Question about Brother XL-2230 Mechanical Sewing Machine
Machine makes an angry noise - stops moving.
This happens at random when Im sewing but it's becoming more frequent. The tension on top gets very tight and as its in the middle of having the spasm, I've noticed that the tension on top at the base of the thread does like a backfire.
The bobbin tension seems fine and I can wind the thread back on both the top thread and the bobbin. If I just try to keep going manually or by pedal it creates a cluster of crazy thread underneath the fabric.
I've tried adjusting the tension as this worked on my old singer machine but this doesn't seem to be working.
Ive also moved the **** thread from around the bobbin area and it's clean.
Please advise.
THANKS!
SOURCE: brother sewing machine ls2125
HELP, I can't figure out how to thread the bobbin on my Brother LS2125?  Thanks
Posted on Aug 12, 2008
SOURCE: Brother Industrial Machine Tension
This is an answer to another person with a similar complaint. Try the suggestion below, it may fix the problem.
From your description it appears that you have tried tension settings on the upper tension control adjustment knob without success.
Check that the bobin tension is adjusted correctly by taking out the bobin complete with the spool.
Pull the cotton thread and it should be a smooth light pressure if the tension is correct. If it is tight to pull or pulls freely then adjust the tension screw which is found on the outside of the bobbin. The screw is very small and requires a minature size screwdriver. The adjustment will only be a slight turn of the screw one way or the other to obtain the correct tension(depending if it was loose or tight).
Once this is set reinstall the bobin and tread up the machine, hopefully with the upper tension set at approx."2" the machine will sew correctly.
Posted on Nov 30, 2008
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
SOURCE: Sewing machine bobbin thread issues
i dont found the bobine
Posted on Nov 22, 2009
  • 1788 Answers
SOURCE: My brother LS-1520 sewing machine is having major tension problem
Try some metal bobbins, #15 or SA 156. that seems to help. If, you don't have a manual go to brother.com and download one for free
Posted on Jul 27, 2010
Moved my tension button and not sure what to set it on, sewing polycotton curtains
uually your tension should be set between 4and 5 this is a good tension for most fabric
Dec 27, 2017 | Sewing Machines
I have a Bernina 350 SE. Trouble with buttonholes: thread accumulates in lumps intermittently. Stitches become very small, fabric stops advancing, thread piles up.
Have you tried re-threading the top thread? Sometimes the stitches get small and pull tightly because the thread is looped around a guide or the thread spool. Just a thought as that happens frequently with my machine.
Oct 19, 2017 | Bernina Sewing Machines
My sewing machine makes loose threads under the cloth
It is your top thread tension causing the thread on the bottom of the cloth to be loose. Make sure your machine is threaded properly and the thread is seated correctly between tension discs.
Make small adjustments and do a test on scrap fabric until the stitches are tight.
Jul 12, 2017 | Sewing Machines
Why does it make a knocking noise as it sews?
the needle position is up tight in the holder and no where else
the cut away bit of the needle faces the bobbin case hook and the groove in the needle faces the end of the machine and gives clearance for the thread to pass through the material
from your description and what you did, the needle /hook timing needs adjusting as it is out
turn the machine over by hand as in sewing and watch the position of the eye of the needle and the bobbin case hook
just as the needle starts to move up, the hook should be just above the eye of the needle at the edge of the needle
The adjustment is by loosing off the screw on the vertical shaft at the end of the machine that is attached to an arm that moves the needle up and down and move that bit up or down until the needle is positioned correctly to the hook
tighten up the screw
next is to check the needle tension is not too tight
workshop manuals are available on line in pdf version or take it to a sewing machine repair shop for a proper diagnosis
May 12, 2016 | Singer Stylist 7258 Electric Sewing...
I have a singer advance and the thread from the top starts out sewing correctly but within a short time becomes too tight and snaps what is the problem
Try to go for a regular maintenance. Here i have added a video which will help you to carry out the maintenance process. Hope after that you problem will be solved.
SINGER Sewing Machine Maintenance Troubleshooting
www.electro-medical.blogspot.com
Oct 06, 2015 | Singer Sewing Machines
On my bobbin side of the materal after i sew its just tons of thread on that side and the stitch is not tight
Loose on bottom indicates trouble with top tension. Re thread your machine with the presser foot UP. sew a test seam. If you still have problems adjust the top tension. sew a test seam. If you still have problems clean between the tension discs with some sturdy fabric and unwaxed dental floss. Sew another test seam.
Still problems? Wind the top tension tight then back off 1/4 turns until the seam is balanced.
Aug 16, 2012 | Janome Sewing Machines
The machine won' tsew as if the tension is too tight any ideas?
try rethreading the machine top thread & bobbin
try a tension of 3 or 4
make sure the thread move smoothly around the tension disks
make sure before threading the needle that the thread pulls smoothly
Nov 17, 2010 | Brother XL-5130 Mechanical Sewing Machine
JONES SEWING MACHINE PROBLEMS
We have a very old Jones Sewing Machine (1960's) we are having trouble with the thread at the moment. When we sew the thread gathers up underneath the material that we are trying to sew. Any suggestions to overcome this problem?
Feb 21, 2009 | Sewing Machines
Machine tension knob does not work.
Use a better quality thread. Sometime old or cheap thread never works right. Check to make sure you have the right needle for your fabric.
Dec 07, 2006 | Necchi 3537 Mechanical Sewing Machine
Brother XL-2230 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
