Question about GE JBP66 Electric Kitchen Range
CAN THE THERMOSTAT ON A GE MODEL JBP66WOB4WW BE ADJUSTED
OVEN TEMP TOO HOT
    Top Expert:
  • GE Master
  • 9,472 Answers
No it cannot be adjusted and will need to be replaced. Here is the sensor to order.
Posted on Nov 27, 2012
5 Suggested Answers
  • 61 Answers
SOURCE: oven tempature is 10 to 15 degrees lower than set
all ovens very sometimes 10-25 degrees +/- depending on the brand..nothing you can, do set the temp a little higher if you know its off.
Posted on Jan 21, 2010
  • 382 Answers
SOURCE: GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
Posted on Dec 27, 2009
  • 126 Answers
SOURCE: ge spectra xl44 heats up but doesn't maintain heat
Turn oven to 350"look for ignition glow .within 30-60 seconds the burner should fire .if it takes too long ignitor is weak (not drawing 3.5+ amps and should be replaced).Sometimes the ignitor will work for the first couple of cycles and then die down. bad sensor would usually show f- code.
Posted on Jun 27, 2009
  • 530 Answers
SOURCE: oven to getting Hot
it is possible that you have a bad temp probe
Posted on May 28, 2009
General Electric oven how to reset thermostat
First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
Aug 08, 2014 | GE Profile JTP18 Electric Single Oven
Gas oven temp
You might be able to order a thermostat online. Try the GE website.
Dec 15, 2012 | General Electric ge JGBS04BPW wb1k5 Oven...
I own a spectra range Model # JBP30B0B4WH The problem is that the oven temp, is off about 15 degrees how can I adjust it? Roy
This is from page 13 of your manual:
To Adjust the Thermostat
Put the Oven Temperature knob in
the OFF position.
Press and hold the HOUR +/– pads for
5 seconds until the display changes.
Before display changes back, press
the HOUR +/– pads to increase or
decrease the temperature in 5
degree increments.
The oven temperature can be adjusted as
much as 35°F. or down as much as 35°F.
If the oven adjustment is set cooler
than the factory setting a minus sign (–)
and the adjusted temperature will appear
in the display.
Wait several seconds for the control
to automatically set and return to its
previous setting.
Feb 10, 2010 | GE Spectra JBP78 Electric Kitchen Range
Oven tempature is 10 to 15 degrees lower than set temp.Can this be adjusted? This is a electric oven. GE Profile Model VZ295971J.
Jan 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE oven heating element heats red hot no matter what temp I put the oven on
Something is probobly wrong with the thermostat, it gets hot to warm up, but should lessen as it reaches your desired temp. If the thermostat is bad it will just keep going.
Nov 20, 2009 | GE Profile JTP18 Electric Single Oven
Oven to getting Hot
May 28, 2009 | GE JBP71 Electric Kitchen Range
Bottom oven gets extremely hot
It would appear you have a faulty thermostat that controls the temp. SUggest you get a new thermostat fitted.
Dec 08, 2008 | GE JTP27 Electric Double Oven
GE JBP66 Electric Kitchen Range Logo
291 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
