Question about ASUS Computers & Internet
Intel core 2 Quad Q 8400 and x64
Asus Mobo with this microprocessor runs now with W7 32 bits. Is it possible to run W7 64 bits with this configuration (Mobo + CPU). kind regards johan
  • ASUS Master
  • 5,660 Answers
Posted on Nov 27, 2012
Testimonial: "Halo joe, I have read the links. Even Virtual Machine Monitor is present and makes it possible for my config. to run W7 32 & 64 bits. Thanks a lot."
  • Johan Meijners Nov 27, 2012
    Halo joe, i have read the links. Even Virtual Machine Monitor makes it possible for my config. to run W7 32 & 64 bits. Thanks a lot.
  • joecoolvette
    joecoolvette Nov 27, 2012
    Hello Johan! Thanks for the rating! (Central USA)
3 Suggested Answers
Ryan5443
  • 336 Answers
SOURCE: Will this CPU be compatible with this MOBO?
Okay your Processor is not supported by your System Board. I will take some time and look to see what would be a good upgrade, but it may take a few days.
Ryan Frame
Creative Energy Associates Technical Center
Posted on Apr 27, 2009
jecboys
  • 35 Answers
SOURCE: with asus m4a785-m motherboard and amd phenom x4
Hmm, I've never seen a computer give a CPU fan error. Maybe if the fan is really dusty it's clogging it up, try getting some canned air and spraying it out.
Posted on Dec 17, 2010
Why is pcouffin device for amd 64 bit systems showing up on my ASUS Laptop running Windows 7 64-bit with an intel dual-core i5 chipset?
It is a low level driver for CD's and DVD's supplied as part of some softwares.
See this page for ore information.
What is Pcouffin
It is not a virus, but check the file sizes mentioned. The message is misleading as it means X64 systems, not just AMD.
Mar 18, 2015 | ASUS Computers & Internet
Which is the perfect OS x86 or x64 for intel core i3 cpu 530 @ 293 ghz
The i3 cpu is a 64 bit processor, therefore it will suit 64 bit Windows OS.
Jan 29, 2012 | Intel Core i3 530 293 GHz processor
I would to know if asus mother p5kpl am se iscompatible with window 7 ultimate 64 bits
yes it is. =) as long as your processor is compatible with windows 7 ultimate. this is the specs of your motherbard and I think it is pretty cool:
- Intel® Core™2 Extreme / Core™2 Duo Ready
- Intel® Quad-core CPU Ready
- Intel® 45nm CPU Ready
- G31+ICH7
- FSB 1333/1066/800MHz
- Dual-channel DDR2 800/667
- 4x SATA 3Gb/s
- Gb LAN
- 6-channel HD Audio
- EZ Flash2 & CrashFree BIOS3
please rate how this helped you.
May 26, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
Asus notebook windows 7 totally frozen..."not responding" Can't even exit without holding power off.
This is due to the fact that your ASUS Eee PC 701 PC does not offer minimum System requirements to run windows 7
Microsoft has published their minimum specifications for a system running Windows 7
as
  • 1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 GB RAM (32-bit) / 2 GB RAM (64-bit)
  • 16 GB available disk space (32-bit) / 20 GB (64-bit)
  • DirectX 9 graphics processor with WDDM 1.0 or higher driver
But I suggest following as min to run smoothly
  • A Dual Processor (AMD or Intel) – you can use a lower Celeron or Pentium Processor, but you will regret it
  • 2 GB RAM (operating memory) – you can use less, but you will regret it
  • 16 GB available disk space and another 20 to 30 GB if you plan on running applications
  • A Vista compatible graphics card (DirectX 9 graphics process with WDDM 1.0 or higher)
  • A Vista compatible sound card
  • Vista drivers for any other unique hardware you have on or connected to your computer
If this helps please do leave a vote and rate for the solution.
Feb 21, 2010 | ASUS Eee PC 701 Notebook
32 bit or 64 bit?
Here are the motherboard's processor specs >>>>
Intel Quad-core CPU Ready
LGA775 socket for Intel Core 2
Extreme / Core 2 Duo / Pentium D / Pentium 4 / Celeron D
Processors
Compatible with Intel 05B/05A/06 processors
Intel
Hyper-Threading Technology ready
64-Bit Processing Technology
Yes the motherboard can be used with a 32 bit or a 64 bit processor.
Regards..
Nov 13, 2009 | ASUS P5B-VM SE LGA775 Micro-ATX Intel...
I have a Question for upgrading my machine. I havent had the chance to dabble with Dual-Processors.... This will be my first time. Q: Is it possible to utilize a Xeon 2.66GHz x3330 Processor and a Pentium...
You can only mix the same family processors with different stepping and speed. Pentium D is not in the same family as a Xeon. So no, you can not. For as long as the processors are in the same family, you can mix dual core with quad core and even different speed.
Sep 02, 2009 | Intel Quad Core Xeon X3330, 2.66 GHz
E2180 Vs Athlon 64 X2 5000+
depends on what you plan to do with the cpu amd are good but a 3200 may only run @ 1.8 to 3.2 ghz depending while a intel 3200 will run 3.2 ghz.
I believe intel are more stable & run cooler than AMD but AMD benchmarks on Games better but run hotter (so get a good cooling fan & heatsink both pentium / celeron d & intel dou / dual core / core 2 dou and amd x2 have 2 cores (but watch your front side bus and cache the higher the better but the more $ also) then You need a good stable mobo that supports the chip you get (I preffer asus & msi for Gamers and biostar / msi for home users)
Sep 18, 2008 | AMD Athlon 64 X2 4600+, 2.4 GHz...
Cannot install vista - BSOD
the processor is core 2 quad 2.4 ghz, and as far as i know it does support 64 bt os. also bios is updated to latest from intel site using flash drive. but there were no mentions in the bios about using 32 or 64 bit os
Jul 20, 2008 | Intel DG31PR Motherboard
Raid sys on p5k/epu
You are correct. The Asus P5K does support SATA RAID configuration. Page 4-14 in the user manual.
Congifuration [Enhanced]. Only real option is IDE. That does not mean the SATA drives will run like an IDE. The SATA's will function faster. In order to get RAID function you would need to have bought the Asus P5K Deluxe. http://support.asus.com/download/download.aspx?modelname=P5K%20Deluxe/WiFi-AP&SLanguage=en-us
Mike
Jun 06, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Computers & Internet Logo
140 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
