Question about RCA Televison & Video
I need the horizonal output transistor number for my P52810lv RCA tv
  • 26 Answers
Try this number 2SC5148
Posted on Nov 27, 2012
5 Suggested Answers
SOURCE: Disney DTD1363-car, Need part # of transistor
The tv keep shuting off an the dvd door won't open. I have model # DTD1363-CAR
Is there any recall on the tv
Posted on May 21, 2008
  • 280 Answers
SOURCE: sony 27s42 broke the horizontal output transistor
Be sure to make sure the connection on the horizontal driver transformer are soldered good. check caps around HOT
Posted on May 23, 2008
RALilja
  • 384 Answers
SOURCE: Rca 32v434T need part numbers
The H.O.T. Transistor number (original is 2SD3402 (which is no longer available)) it's replacement is the 2SC5902.
The H.O.T. Transformer part Number is RCA 271996
Posted on Feb 02, 2009
SOURCE: find a horizontal output transistor or flyback
Flyback transformer part number for a tv RCA F32648
Posted on Aug 30, 2010
RCA P52810LV wont turn on
If the set is dead, what to do with a reset? The power supply section circuit should be troubleshooted. Contact any experienced service technician.
Jun 11, 2012 | RCA P52810LV TV
I need to know the datasheet for the horizontal's transistor for a tv RCA 32F531T, because I lost the replacement
Hello
The number of horizontal output transistor is [TL 035]. If this number is not available, you can use exact substitute after reffering it to transistor data book and equivalents. OK.
Jun 03, 2011 | RCA 32F531T 32" TV
The picture is double or triple & it shuts offon its own. Make-rca Model-r56wh78 Serial#-g436cg038
It has a bad Electrolytic Capcitor near the horizonal output transistor. I can't recall the locater number but a good cap checker will find it.
Oct 09, 2010 | RCA Televison & Video
My RCA tv turned off in the middle of watching it and now it wont turn back on.red light comes on and tv makes clicking sound but no picture or sound.sounds like it turns off again.
Sounds like the Horizonal Output Transistor Shorted, Also on many RCA sets the Flyback Transformer is bad to go and short the HO Transistor
Find a horizontal output transistor or flyback
Mar 06, 2010 | RCA F32648 32" TV
Tv will not power on. Hear a high pitched sound
the horizonal output transistor is shorted-replace it also resolder coil near transistor-if output shorts again flyback transformer is bad
Sep 15, 2009 | RCA F36673ET 36" TV
No sound, No picture
The high voltage isn't firing up. Could be a number of things, but is most likely one of the following: Blown fuse, bad Voltage regulator, bad Horizonal output transistor, Bad solder joint(s) on any of the above.
Sometimes the whole power supply PC board can be replaced as one unit. There's Company called PTS Corp that rebuilds boards and will trade you for a price. They are very good at what they do. You would need the numbers off the existing board.
If you decide to look at it, please be careful. The high voltage can exceed 30,000 volts and capacitors in the set can hold a charge for days.
Hope that helps...
Geno
Mar 27, 2008 | RCA D52W15 TV
RCA F36650 36
Sounds like horizonal output transistor could be over heating. There could be other problems. But I would start there. You can find the part number on the schematic inside the set. If you change it yourself don't forget to use the included insulater. Part should cost between 15 & 20 dollars. You will need make & model # of set at electronic parts store.
Diagrahm inside set will show you location of transistor.
Jan 05, 2008 | Televison & Video
Oct 30, 2007 | RCA 32V550T 32" TV
Rca 2006 32v434t dead shorted out put
One special transistor is there. Before you change the transistor please sure that this is the first time problem or repeat H output TR failure. If it is first time means simply change the special type of transistor C5591. This is the high current rated tr and Panasonic is the manufacturer. Repeat H out failure means do the following simple works. If there is any capacitor between H sync output from Ic and horizontal drive transistor. Reduce the mf value and slightly increase flyback capacitor value. And then put the new horizontal output transistor.
Sep 06, 2007 | Proscan PS36800HR 36" TV
Televison & Video Logo
14 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
