Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
I have hitachi 60 v 500a-lamp doen not look burned -can it still be bad -i replaced it some time ago
HItachi model 60V 500 A
  • franklatt
    franklatt Nov 29, 2012
    Can it be something else-or shoul i just change the lamp and go from there
  • franklatt
    Thank u
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Try the lamp first and go from there.
Posted on Dec 22, 2012
My 50 inch hitachi hd projection tv picture won't
This T.V. more than likely has a bad lamp. I don't know the model number so look up on ebay for a lamp replacement by model number after you inspect it and find it to look cloudy or exploded.
Jun 20, 2011 | Hitachi Televison & Video
It is just very dim. The bulb has 500 hours - is it just a bulb?
This projector had a lamp rated at 2000 hours (normal) / 3000 hours (eco mode). It last shipped in August 2008. It is a 3000 lumen projector. It's a reasonable business class projector.
As a first step, it's certainly worth checking your warranty status. Your projector will certainly be approaching the end of its warranty now, however this model was shipped with a 3 year warranty so it may still be covered if the fault is not the lamp. Check now, and log the (possible) fault with your local Hitachi service dept. eg http://hitachiserviceeu.com/support/contacts/contacts.htm
Essentially it is hard to say. You might find that replacing the lamp makes the projector considerably brighter. A new lamp in an old projector does not return the image to a showroom state though due to degradation in the LCD panels, and dirt etc.
If the projector is not displaying any sign of other fault (ie. it will run happily for a decent length of time, and there are no warning LEDs) it might be worth considering replacing the lamp. A new lamp will cost cost around £250 or $250. If you are going to replace the lamp before sending it for "repair" make sure you fit a genuine Hitachi lamp as non genuine lamps can lead to warranty problems.
Feb 15, 2011 | Hitachi Lamp CP-X400 CP-X200 -...
My Hitachi 50V500A has a large area where the color is turning out to red. Is this a lamp or a complete light engine replacement job?
not the lamp. hitachi knowingly had a defect with the fan not allowing enough air to cool the lamp which has burned the red color lense resulting in the red on your screen. enjoy your new brick thanks to hitachi!
Jan 09, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
My hitachi prjection tv does not come on. It flashes the temp and lamp lights and then shuts down. Is my lamp burned out?
Chances are real good the lamp is bad. Open the lamp door, remove the lamp and see if it is shattered or scorched on the inside. If so, replacing the lamp will fix it. Only replace it with a genuine Hitachi part. The part number should be on the lamp cage.
Good luck,
Skyassoc
Dec 14, 2010 | Hitachi 46F500 46" Rear Projection...
Hitachi 52" projection tv went black. when i
if this is a DLP it seems your lamp burned out and needs replaced , if so search ebay with model # for replacement, you can purchase a buld or lamp assembly
Nov 28, 2010 | Hitachi Televison & Video
I would like to know how to change the lamp from my Hitachi 50 inches HDTV. The lamp burned out 2 days ago, and I want to change the lamp by myself.
Most of these hitachi's have a lamp door on the back or behind the front panel (most).. pop off the front panel and open the little door, using a philips screwdriver and then you can pull out the lamp.
to get a new lamp, check out www.dlplampsource.com for a decent price and 1 year warranty
Jul 26, 2010 | Hitachi 50VS69 50" Projection HDTV
Hitachi model 60v500a.the middle of the screen is a little yello
If you Google "60v500a light engine" you will learn a few things about this set which was first sold in 2003.
There are some class action lawsuits out there for several Hitachi models made at about the same time.
Most of the time these sets develop a discolored area fairly large in the middle of the screen---a lot of them had a large red or pink oval area but other colors are possible.
This set uses a LAMP for the light source and it directs the light into the optical light engine--at the top of the engine is a 3 inch lens that the picture comes out of and is directed into the mirror which puts it on the screen.
Lots of these sets develop a "burn" inside the engine from the heat--there are a series of lens and baffles inside---even slight separation inside will change the color in some area of the picture.
I am sorry to give you bad news but I have replaced a lot of these engines under extended and when they were new mfg. warranty.
The part is no longer available from Hitachi new--the only way to get one is to remove the one in the set and have it sent out for "rebuild" and the last time I saw one the engine was over 600 dollars at the wholesale level not counting the fact that it is major labor to replace.
Find someone in your area familiar with Hitachi and this model and you will see what I am talking about.
Even though this is not good news, I think it is what your problem is.
If this helps you, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Hitachi 60V500 60" Rear Projection...
Blue Haze
yeah I have the blue haze also whats up?
May 20, 2008 | Hitachi 50V720 Television
TV Problem
It is a failure in the light engine itself. You will need to have it replaced. Here is a link to that rather costly part. http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/50V500/Hitachi+Ltd/Hitachi/UX22201D/New.aspx
Apr 05, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
Henry  Thomas
Henry Thomas
