Question about Saws
What size jigsaw blade to replace on durabuilt jigsaw
  • 211 Answers
SOURCE: cant change a blade on 500watt pendulum jigsaw fmtc500js
Hi
There is a click mechanism to replace the blade at the top of the blade.
best regards savumihai71
Posted on Feb 12, 2009
  • 10865 Answers
SOURCE: Milwaukee jigsaw with blade change problem
a new tool will cost you about 170. You could look for a used on on craigslist.
Posted on Apr 21, 2009
shameerariff
  • 89 Answers
SOURCE: Replace the blade on jigsaw Bosch # 1587 AVS item # 0 061 587 683
YOu can download the user manual in the following links
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00061v-1.pdf
https://www.boschtoolsservice.com/Order/IPL/IPLDetails.aspx?tn=0601587651&mn=1587AVS&init=1
The blade can be replaced by unscrewing the screw found on the shaft.
Posted on Jul 28, 2009
RonPark
  • 855 Answers
SOURCE: I need a replacement roller part for my Makita 4320 jigsaw
You can go to ToolPartsDirect.com or eReplacementParts.com
Both sites have a listing and a blow up diagram of your saw. So check there if the part is not on the diagram you may be able to call them and there may be a universal one or the right one available. They were the two most promising sites I could find.
Posted on Oct 23, 2009
Testimonial: "Thanks for the advice The only problem is they don't ship outside the US I'm in Australia"
ftw1952
  • 10319 Answers
SOURCE: I need a manuel for Bosch 1587 jigsaw
try freemanuals.com on the web
Posted on Mar 06, 2010
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: https://servicenet.dewalt.com/Home . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently https://servicenet.dewalt.com/Products/GetDocument?docName=402086-01,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
How to change blade on a Chicago jigsaw
Harbor Freight Chicago Electric Jig Saw - Review - YouTube
? 2:21
www.youtube.com/watch?v=lSh0M4WIJTk
Dec 13, 2013 - Uploaded by AdamDIY
Chicago Electric - Orbital Jigsaw 92772 They change the design over time but some of the key flaws tend to ...
jigsaw from hell - chicago (electric?) brand - DoItYourself.com ...
www.doityourself.com/.../445560-jigsaw-hell-chicago-electric-brand.ht...
Mar 9, 2011 - Most blades either have a hole in the shank or the shank is shaped like a .... A brand new one is only about $25 and no tools for blade changes.
Oct 22, 2015 | Saws
How to fit blade in performer 350w jigsaw
There is a blade release that you have to push up while inserting blade. If this isn't the problem, there are many types of blades for different jigsaws. You need the one for your brand. Take an old blade with you when you purchase. Good luck
Oct 18, 2014 | Saws
I need to use my late husband's jigsaw but can't get the old, bent blade out. How do I do it and which blade do I replace it with? I need to cut a few cms off the width of a kitchen worktop. I...
Hi Jen,
It depends on whether you have an older or newer model jigsaw. Bosch makes the newer ones with a button you push that will release the blade.
On an older jigsaw, look at the handle from above the jigsaw directly in line with the blade. You should see a screw in the top of the handle. Use a screwdriver and loosen this screw, don't remove it, and when the screw is loose enough, you'll be able to pull the blade out. When you put the new one in, slide it in the slot until it seats.
A rule of thumb is to use the blade with the wider gap and larger teeth on wood, the smaller teeth on metal. Most blades will say bimetal on the metal cutting blades.
Now, the courser the teeth the rougher cut you'll get. So, if you want a nice cut, don't use the blade with the largest teeth. Move down to the next largest.
I don't have a Bosch, so am not sure which codes are for which blades, but you can't go wrong if you go by the size of the teeth.
You didn't say what material the worktop is made of. If it's wood, the second largest toothed blade should be fine.
If you've never used a jigsaw before, I could suggest a couple tips that would help you get a nice job done.
First, put a piece of painters tape or masking tape over where you will cut, draw your line and go easy. The tape will keep the blade from giving you a roughed up top edge.
When you get near the end of the cut, hold a piece of scrap wood flat against the back edge to prevent tearout.
Also, let the saw do the work, don't push it.
Hope this helps, If it does, I'd appreciate a 4 thumbs up, Thanks,
Handie Andie, "woodworker by night"
May 24, 2011 | Bosch Garden
How do you put a new blade into a Black & Decker JS4000 Type 1 jigsaw
There is a black plastic switch where the blade is slid into the jigsaw. The black plastic switch can be seen and accessed from the front of the jigsaw through the clear plastic sight guide...You pull the black switch toward the bottom of the jigsaw and it opens the space for the blade to slide into, when you release the switch it will close the space and lock the blade into place.
Hope this helps.
Mar 06, 2011 | Garden
Cannot remove blade as do not hve manual 4350FCT makita jig saw
Hello Aiden,
This Makita jigsaw does not use any set screw fasteners to secure the blade in the saw. It has a "tool-less" blade retainer, so all you need to do to remove (or install) the blades, is to twist the small knurled ring nearest the blade shank.
Be sure to unplug the jigsaw first and with the blade shaft fully away extended from the saw, (you can just pull it out by hand if needed) and then simply twist the round locking ring and then with your other hand, pull the blade out of the jigsaw.
I would suggest that you use a glove on the hand you're going to pull the blade out of the jigsaw with, as those blades can be very sharp with the jagged cutting edges, etc.
Here's a parts breakdown of the jigsaw, for your reference and for obtaining any replacement parts you might need in the future.
http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_4350FCT.pdf
Makita doesn't have an owner's manual listed on their web site for this product. You will need to contact Makita directly to obtain a free replacement manual for your product. You can contact them at
1-800- 4MAKITA (462-5482) Hours: Monday through Friday 8am - 6pm (EST)
I hope you find this Very Helpful and best regards!
Dec 23, 2009 | Makita 4350FCT Top Handle Jig Saw w/...
Cannot see how to fit blade on Powerbase jigsaw with screws at front - recess does not seem big enough to contain blade provided.
Plate can be lifted up with end of blade to reveal nevessary size of opening. Blade can then be inserted and tightened satisfactorally.
Dec 15, 2009 | Saws
Makita 4304T. jigsaw blade Do not know how to fasten it?
On the top of the Makita 4304T is a knob, (Top/Front)
This is the blade Installing Lever.
Viewing the jigsaw in the direction you would use it, the Installing Lever is turned towards the Right. Keeping it turned, you then install the jigsaw blade. Once you have the blade up in the Blade Holder, gently release the Installing Lever.
This is a PDF file of the Owners Manual for the Makita 4304T Jigsaw,
(From Makita - Products - Support)
http://www.makita.com/en-us/Assets/images/Products/4304T/owners_manuals/4304T.pdf
[Should the above direct link not work for you, this is Makita - Products -Support, and the download page,
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=248
Left-click on Owners Manual next to the PDF file Icon]
Nov 04, 2009 | Makita Jigsaw Blade
Blade wander
a jigsaw is for cutting wavy lines if u want a straight cut use a rip saw with fine blade but you still can use a jigsaw must have sharp blade there is a blade u can get now from screwfix with a triangle spine on the back off the blade to prevent it twisting works fine (also do not push hard on the powertool let the blade do the cutting less likely to wander hope this is of help
May 30, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Saws Logo
116 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
