Question about Air Purifiers
I have a honeywell air filter model 17000. the motor is bad, where can i find a replacement motor . the motor p/n is 001-02077-000 ref # hm-150
I have a honeywell air filter model 17000. the motor is bad. the motor p/n is 001-02077-000 ref# hm-150 can't find parts on honeywell site. where can i get a replacement motor.
4 Suggested Answers
SOURCE: honeywell air purifier, will not turn on,
Does this unit have a 3 volt battery in the control panel like the 17005 model? The battery lasts appx 4-5 years then the unit doesnt seem to work any more once you change it. The unit must be left plugged in while you change the battery otherwise you lose your programing. If your not under warranty, UNPLUG it then pull out the filter, take out the 6 screws, separate the sides, and expose the fan. If the fan does not spin very easilly with no drag, the bearings are gummy; which is why nearly all small motors get replaced. The motor can be easilly disassembled, gummy grease washed off with rubbing alcohol and a cotton swab, and reoiled with synthetic oil. These units are designed to gum up and require replacement at approximately the same time the warranty expires. They would last almost indefinitely if oiled in their little oil ports occasionally (every couple of years). If your bearings are stiff, then a hidden safety device has tripped to avoid a fire, and if you are handy, you can replace the blown fuse if you can locate it on the circuit board, or the blown over temp device. If you have to pay some one to do this, it is cheaper to replace the whole machine in this throw away world.
Posted on Jan 02, 2010
SOURCE: I have a Kaz Honeywell
Check to see if there is power getting to your device. If it is a 110-volt unit, plug a lamp or other device into the same outlet the device is plugged into. If there's no power, check the fuses or circuit breakers. If there's still no power, you will need to contact a qualified electrician to restore power to the outlet. If there is power to the appliance but it is still completely dead there may be a problem in one or more of the following areas: Wiring (Inspect for any broken or burnt wiring) Selector switch Control board Work on these areas of an appliance may require help from an appliance repair person or other qualified technician.
Take care.
Posted on Oct 10, 2010
  • 4736 Answers
SOURCE: WILL NOT START....NO POWER? BOUGHT
Make sure that the receptacle that it's plugged in to is still working. The circuit breaker for that outlet may have been tripped in your home's circuit breaker panel. Or there may be a loose wire or bad connection inside the outlet box. May not be air purifiers fault at all.
Posted on Mar 29, 2011
Putting filter back in a Honeywell air purifier model hfd-135
Hello, this is Ava with Think Crucial.
You may refer to this online manual for your model number to help you put back the filters in your unit.
Honeywell QuietClean HFD 110 Series User Manual
You can purchase a wide variety of high quality Honeywell replacement parts for your Honeywell Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 22, 2016 | Honeywell Air Purifiers
Why is there delayed start & screeching?
The motor needs to be oiled. There are places to add oil on the ends of the motor. There may be a start capacitor that needs replaced too.
Jul 05, 2015 | Honeywell 17000 Air Purifier
My honeywell HFD-015C air purifier wont turn on
You may check to make sure that the power cord is correctly connected to the outlet. Test the outlet is functioning properly using another appliance or lamp. Also, check the fuse or circuit breaker. The outlet may be overloaded if other appliances are also in use. Establish and correct the cause of the overload. If none of these works, then there is something wrong with your purifier unit and contact the store where you purchase it or Honeywell for replacement. It is advised not attempt to repair the unit yourself.
You can purchase a wide variety of high-quality Honeywell replacement parts for your Honeywell air purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
May 31, 2014 | Honeywell 17000 Air Purifier
Honeywell 17000 Air Purifier manual
Please refer to the link below for the Honeywell 17000 online manual:
http://homeappliance.manualsonline.com/manuals/mfg/honeywell/portable_hepa_air_cleaners_17000.html
Ava B.
Feb 02, 2013 | Honeywell 17000 Air Purifier
WILL NOT START....NO POWER? BOUGHT AT SEAR JUNE OF 2010. HONEYWELL MODEL 17000
Mar 29, 2011 | Honeywell 17000 Air Purifier
I want to take the 17440 air purifier apart to see why it won't start.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 30, 2010 | Honeywell 17000 Air Purifier
Instruction manual for Honeywell air purifier 17352
Please refer to the link below for the Honeywell model series 17000 online manual:
Honeywell 17000S Owner Manual
Ava B.
Jun 25, 2010 | Honeywell 17352 Quiet Care Programmable...
Honeywell air purifier, will not turn on, obviously getting power. but pushing the buttons on the control panel does not result in the machine turning on. This is the 17000. Can anyone help?
Nov 25, 2009 | Honeywell 17000 Air Purifier
My honeywell air purifier is emmiting an awful
Mine quit too... The led screen went blank so I changed the battery. Now it does nothing. I totally disassembled it as the fan was turning stiffly.(should spin very easilly) The grease in the end bearing was stiff. I washed the gummy grease off the shaft and reoiled with synthetic oil. Your smell is probably motor windings overheating. I disassembled the electronic control and was disgusted to see that there is a glass fuse soldered to the circuit board. I believe the only reason for this fuse is to cause us consumers to needlessly replace otherwise good equipment. (It cost more to pay a repairman to replace the hidden fuse than to purchase a new unit)The fuse is not blown. At least this fuse actually looks lide a fuse unlife the stealth fuses most electronics have hidden in them. I can not obtain a wireing diagram on my 17005 unit but it has a black box inside behind the control panel. It looks like a small start capacitor, but it has a temp rating on it of 70*C. I suspicion it is a single use over heat safety which triggered when my motor got hot due to stiff bearings. I refuse to play their game and purchase a new air cleaner. I love this one... So, if I can not determine what that little black box is, I am going to bypass all the crappy electronics and just drill a hole on top by the handle and install a hi/lo/off manual switch directly to the motors wire hasness. This machine will never give me problems ever again, and if I oil the motor every couple of years with synthetic (Ander oil) this unit WILL last me for the rest of my life...
Oct 26, 2009 | Honeywell 17000 Air Purifier
Air Purifiers Logo
270 people viewed this question
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
