Question about Mtd Garden
Tecumseh 8hp HIGH REVING! snowblower
Have an mtd yard machine snow blower with a 8hp tecumseh engine,theother day while blowing snow, the engine rpm's picked up dramaticallyand the engine started to scream! I got it backed down by pushin thelever back to slow(it was still too high for slow) I could still blowsnow to finish by having augers and wheels engaged but as soons I ranout of snow, engine would pick right up and rev really high again! Itook the carb off an checked linkage and bowl and looked, but cannotsee why....put it back together an it does same thing...could thegovenor went out of adjustment? any ideas? appreciate ANY HELP! we'resuppose to get 4-8'' today in n.y. (.....again!) scart to use it asis....thanks in advance! RC
  • 2 more comments
  • rcdeer55
    rcdeer55 Jan 10, 2009
    i'm leanin towards the carb gasket...just makes the most sense so far cause it happened really quick,and i can still adjust speed..(it ain't the right speeds but it does adjust..) but the gov. thing is a strong second,,i can fix gaskets,,gov's..??? thanks!
  • rcdeer55
    so, if i understand this..when i can run it again,the lever going to the gov. should move? if it don't something is broke inside? (no linkage or springs are broke now) i had it apart, put it back, ran it did same thing..it runs fast at low setting but steady,but normally that setting would be putt-putt speed.....could gov. be broke? inside? what would i look for? ...gov is new to me! appreciate yer help!
  • rcdeer55
    rcdeer55 Jan 11, 2009
    thank you! will do!!
  • rcdeer55
    rcdeer55 Jan 15, 2009
    Well... I put new pulley on, new belts,and new carb gasket..started it up.... blew the side of the block right out..wasn't rev'in very fast either,,,guess we'll never know now,,,but I REALLY do appreciate all the help,links and ideas! Thank You All! RC now findin a 8hp motor....................or..
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
be careful, if the engine over revs it may just explode. These engines are very picky if over sped and easily blow up.
Your problem may be a broken throttle control rod, have look at that first. If the control rods are fine and in place it could be the fly wheel governor is worn out.
Posted on Jan 10, 2009
  • HW_Dude
    HW_Dude Jan 10, 2009
    Well, I am not convinced the gasket could cause you this grief. I suggest to remove the metal sheet cover that covers the carb and assembly and then observe the linkage in operation. You want to see some 'regulating' action which maintains the RPM. If the linkage gets stuck or there is a problem with the governor assembly slipping, you may get over speeding.
    Have a look here:http://outdoorpowerinfo.com/repairs/
  • HW_Dude
    HW_Dude Jan 11, 2009
    Have a look here regarding the governor setup and troubleshooting.:
    http://www.smallenginesuppliers.com/shop...
    Good Luck
Tecumseh 8hp drive stopped have to push
Could be the belt is broke or come off or the pully loosened on the shaft. Good Luck
Jan 04, 2014 | Tecumseh Snowblower Snow Blower Starter...
Tecumseh engine snowblower, will only run if I keep pushing the primer bulb, Why?
Take off the screw that holds the carburetor bowl on and clean the holes with a needle and blow air through them. These holes feed gas from thr bowl into the carb and may be clogged.
Feb 23, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Mtd yard snow machine dont start
check fuel filter if ok rebuild carb. and replace all gaskets
Dec 02, 2011 | Tecumseh Snowblower Snow Blower Starter...
Need a manual for yard machine snow blower, model #31A-260-7310
Assuming that you have a Tecumseh engine on your machine, this should help you out a bit. Tecumseh also has some other very helpful documentation on their TecumsehPower.com website.
http://www.tecumsehpower.com/CustomerService/BSI.pdf
Nov 08, 2011 | Mtd 22" Yard Machine Push Mower
My snowblower Yard Machines 26" 8HP started but
Clean the carburetor and check the intake manifold to the head for air leaks/bad gaskets.
Jan 13, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I have a 5hp tecumseh motor HS50-67324K on a craftman snow blower,could you please tell me the high and low RPM speed settings on this unit.
Here is a 70 page Tecumseh service guide. Locate the type of carburetor you have in the guide. All instructions with diagrams are available. This is a PDF file. Adobe Reader will be needed to view it.
http://www.smallenginesuppliers.com/html/engine-specs/tecumseh/Tecumseh_quick_reference.pdf
Dec 14, 2010 | Tecumseh 5hp Engine Snow King Mtd Blowers...
I have a mtd 26" 8hp snowblower that need aufer
if the bolt broke off then you need to get old part of it out before putting in a new bolt.
Dec 12, 2010 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
2,207 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
