Question about Craftsman Sears 16" Chain Saw Bar
How to replace FUEL LINES on a sears craftsman chainsaw
Puttin gas lines back on chainsaw that someone else took off. need to know how they go back from the tank to the carb to the bubble
#1 Taper
  • 1040 Answers
SOURCE: need diagram on fuel lines on a 26 cc craftsman weed eater
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jun 16, 2009
#1 Taper
  • 1040 Answers
SOURCE: craftsman 28cc gas weedeater gas line connections
Jim
Posted on Jul 03, 2009
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
rycgl
  • 1545 Answers
SOURCE: Craftsman 32cc Weedeater -- need fuel line diagram
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
Posted on Jun 01, 2010
panilling9
  • 284 Answers
SOURCE: Which fuel line "port/inlet" on the Walbro wt-380
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Posted on Jun 25, 2010
How do i replace fuel lines?
Where do the fuel and primer lines go in Craftsman or Poulan Chainsaw
Hope this helps. Also try to avoid using gasoline with ethanol. This causes the lines to deteriate.
Apr 30, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Where to place fuel lines on a craftsman chainsaw model 358.352161?
http://www.ereplacementparts.com/craftsman-358352161-gas-chainsaw-parts-c-158286_172209_172289.html
The above link will take you to www.ereplacementparts.com
They sell all of the parts for your saw. There is also an exploded diagram. I am not sure if it will help you, but it may.
The other place I would try is YouTube. There are many videos on chainsaws.
I hope this helps and god luck with your saw.
Jul 09, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need to replace fuel lines that is rotten
Hi randy waldrop...
Here is the fuel routing for chain saws
Please rate me
Bud
Sep 29, 2012 | Craftsman Sears Chain Saw Manuals Model...
Craftsman 18" chainsaw runs but dies when I press the throttle, new carb and fuel lines low and high speed set at 1 turn .
remove the muffler and run it after seeing that it runs good open the muffler and clean the screen inside
Sep 27, 2012 | Craftsman sears 18" Chain Saw Chain (...
I have a Craftsman 2.5 Turbo 18" chainsaw. Yesterday it would start and run briefly and the die. I changed the sparkplug and cleaned the air filter and now the saw will not start. The plug is...
Seeing a lot of fuel line problems due to ethanol. Make sure your fuel lines and primer lines are in tact. If the fuel line has broken, you may also need to clean out the inlet screen in the carburetor which can also become clogged.
Feb 12, 2011 | Craftsman sears 18" Chain Saw Chain (...
Fuel Lines - 25cc Craftman weedwacker
Your Craftsman Trimmer/weedwacker:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=358795591+&pathTaken=partSearch
Best Poulan Engine Match (probably real manufacturer):
http://www.ordertree.com/modelinfo/PWE/BC2400-Gas-Trimmer-Type-6/75.BC2400-Gas-Trimmer-Type-6.1.59.1.html
My decisions are being driven by my experience with Poulan chainsaws. Small hose in tank (long enough to reach all corners), filter on bottom, connects to lowest connection on carburetor. Small hose on upper carburetor connection to small fitting on primer. Large hose from large connection on primer through largest tank hole, roughly mid tank long. nothing on bottom. I suggest you leave the 2 connections on the carburetor long enough they can be swapped (just in case) then try it. if no go swap them.
Typical fuel system and a suggestion or two:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
This is how I would configure it if a chainsaw, doubtful they would do something completely different. In defense of Jerry, he knows how it should be done, clarity of instruction could use some help. Good Luck. HTH
Lou
Feb 24, 2010 | Craftsman 25cc Gas Line Trimmer
Sears model 358.356280 chainsaw. Just replaced
Sounds like you need to pull out the spark plug and put some fuel directly into the cylinder to get it fired up.
Nov 14, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Feb 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Craftsman Sears  16" Chain Saw Bar Logo
137 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
