a local repair shop to see what they would charge for a repair estimate if you brought the unit in.
(by the way, we are unable to respond back to comments on premium questions)
Posted on Dec 06, 2009
  • 8404 Answers
SOURCE: I have a GE SpacemakerXL Microwave Oven
Check the door safety interlock switches.
Thanks for using FixYa.com
Posted on Dec 11, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: hello, i own a 7year
Is there any unusual noise or is it louder or quieter than normal?
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
If it sounds the same as usual or a little louder, I would suspect the magnetron or high voltage diode has failed.
If it is much quieter than usual I would suspect a bad upper door switch.
The service manual is here.
Also see this file on door switches.
Posted on Aug 23, 2010
Microwave does not heat. used as timer and has not worked since
If you ran this unit empty on full power as a timer, it burned out the magnetron. You have to have a load in a microwave or else there is nothing for the energy to work on so it backs up and destroys itself. It's like putting a potato in a tail pipe..... only worse....
Nov 03, 2013 | Goldstar MV-1501 Microwave Oven
The scrolling speed for the timed cooking is running incredibly fast - too fast to allow the food to cook. I was looking for a manual for Model #MV-1320B.
The owner's manual can be found here.
It sounds like the oven has been placed in "demo mode".
Nov 14, 2012 | Goldstar MV-1320W/B Microwave Oven
My microwave wont heat food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 11, 2011 | Goldstar MV-1501 Microwave Oven
Dear Sir, I have a Goldstar MV-1320W microwave. Tonight, for no apparent reason a loud blowing noise started. It sounded different than the usual fan and would not respond to anything from the keypad. I...
I'd suspect the relay located on the pcb to be shorted, as in the contacts welded/stuck together.  This isn't available separately from Goldstar, as it comes with the circuit board.  The board will probably be prohibitively expensive.  If you have the know-how, remove the board so as to make working on it easier.  Remove the relay lid and using a points file or emery cloth, clean them up.  My experience with this, is the repair works great.  The relay lid may never fit again, as most of them are "sealed", and not designed for removal.  Of course, a replacement relay with roughly the same specs could replace the defective one.  These are usually 120v spst, normally open.
Jul 15, 2009 | Goldstar MV-1320W/B Microwave Oven
Goldstar microwave oven stop heating
microwave ovens have a special Magntron fuse that is inside the body of the microwave its much bigger than a normal fuse, if its blown the microwave wont work.
Jul 30, 2017 | Goldstar Microwave Ovens
Goldstar keypad not working
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 22, 2008 | Goldstar MV-1320W/B Microwave Oven
Aug 07, 2008 | LG MV-1444Y Microwave Oven
Mvh1615
It doesnt matter how old a system was. components can be failed at any point in time. unplug the unit. carefully disassembly and visually check the diode near magnetron and capacitor, it might be broken.If seems good, check the thermostat continuity,if beeping. changage your magnetron. be careful capacitor store charges that deadly. discharge the capacitor first.
when you change mag. change the diode too.
Jul 24, 2008 | Goldstar MV-1501 Microwave Oven
Goldstar Microwave
Could be the relay, an internal fuse. With the power off, open up the key panel and search for a fuse. Also, there are thermo sensors black, diameter of a dime and 3/8 inch thick with two wires. Check the fuse and replace if necessary. The thermo can be jumped out to test. Remove the wires, use a paper clip between them and tape it up. Briefly turn the unit on. Replace if it works now. The thermo is generally clamped to the wall of the oven behind the key panel. Never run without the thermo sensor.
Dec 18, 2007 | Goldstar MV-1501 Microwave Oven
Hood lights
first remove mains cord from main power. and remove the microwave oven top cover and check the bulb and crefully remove the old bulb and put new bulb. at high voltagae section dont touch any thing ,that area very dangerous ,thats why very carefully work inside the microwave oven ..
Sep 09, 2007 | Goldstar MV-1320W/B Microwave Oven
Microwave Ovens Logo
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
