How do i clean the filter on a hotpoint aquarius WDL 5490?
Where is the filter on a Hotpoint Aquarius WDL 5490 and how do i clean it or change it?
barkencoa
  • 3463 Answers
SOURCE: where is the filter on
If you remove the lower rear panel, you will see a large black hose fastened to the bottom of the tub, remove hose from tub and you will find filter in there..
Be careful as there will be water in there.
Plz rate this solution.
Thanks.
Posted on Dec 15, 2008
  • 1462 Answers
SOURCE: Hotpoint Aquarius WD440 Washer/Dryer
remove bottom rear panel. you will see a large diameter hose going from tub to pump. undo this hose at the tub end - lots of water will come out. filter is inside this hose. remove and clean
Posted on Jul 17, 2008
barkencoa
  • 3463 Answers
SOURCE: does machine have a filter
The filter is to be found at the rear of the washer.
Remove lower rear panel of washer, remove large black hose fastened to bottom of tub.
Watch out for water running out.
Remove plastic`filter inside hose and clean.
Refit filter and hose.
Dirty washing can somtimes be attributed to washing at too low a temperature, so make sure you have selected right temp for washing.
Please leave a fixya rating for my solution.Thanks.
Posted on Feb 08, 2009
  • 89 Answers
SOURCE: Where is the filter on the Hotpoint Aquarius
Filtet access at the rear of the machine behind access panel, Remeber to remove the plug from the socket before removing the rear panel
Posted on Jun 10, 2009
barkencoa
  • 3463 Answers
SOURCE: where is the filter on hotpoint aquarius extra
Remove lower rear cover of washer, you should see a large black hose attached to bottom of drum.
Remove hose and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Posted on Sep 11, 2009
Changing filter
Where is filter on Hotpoint Aquarius WD420
Oct 14, 2012 | Hotpoint Aquarius WD640 Front Load...
The tumble dryer on my hotpoint WDL 540 is not getting warm. I assume it's the heating element, but would be grateful for advice if it could be anything else or how easy it is to fit a new...
hello i'd check the heat sensors first there may be 2 of them you will need a multimeter to test them if 1 is faulty change both of them hope it helps
regards
shaun
Mar 11, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius extra 1000 spin washing but when spinning, clothes coming out still soaking wet. Help!
Check the machine filter, clean it and this problem might go away. Use manual for locating the filter.
Feb 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Where do I find the filter on my Hotpoint Aquarius WM22? Or does it not have one?
Both the Hotpoint WD63 (wash dryer) and the Hotpoint WM22 (washing machine) have a drain filter in the sump hose at the bottom of the tank.
This filter is a last line protection for the pump and is not designed to be cleaned on regular intervals by the user.
Jan 31, 2011 | Hotpoint Aquarius WD63 Front Load...
Could you please tell me where i can find the filters on the hotpoint aquarius extra WD63? Thank you
Remove rear panel completely from washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose.
Oct 21, 2010 | Hotpoint Aquarius WD63 Front Load...
Where is the filter located on a Hotpoint Aquarius WM63 washing machine?
Remove lower rear panel of washer.
Locate and remove the large black hose from bottom of drum, remove and clean the filter inside the hose.
Oct 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Where is the filter on hotpoint aquarius extra wwm39
Thanks.
Sep 11, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius extra filter
Normally in front of machine.Remove down plastic cover and then you see pump/filter,open and clean and make sure pump rotor is free to run.Jan
Feb 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Jul 17, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
315 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
