Question about LG 50PC1DR 50 in. Plasma HDTV
I was replacing caps and thought I looked at all of them and thought they were all the same but one is a different value. I need to know if anyone has anyway of helping with this.
I removed 9 capacitors on the power board. When I looked at them before hand they all looked like 3300uF 10V caps but one of them was actually a 680uF 50V cap. I found a schematic online but the cap they had listed with the locations were completely wrong.
JBL sub PSW-D110 hums, and the fuse is blown
here is the manual, I am looking for a more detailed version
Mar 25, 2008 | JBL PSW-D110 Speaker
What capacitors do I need to purchase to replace these blown ones in this avol tv?
U have caps in these sets all over the place - all different values and voltages.
Limit yourself to the caps in the power supply for time being. Look for leaky or bulging caps and replace those first. If that does not do it then you have no recourse other than to remove the caps and test each one with a cap tester. Those things can go with no noise or overt signs that they have gone bad.
Sep 18, 2015 | Televison & Video
ECS GeForce 9800 GTS+ Burn out of one small capacitor/diode as it not fully readable, it looks like C23, C25, C26, C28 (suspect C26). Need to know if its repairable or throw away? Is there a repairer...
If it's within warranty, I would contact the manufacturer to see if they'll repair it. Taking it to a repair shop would likely void the warranty.
Mar 14, 2011 | Computers & Internet
Mlt070a power supply (polaroid 373b)
Mine are 100ufd 450volt 105C capacitors.
Hope this helps,
Mark
Jul 31, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Can someone tell me the values of the capacitors ?
EC18, EC19, EC20 are 1000uf/16v 105c
never had to replace EC9 and EC10 but should by the same value look at the size if the same as EC18 - EC20 I would go with the same value. It should be printed on the caps. If that did not fix your dead unit replace the power supply board and same time.
Check for the parts here:
http://www.mcmelectronics.com
# NOTE - If this info was helpful to anyone please click on yes!
Jun 23, 2009 | Akai LCT2721AD 27 in. LCD Television
Internal battery in Sony VCR.
These units use a large valued capacitor rather than a battery. If memory serves me corectly, on these units the cap is located on the front panel board. It is usually either a 1 farad cap or a 2.2 farad cap at 3V.
Dan
Feb 22, 2009 | Sony Televison & Video
Replacement Caps for Power board WD-52525
You can check out www.tritronicsinc.com just look for correct values VOLTAGE, VALUE, TEMP 100C or call 800-638-3328
Dec 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
PDP4294 PowerSupply Components
Any manufactures cap will do, www.jameco.com and www.digikey.com have a great supply of caps. Just make sure that the uf and volts match up and you will be fine.
Apr 21, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Dm board mit wd52525
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Sep 28, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Open Questions:
See all LG 50PC1DR 50 in. Plasma HDTV Questions
LG 50PC1DR 50 in. Plasma HDTV Logo
43 people viewed this question
Computer Repairing
Computer Repairing
