Question about ADATA Classic Series C008 8 GB USB 2.0 Flash Drive AC008-8G-RKD Black
USB drive says "disk write protected" when formats.
Have tried almost each and every available solution in google but i couldn't format my pendrive. used "regedit" , format using safe mode, virus check , format using cmd ,HP format tool, sony format tool,active kill disk,and other available military grade format tools.none of it worked ... is there any chance to format my drive??
  • ADATA Master
  • 27,725 Answers
You have to be the computers Administrator to change any values on any Hard Drive on your computer.
Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control.
Click start click to open on my computer you should see your Usb drive E: or something
right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions.
Make sure all 3 boxes are ticked full control change and read in windows 7.
Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP.
Click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Click start click on my computer to open you should see your drive
right click then select format
another way
Click start control panel administrative tools computer management disk management
Right click on your usb drive select format.
If you need more help with this post a reply
Hope this helps.
Posted on Nov 27, 2012
fixyathing
  • 341 Answers
SOURCE: pendrive is not formateing
look for a write-protect switch or tab...also check the attribute of the file, check if it is read only...you need to remove the read-only if it is set. Usually doing a full format will erase it
Posted on Aug 16, 2009
laikexpert
  • 281 Answers
SOURCE: A-data usb flash drive(no disk)
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Feb 02, 2010
Crankstart
  • 696 Answers
SOURCE: i have a 4G Verbatim flash disk. I can't format it
Hello
There is a physical switch along the edge of the card which allows the card to be protected. If the switch is set to lock or protected then nothing you do in software will matter.
Take a good look at the label it should have a marking next to the switch. Once you change the switch position it should start working normally again.
Hope this helps FixYa,
Crankstart
Posted on Mar 28, 2010
SOURCE: PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
Posted on Apr 13, 2010
  • 547 Answers
SOURCE: Hi, I have this Verbatim
Do you have verbatim's "V-Key" driver for this flash drive?
If so, there's an option in that driver for "write-protect enable" and a checkbox for that option.
If not, and it's operating as a standard USB mass storage device, then you can try this registry change:
- Start > Run > type ‘regedit’ then hit 'OK'.
- Browse to the following key:
My Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
- Double click on the string ‘WriteProtect’ and change the ‘Value Data’ box to ‘0’
- You may also need to do this for the strings in any folders called ‘ControlSet***’ e.g.
My Computer\HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\StorageDevicePolicies
My Computer\HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Control\StorageDevicePolicies
etc.
Posted on Aug 02, 2010
My flash is write protected I can't format it
use hpusb utility to format your usb you can search it in google that was free
Mar 31, 2012 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My pendrive is write protected & first time copy
Dear User,
Please follow these steps.,
connect the pen drive, after autoruns,
please go to my computer-manage-disk management-
in this tab please find the usb pan drive as removable storage drive right click on the pan drive & format the same in the format option please tick the quick format wait for some seconds its format.
if format done, then no issue.................
but if no..............then try below steps.
go to start menu- click run-type "cmd", black screen spears, in that screen please type your pan drive drive name .i.e :-
G: and press enter,
now ur drive is open now please type "format G:" or whatever ur drive name..& again hit enter ur format done this is master formatting process...................if u like please don't forgot me............dear
Thanks,
Dhiren Motivaras
Sep 16, 2011 | Computers & Internet
I have a transcend 4GB pendrive. it has become write protected due to virus. how can i format it. i have tried many processes but can't get my pendrive formatted.pls help
Some usb keys or flash drives have a little switch thatlocks it & makes it read only. Try looking for something like this. Or youtry following these steps:
For USBdrives:
1. Open Start -> Run...
2. type diskmgmt.msc and press enter
3. right click on the partitin you want to format (where the leter and is)
4. select 'Delete Partition...' and confirm
5. right mose button in the same place and select 'Create partition'
6. select primary partition
6. select , file format, disk leter, label etc should be all right if youleave defaults.
7. click ok
This will recreat the partition and format it in proper way.
I hope this information will be helpful. Thank you for using FixYa!
Please vote if it helped you.
Jun 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I can't seem to remove write protection from this disk to format it. It is and 8gb usb device. It tells me it's write protected whenever I try to fix it.
Try with my property click here , choose download - and download winsetup from usb.
Try format with this software ,
if still error, contact me.I will help you my friend.
Jun 16, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Hi I have a transcend jetflash d33193 4Gb flash that won't format. It tells me the flash is write protected and i don't she any physical lock. i have tried every possible thing i know on it but it...
The message which you are facing while formatting your flash drive maybe be due to below reasons.
1) It could be due to virus. Try to scan your flash drive with your anti-virus and check.
2) Second reason would be when you connecting your flash drive it may include some autorun files which starts its own when you connect your flash drive and because that file is running it wont allow to be formatted, so try to delete all the files including in your flash drive and than try formatting.
or
There is right protect switch on many pen drives , a physical write protect switch which enables you to either allow writing on the disk or disallow writing on the disk.
All you need to do is toggle the right protect switch and you would be able to write files on your pen drive.
Please find an image below for more information.
Jun 08, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Cannot format flash drive.... receive message `disk is write protected`
Usually there is a small switch or colored slide which flips between write protected and writable. If there is no switch it may be the software that is on the drive is preventing the format, if this is the case you may need to use a boot disk like Hiren's boot Cd to format it while not booted into Windows.
Mar 15, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I have 1 gb iball usb flash drive & it is not formatting
Is there a write protect switch on the drive?
In Windows XP, right click on "My Computer", choose manage. Go to Disk Management and find the drive in question. right click on the drive for more formatting options.
Jun 21, 2009 | Computers & Internet
Windows was unable to complete the format
sir
u dont need to buy a new one. You can download file shredder from here . do following things :
  1. download and install file shredder
  2. shred all the files which are in pendrive(after shredding u will not be able to recover them)
  3. then try to format it .,
thankyou for using fixya
dont forget to rate the solution
have a nice day
Mar 12, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
ADATA Classic Series C008 8 GB USB 2.0 Flash Drive AC008-8G-RKD Black Logo
495 people viewed this question
Top ADATA Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
dmhandyman
Are you an ADATA Computer and Internet Expert? Answer questions, earn points and help others
