Question about Behringer Pmp3000 16 Channel Audio Mixer
Output one of the speaker outputs not working
    Problem Solver:
  • 9 Answers
Often this is because the amp mode is set to "Main L + Main R" and not set to "Bridge" mode.
Posted on May 28, 2009
I have xr 1220 an no sound output?mixer is working but no sound output to the speakers.
If there's a cue output on the unit, use this to make sure it's actually outputting a signal.
Just put some headphones in the cue port and see if there's anything.
If there is, it may be a problem with your speakers or how you've connected it to your speakers.
If all else fails, it'll be your output board in the mixer that's the issue.
Good luck & have a great day! :)
Jul 12, 2017 | The Music
I'm using the Peavey XR 8600 with two EV Force i 25 speakers. My question is this, what is the difference between the two outputs on the Peavey? I naturally assumed one was left and one was right....
DO NOT parallel more than two 8 ohm speakers on either output and you will be OK. You could also use one speaker on each output. That would be easier on the equipment as it would be an 8 ohm load on each instead of a 4 ohm load on one of the internal amps. If you want to drive stage minitors, then you existing setup is fine and you will connect the monitors to the second speaker output and set the Mon switch as MAIN/MON.
Aug 23, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Aux1 and 2 are not working...what is the fix on the emx5016cf yamaha board
You are NOT trying to drive speakers from the aux outputs are you? These are LINE outputs that should be using TRS balanced lines to either powered speakers or amplifiers. Often these are used for monitors. The monitoors MUST be powered versions or use external amplifier if the speakers are passive..
Apr 26, 2011 | Yamaha Emx 5016cf 16 Ch 2x500w Powerd...
I have a budda superdrive 30 II amp and have a setting question. I made a 2-12 cabinet to hook to this amp. Each speaker is 4 ohms. They are wired to their own output jack. My amp has 2 outputs for...
You best rewire the cabinet to put the two speakers in series. Wire one speaker plus to minus of the other and bring the other lead, one from each speaker to your jack on the cabinet. The amp output impedance is what is set on the switch... for two 8 ohm speakers you would use both jacks to the two speakers BUT ssince you have 4 ohm speakers the ONLY option is for two in series and set the switch to 8 ohms. The amp is ONLY 30 Watts so don't expect too much sound output... You should get a nice CLEAN sound at a reasonable level. If you drive the amp too hard it will clip and you will get garbage.
Apr 22, 2011 | Budda Superdrive 30 Series II Amp Combo
Hey, i bought a new pair of samson auro D415 speakers and i connect them in parallel because one of my main mixer outputs ain't working.but even if al my signal gains and fader levels are low,the peak...
Check only one active speaker at the mixer output and report the results.
Connect only one of the audio inputs from the power amp at the mixer output (and the passive speakers at the output) and report the results.
Sometimes (in parallel connections) there are interferences from the volume controls.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 30, 2011 | Samson Auro D415 - 2-Way Active Speaker...
I Have a Peavey XR 600B mixer. There are only 2 inputs in the rear for speakers. I want to add more speakers to be used as monitors or just have extra speakers. How can this be done? I only have...
First off it's outputs to your speakers. If you had an extra set of powered or amplified speakers you could "Y" cable your speaker outputs. Your passive speakers won't work without an amp. You really need powered speakers or an amp for your extra speakers. (if you had powered/amp'd speakers you could run them off one of you "aux" out for monitors. Do not daisy chain your speakers connecting twi together, you'll change the resistance/ohms and damage your speakers. Trust me, I do this for a living.
Mar 06, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
My amp has output but no sound from the speaker.
If you have tested with other speakers, you may have blown the ones that are not working. Test the speaker(s) on another source. I am not sure how you have tested your amp that it "has output"... indicators mean NOTHING on the amps as far as actual power going out.
Jan 29, 2011 | Hartke Ha2500 250watt Bass Amplifier Head
Marshall MG100HDFX 100-Watt Amplifier Head. The head phone jack works but speaker output is dead. Hooked it to speakers with another amp input and after word it stopped working. Can't see any overheated...
You'll have to take it in to get it repaired. From what you described it sounds like you blew the output stage out. You can't run from your speaker output jack into the input jack of another amp. You should go out of the recording out, line out, effects out or in the least case your headphone out. What happens usually is your output transformer short circuits due to a mismatch of impedances. It sounds like you still have a transformer though so you might have gotten lucky. You will need to take it in though. Sorry.
Nov 26, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Behringer Pmp3000 16 Channel Audio Mixer Logo
122 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
