Question about Frigidaire Washing Machines
Its not the water heater that leaks its the frigidaire washingmachine
Model fwx233re54. the pump itself works fine , it just leaks from arroun the pump
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
You will need to replace the pump. Here is the part to order.
Posted on Nov 27, 2012
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Door leak in Kenmore Front Load Washer model # 110.4646
It appears your lid switch/door latch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
nanbuenbrazo
  • 553 Answers
SOURCE: Frigidaire Washer Model #WILL-1 - won't spin or pump out water
Can you access the location of you motor?
try to open the back and unscrew the cover and see if you can see the motor, try to start it but don't get near to much just enought to see if it is moving or not.
if it still running and rotating see the belt maybe it is too loose or maybe it is to tight,
But if it just humming, turn it off and unplug, see if you can rotate the motor with your hand, if you can then you'll need a starting capacitor, you got to buy one and install.
But if it is hard to turn even without a load, then you'll need to bring your motor to a service center to check for the bushing and shafting and lubrication.
your motor winding is still ok since you heard a humming sound, that problem would be the mechanical part.
Posted on Nov 06, 2009
Leaking anti freeze from water pump screw
Most water pumps have a weep hole that leaks when the pump seal is broken. Usually indicates the water pump needs replaced.
Mar 01, 2014 | Dodge Shadow Cars & Trucks
Frigidaire gallery series Model GLGH42FS1 stackable washer leaking
see this causes and fix it. God bless you
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is down under neath. To disassemble your washer follow the appropiate tutorial. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Tub Seal
This is in the center of the tub. The seal is inexpensive but will require some labor to install. Check the tutorials on disassembling the cabinet then remove the agitater and inner tub. Enter your model # above for a diagram or illustration.
Oct 11, 2012 | Frigidaire Washing Machines
My washingmachine started to beep and FH showed up on the screen. What does FH stand for?
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hose, it may be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Feb 16, 2011 | Whirlpool Washing Machines
HAVE FLUSHED THE SYSTEM AND INSTALLED A NEW THERMOSTAT. BLOWER WORKS FINE BUT VERY LITTLE HEAT. COOLANT LEVEL APPROPRIATE.
check water pump working and no leaks..might be vacuum line not opening the flapper door or heater core, or heater control valve
Jan 20, 2011 | 1989 Buick Century
The clean light won't go off on my Frigidaire 1000 series dishwasher and the only way to make it run or work or do anything is to reset the breaker. I have tried everything. PLEASE help
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Nov 27, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
I noticed that my the spa water level got really low. My pool pump is has stopped working. The breaker was tripped and I reset and it tripped again. Is the pump fried?
Probably the heater. Turn the heat off and try it. There should be a flow switch to prove pump is on before the heater works, but sometimes if you're running low, it will work intermittent. Do you know how it got low? evaporation? Is the pump leaking? If the pump is leaking, and has leaked for awhile it may have shorted out the motor. While running the pump low on water will damage the mechanical seal that keeps the water in the pump, it should not affect the motor itself.
Oct 19, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Replaced heater failed within 2 months
If your filter is plugged causes the heater to work harder(overheat). Rus
Mar 17, 2010 | Heating & Cooling
I have a 92 mazda mx3 that i just replaced my water pump on and we thought my radiator was leaking so we put radiator stop leak in and right after that my heater stopped working the heater was working fine...
the stop leak has clogged your heater core. you may be able to flush it out if there is still some flow, otherwise heater core will need to come out.
Jan 02, 2010 | 1992 Mazda MX-3
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Apr 23, 2009 | Frigidaire ATF6000ES Front Load Washer
98 dodge ram overheating with no heat
Did you have your heater running when you refilled coolant after water pump changed?
Jan 20, 2009 | 1998 Dodge Ram 1500 4WD
Washing Machines Logo
48 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
