Question about GE Refrigerators
GSS22KGPA side by side not cooling
Freezer and Fridge not cooling, just the fan inside the freezer top part and the fan at the lower back are running. Compressor is not running at any temperature setting. No clicking sound to indicate compressor motor is running. How can I verify the status of this motor. Any help is much appreciated. Thanks.
    Top Expert:
  • GE Master
  • 9,472 Answers
Unplug the unit and pull the relay off the compressor and shake it to see if it rattles. Post back the results.
Posted on Nov 27, 2012
  • 2 more comments
  • rani Nov 28, 2012
    Hi Richard, Thanks for the reply. There's a 3 pin plug at the back of the unit labelled Line, Defrost, and Compressor. I jumper the Line and Compressor pins and the compressor pins and the compressor runs. I don't know what cause the relay not to switch on. It seems like it is stuck in defrost mode. I don't have a wiring diagram so I can't tell for sure. Hopefully someone in the forum will have an answer to my problem. Thanks everyone.
  • Richard Roth
    Richard Roth Nov 28, 2012
    OK, on that model I believe the defrost timer is a part of the main control board. Here is the main control board to order and if that doesn't work you can return the board. The supplier has a 365 day, any part, any reason return policy so you won't have any problems returning it. Keep me posted on your endeavor.
  • Richard Roth
    Opps, here is the part! http://bit.ly/TpI8Jy
  • rani Nov 29, 2012
    I removed the main board and found the PCB trace at the back of the compressor relay burnt. Put a jumper wire in place of the burnt pcb trace. My fridge is working fine now. Thank you.
Cerfer39
  • 709 Answers
SOURCE: Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website www.playstationclinic.com
Posted on Sep 25, 2007
  • 61 Answers
SOURCE: Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Posted on Oct 20, 2008
  • 833 Answers
SOURCE: Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Posted on Nov 20, 2008
peyton32034
  • 410 Answers
SOURCE: freezer/ fridge not cooling, compressor not running
this refig has 2 independent temp controls one that operates the freezer side (this one also operates compressor, condenser fan and evporator fan) and one that controls the temp for the fresh food side this one operates a damper and evaporator motor.
I looked up you model number and you need to check the control that is located to the left side of the control panel or the freezer control. if it is 60f in the unit then if this control is good it should read infinity on a ohms meter. if its bad you will get no reading at all. alternatley you may try hitting the control solidly with the **** of a screwdriver sometimes the contact will hange open. message me back if you need further assistance. peyton...
Posted on Jan 28, 2009
  • 159 Answers
SOURCE: Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
Posted on May 22, 2009
Why won't my fridge cool properly
This happened to me also, I had to let refrigerator defrost all the way by unplugging it. The lines that carry the freon had frozen so they were not circulating properly. I had to buy ice and use coolers for food, then wait till next day before plugging unit back in.
Apr 24, 2014 | GE GSS22SGM Side by Side Refrigerator
What causes the coils behind the panel in the freezer to freeze up and stop the freezer fan? top half of freezer defrosts, lower half stays cold.Fridge is side by side and freezer fan keeps turning of
When the evaporator fan motor stops running the top half of the back wall of the freezer will frost over and the the only reason the lower portion stays cool is because cold air falls. More than likely you have a a dc motor fan and its bad, but be wary with ge, the main control board could also go bad causing the fan not to run.
Sep 05, 2012 | GE Refrigerators
Frigidaire frs26lh5dso freezer works great, fridge side is warm.
make sure door to refrigerator is all the way up, so when it is closed it turns the cooling part on. I have to check mine all the time and screw it up if it's down, which is quite often. Mine is a side by side and I just make sure it's even with the top of refrigerator and even with the freezer door.
Jul 16, 2012 | Frigidaire Refrigerators
Bottom half of fridge and freezer are cold top half warm?
This sounds like an air flow issue, If your freezer fan is running still you may have a defrost problem starting in the freezer cooling coils. This will cause the cold from the freezer to back flow into the bottom of the fridge and only the lower half of the freezer to keep very cold.
Most likely culprit for defrost issues would be the terminating thermostat (inside freezer behind back wall and clips to top of coils).
Good luck and let me know if you need more help!
Jun 14, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Sub Zero side by side frig. side not cooling. Freezer works fine
There is a fan inside the freezer and possibly the fridge. It circulates the cold evenly throughout the unit. The fan may shut off with the door open so hold the door switch in to see if you hear the fan. It's behind the rear cover on the inside.
Sep 11, 2009 | Refrigerators
Freezer temp is wear fridge shoud be.fridge temp 55 degress.
Check the fan in back which cools the compressor . Also check the coils to make sure they are clean of dust , lint , etc...
Aug 02, 2009 | Magic Chef CTB1821AR Top Freezer...
Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Jun 11, 2009 | Jenn-Air JFC2089HE French Door...
Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
GE Refrigerator Model GSS20IEDPD
check the back panel inside the freezer section near the lower shelf (not the bottom bim) for frost
Oct 14, 2007 | Refrigerators
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
