Mounted room aire cond. ASW-H12A - Heating & Cooling
3 Suggested Answers
  • 233 Answers
SOURCE: Kenmore room air cond fan runs, no cool. checked
if the fan motor is on but the compressor is not : if the compressor has correct voltage up to the terminals and is not operating, the compressor is bad, if ther is not power to the terminals, the start components may be the culprit, if there is no power to the start componenets then the controller is the issue.
Posted on Jul 19, 2009
heatman101
  • 43501 Answers
SOURCE: I have a 1.5 hp kelvinator wall mounted air
The best button to push for that is the cool button, then turn the thermostat all the way to cold.
The fan button will only move air around and will do no cooling.
The dry button is for dehumidification, in this mode the unit will run a low speed fan over the cooling coil to take the water out of the air.
So for cooling your best option is to push the cool button and crank down the thermostat...
Heatman101
Posted on Jan 11, 2010
When I press the control to get the air temp down to 60 it goes back to 86 right away , How can I fix it ? I have a Haire portablr air cond 7000 btu model hprbo7xc7
most air conditioning unit have a built in thermometer so that it will tell you the room temp,if you set the temp and then it goes to a high number let the system rum for a while and see if the temp starts to go down in the room it is probably working fine.
Jul 21, 2011 | Haier Heating & Cooling
I want to make the air cond. get cooler. I want to cool fruit in this room. Can it be done. Maybe override the therm.?
To cool fruit ect you need something much more than a window unit air conditioner, they just don't have the cooling capacity to do that job. You need a walk in cooler to cool food down.
Jun 19, 2011 | Maytag M6Q10F2A Air Conditioner
I have a narrow window. Can an air cond. window unit be put in sideways? panzer12@juno.com
Hello, unfortunatly itncannot be put in sideways because for one it would not cool the room and second it would be very ineficiant.
Jun 08, 2011 | Kenmore Heating & Cooling
I have a 1.5 hp kelvinator wall mounted air cond.It has three button (cool,fan,and dry)If I want to get the room really cold what is the best button to push
Heatman101
Jan 11, 2010 | Heating & Cooling
Jul 18, 2009 | Kenmore 75123 Wall/Window Air Conditioner
Re: air cond. should exhaust lever be open or closed to cool off?
Im not sure what type of unit you are speaking about but in general a window airconditioner unit will have an exhaust button. This button generally opens a small door that allows a small ammount of fresh air to mix with the conditioned air from the room. When it is closed all of the air is recycled from the room. To cool a room fastest, close the outside air inlet.
Jun 21, 2009 | Heating & Cooling
V- lec MODEL ASW-H18A4/HSA air conditioner compressor cuts out.
If you get the numbers off the board give this web site a try. I live in the city they have shop in and they are very good.
http://www.wsconet.com/
Jan 27, 2009 | Heating & Cooling
Idle
Does the engine stall? if not the motor mount is the issue, it is allowing engine vibration to be sent along the frame to the driver, the mounts have 2 functions, the 1st is of course to hold the engine in place, the 2nd is to isolate the vibration from the driver, engines vibrate allot, but if all the mounts are good you seldom feel it.
Sep 08, 2008 | 1999 Suzuki Vitara
We bought a 8000btu air cond and used it last summer. It is in a room 16X20. It has never seemed to blow cold enough air and will not keepthe room cool enough. I,m wondering if there is a service depot...
The A/C is small for the application. If there is any sun shining into the room it will add heat. If the room is open to other rooms the square footage it is cooling will multiply in proportion. Using a thermometer check the temperature of the air going into it and the temperature coming off of it out the grills. If the difference in temperature is 20°F or greater it is doing the job it was designed to do. If you shut it off when you leave and turn it on after the day heat has built up it will not seem to overcome it.
May 22, 2008 | Maytag Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
