SOURCE: Trying to determine year of a specific Schwinn Panther bicycle.
1949 is the year of this serial number
Look at this website to verify my findings
http://www.re-cycle.com/history/Schwinn/SwnB_Serial.aspx
Testimonial: "Thank you very much for taking the time to research and find the information in regard to my wife's bicycle. You have been extremely helpful. Ron"
SOURCE: Front wheel touches the frame and touches the pedals when I turn.
the front forks as facing the wrong way, loosen the handle bar head stem and turn the wheel and forks 1180 degrees
Testimonial: "Thanks! It works now."
SOURCE: cna't remove front wheel from my giant cypress bicycle
your wheel is either held on by a nut on either side of the fork or a quick release. In the case of the nut, you simply loosen both sides using a wrench and then the wheel will come off (the axle may have rusted to the fork so you may need to "persuade" it a bit with a rubber mallet). If you have a quick release, you unlock the release lever by pulling it towards you...you may also need to then unscrew the nut on the other side before the wheel will release.
