How do I reset error code C5357 on Konica Minolta Bizhub C352?
Know that this is an error code for cooling fan 1. Have repaired but don't know how to reset code C5357.
  • 32 Answers
SOURCE: Konica Minolta bizhub C352 error code C-D010
enter service mode, select state confirmation, select memory/hdd adj, select hdd format, select physical format, press start button, when displays ok turn off main power for 10 seconds, c-d010 will display again, repeat instructions and do logical format, turn main power off for 10 seconds..should be ok
si
Posted on Jul 03, 2009
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
  • 4 Answers
SOURCE: Konica Minolta Bizhub C352 error C-B116
try with trouble reset
turn off the machine, press and keep pressed utility counter, turn on the machine
on the display you'll see the Trouble reset button on the display, touch it and turn off and on the machine
check if error disappear
Posted on Oct 19, 2008
kfrejlich
SOURCE: Konica Minolta Bizhub C352 error code C-0204
I had the same recently.
Problem is caused by a paper which stuck behind the paper tray. It happens when You put to much paper od while moving (for example). Solution: take out the paper tray 1 and 2, remove the paper from the space behind the trays.
Pixel
www.mojito-networks.com
Posted on Jun 23, 2009
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
I have a proplem in konica minolta bizhub c352 how to sort the problem i have an error code 3451
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day. ENSURE YOU WAIT THE 10 SECONDS
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 15, 2016 | Konica Minolta bizhub Office Equipment &...
Bizhub c352 error 3451
C550 cooling fan not functioning, what can i do to make work?
Konica Minolta bizhub cooling fan not working Questions ...
www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
Konica Minolta Bizhub C550 Cooling fan power - Questions ...
www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
cooling fan not operating properly - HP Support Forum
Nov 29, 2015 | Cars & Trucks
Konica minolta bizhub 163 error 0045, what I do to work
from what I've read here:
Error Codes Konica Minolta bizhub 163
, this is a Fusing Cooling Fan Motor malfunction, which suggests, I'm afraid, that you have to have it serviced.
Kind regards,
Jon Erik
Nov 14, 2014 | Konica Minolta bizhub Office Equipment &...
How to fix problem code 8103 with konica minolta bizhub series?
C 8103 Lift function error up movement.Is a mechanical problem.Check the componenets(motor,gears,actuators)
Jul 25, 2014 | Konica Minolta Bizhub Series C352...
Error C-D370 C352
Try to reset the error code.
Turn OFF the copier and press and hold pressed the Utility key and turn ON the copier.Wait will appaire Trouble reset message on the display and release the Utility key,touch the message and turn OFF the copier.Wait 1 minutes and Turn ON.
Mar 15, 2013 | Konica Minolta bizhub C250 All-In-One...
Reset image unit (Magenta) Konica Minolta Bizhub C352
Change the chip or enter in service mode and change the imaging unit life duration to long life.The copier displayed continuosly Please change the image unit,press OK and ignore.
Feb 13, 2013 | Konica Minolta bizhub Office Equipment &...
548 people viewed this question
k24674
jasbo
jasbo
