Question about Air Tools & Compressors
My brad nailer fires 5 or 6 brads at once - Air Tools & Compressors
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
I believe your trigger is fluttering... An O ring kit can usually cure the problem. What model is it?
Posted on Dec 09, 2012
Testimonial: "Thank you for your help Jeff. The problem was I worked on the switch myself and messed it up but the o-ring was the problem. Thanks again hope you have a Merry Christmas."
  • 65 Answers
SOURCE: brad nailer does not retract enough for brads to enter nailer
hi check to see if there is any wear on the blade or even if it is broken if so replace with a new item from your dealer , this will also come with a new seal so with a good clean your gun should bee like new hope this helps ian
Posted on Mar 25, 2009
  • 74 Answers
SOURCE: porter cable brad nailer only fires brad on second trigger pull
The dent in the wood is not caused by the air. It's caused by the set that drives the brad. Are you oiling it consistenly? Are the brads the right manufacturer for your porter cable brad nailer? From the information you give it appears that the brads are not advancing correctly or that the air pressure is not sufficient to dislodge the brad from the brad strip on the first strike - it takes an additional strike to break it free. The standard for adding oil is to add ten drops of air tool oil for every hour of operation. That seems like a lot, but the correct amount of oil is a sure way to prevent most air tool problems.
Posted on Aug 29, 2009
Testimonial: "Thanks for the info. I was not oiling it at that rate. Is there anything I can do to fix the issue now that I didn't prevent it?"
  • 21 Answers
SOURCE: Brad Nailer not firing. Just a shot of air. adjusting no help
Maybe is time for a service maintenace, this units you can replace all the O" rings, they came in a MaintenaceKit (with instructions) and price is real low., comparing to other brands. Keep in mind, the oil "eat" the clear plastic rings that are inside, that is why u can NOT put a lot of oil , just 2-3 drops Pneumatic oil per day. Also water\humidity from the compressor damage all components inside the nailer. Do not be afraid to open it (just to take a look inside) is 4 screws. of course is the unit is still covered by the warranty take it to your nearest servicenter.
hope this will help.
Posted on Sep 26, 2009
  • 142 Answers
SOURCE: My brad nailer shoots staples without any problem
the only suggestion i have is that you may have a feed problem, so i would clean and lube the track the nails run on
Posted on Mar 27, 2010
  • 885 Answers
SOURCE: does the brad nailer only use 2" brads or cam
Most nail guns are labeled with the longest nail/brad they can shoot but are capable of shooting shorter nails/brads. There should be a data sticker on the gun, usually on the magazine rail, or at least in the manual that tells you what pressure to operate the gun at, what guage brads the gun can shoot and the size of brads from shortest to longest it can handle.
Posted on Oct 22, 2010
Why does it go through the motions but nothing comes out?
If you are sure the brads are the correct type for your nailer, check the feed path to confirm it is clear.
Sep 02, 2015 | Tools & Hardware - Others
Mastercraft brad nailer model 57-7900-2 5/8" - 2"
No experience of Mastercraft brad nailers but if fires with out depressing nose tool is dangerous and should be returned to manufacturer. Dewalt make battery powered brad guns and recently produced a battery framing nailer. I would not say that other nail guns are exactly cheap if they are beware they may not be up to the pressures excerted on the whilst firing.
Jan 24, 2014 | Air Tools & Compressors
I have NT32Ae2 brad nailer. It worked fine when first used it 2 yrs ago. It now will not pink up brads but the gun will fire. No problem with compressor. The driver will come down and mark the wood.
Make sure your using the right gauge brads for your gun, should have sticker on rail with required brad gauge, and max length. Sometimes a brad will get jammed under drive pin where you cant see, might have to remove allen screws over pin to get jammed brad out
Oct 24, 2013 | Hitachi NT32AE2 58to114Inch by 18Gauge...
NEW BRAD NAILER ONCE LOADED WILL NOT WORK
Many modern brad and finish nails use a sequential fire trigger system. You have to push the nose of the tool down to depress the safety THEN pull the trigger. This is the opposite of how a bottom fire works where you hold the trigger and bump the nose to fire the gun.
Mar 02, 2012 | Air Tools & Compressors
The driver doesn't return after firing. it is a porter cable brad nailer BN200
This is pretty common with brad nailers
Remove the brads from your gun - disconnect from the air supply
On the front of your gun is a latch - open it
Check the sliding surface for build up of dirt or small pieces of metal from the brads.
Once clean polish the surface with a fine steel wool or a small brass brush
Reassemble with a drop of machine oil on the sliding surface
Oil your gun as you normally would
Using a piece of soft wood dry fire the gun 10 or so times to ensure that the dents it is making in the wood are all pretty even
Reload and nail something
Mar 08, 2010 | Porter Cable-Cable BN200B 5/8-inch to...
Porter cable bn200 nailer
Get a gasket kit---sounds like top seal around barrel
Feb 21, 2010 | Porter Cable-Cable BN200B 5/8-inch to...
Porter cable brad nailer only fires brad on second trigger pull
Aug 29, 2009 | Makita AF503 2'' 18 - Gauge Brad Nailer
No brad
Your anvil is not returning to the home position to allow the brad to index into the receiver. Try and push the anvil up all the way to the home position. If that works, then you need lubrication, new return spring, etc. All related to the anvil firing.
Jul 02, 2009 | Craftsman Nailer Kit, Palm Air Driver
Nailer jams with 1-5/8 brads
It sound to me that the 1 5/8 brads are not 18 guage but probably 16 guage and they will not work. Double check them first before going any further. You can usually lay them next to the smaller ones that work and see the size difference, if not let me know and I will dig deeper.
Feb 21, 2009 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Air Tools & Compressors Logo
41 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
