Question about Treadmill Doctor CardioZone Elite Max HRT Club Treadmill Walking Deck
Incline not working properly
The incline continually goes up by itself and will not come down when I press the button on the console or handle. To get it all the way down after use, I have to press the power on and off and it will descend incrementally until level. I recalibrated w/o success.
    Top Expert:
  • Treadmill Do... Master
  • 12,223 Answers
Please RUN the software calibration for easy diagnose, and troubleshooting and fix it.
2)However test the motor itsel, speed sensor test it for open, dirty, and clean it
3) Lube the elevation motor shaft, gear.
4) See the diagram attached.
Posted on Nov 27, 2012
X9i incline trainer clicking
Step 1:
RUN the calibration software . and fix it. God bless you
he Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Step 2:
Feb 07, 2013 | Nordic Track Incline Trainer X9i...
Tempo 621T treadmill incline Incline reads 0.0 but is not all the way down. How to bring it down.
you must RUN the software calibration, for troubleshooting and fix it.
See the steps.
The Steps fhor Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the
    1. F" appeared in). Troubleshooting the failure would be the next step.
Jan 09, 2013 | Exercise & Fitness
Tempo 621T treadmill stuck in incline postion scale is reading 0 but it is not completely down..How to reset my incline button
Run the software calibration for troubleshooting and fix it. See the next steps. God bless you
The Steps for Newer Style Console Calibration
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Lube the elevation motor, shaft and gear. adjust the POTentiomer,
Continuous incline with no lights on display except 2 lines on the incline
RUN the software calibration, for easy diagnose, troubleshooting, and fix it.
God bless you
Sep 04, 2012 | Icon Epic T60 Treadmill
Error 100 won't connect to network anymore to use ifit live
Check the power cord to ensure it is connected to the power supply and the treadmill if the power does not stay on or does not turn on. Look at the circuit breaker, located near the base of the unit, to see if the circuit was tripped. Push the switch back in to reset the circuit.
  • 2 Take the key out of the console, wait a minute and place it back in the console to resolve issues with the power turning on and off during use or if the console displays are not functioning properly.
  • 3 Remove the console key and press the "Stop" button to turn off the "Demo" mode, which is often the default setting when the treadmill is first purchased.
  • 4 Reset the incline by holding down the "Stop" and "Speed increase" buttons and putting in the console key. Release the buttons and then press the "Stop" button, followed by the down or up arrows for the incline. This step can be taken if errors are occurring with the incline function.
  • 5 Turn the treadmill "Off" and unplug the unit if errors continue. Wait five minutes and then plug the unit back on, insert the console key, and turn the treadmill "On." This will reset the treadmill and should return to normal funcTION
  • Oct 04, 2011 | Nordic Track NordicTrack Elite 9500 PRO...
    My proform 360p treadmill is stuck on full incline - can it be fixed and if so how???
    try thisSometimes incline motors will get frozen in position and need broke free. Try this:
    take the motor cover off and take the screw out of the bottom of the incline motor that is attached to the screw assembly. Once you remove the screw you should be able to break the incline motor free. run the incline up and down with the screw still off( laying the treadmill on its side may make this easier). Once it goes up and down (hold the screw so it goes in and out) reattach it then run the calibration described below. If it was just stuck it should work fine.
    1. remove safety key
    2. press and hold the speed+ and stop keys at the same time
    3. Put the safety key in/on and release the keys
    4. press stop once
    5. hit the incline + arrow and let the incline go the whole way up and down
    6. remove safety key and try
    If these instructions do not work to fix the incline motor
    check your main harness running down the right leg for breaks in the wires or a loose connection if nothings found you can switch the red and black wires on the incline motor terminal block and see if it goes down. If it does you know you are only getting voltage to one side of the motor. There is a schematic under the motor hood that tells you what the voltage should be when you press the up or down keys. Use a multi-meter to see if you are getting the correct voltage coming from the console to the motor control board and then from the board to the motor. If no voltage from console-replace console if you have voltage from console but not from board - replace board and finally if you have voltage from console and from board replace motor. You will need to test the voltage both when pressing the up key and the down key.
    Jul 14, 2010 | Proform Exercise & Fitness
    My treadmill proform835QT fails to incline. What can I do?
    Try to calibrate the incline: Hold down the stop and speed up buttons at the same time then insert the key. release the buttons the press the stop button and release then press the incline up button. the incline motor should go all the way up then all the way down with - - on the console. If the unit only moves just a and inch or so or the motor just hums , the incline sensor is faulty.
    Jan 15, 2010 | Proform CrossTrainer Treadmill
    My ProForm 530 is stuck in the incline position. Once the key is inserted, the treadmill is steady trying to incline past 12 and does not respond to me pressing the ''incline down'' button. It continues to...
    plug her back in, insert key, let her do her thing while u just sit back- I believe shes trying to Calibrate. If so, she will go up all the way,then back down on her own. after she's in down posistion, console will beep/beep and she has reset herself.. let me know what goes on after u do this. David
    Jan 05, 2010 | Exercise & Fitness
    Proform 550xp Treadmill in continuous incline/decline mode!!!
    i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
    1. plug in and turn on treadmill, keep red key out
    2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
    3. after red key is inserted, let go of both buttons
    **CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
    4. press stop button once
    5. press speed up button until it reads 85 (see what i mean?!)
    6. press stop button once
    7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
    Dec 30, 2009 | Exercise & Fitness
    Treadmill Doctor CardioZone Elite Max HRT Club Treadmill Walking Deck Logo
    93 people viewed this question
    Top Treadmill Doctor Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Electro Med Services...
    fordexpert
    Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
