Question about Creative Labs Sound Blaster Live! 24-bit External External Sound System
I have newly installed creative sound blaster USB - bought it so that i can use it to record karaoke -for which stereo mix recording mode needs to be enabled.But am seeing only 2 modes for SB ; line-in & Wave/MIDI/CD - am able to record either mic output or playback - not both. The purchase is totally useless for me if i cant fix this. Pl help.
  • nairsradhika Jan 10, 2009
    Can you pl elaborate? What is auto soft?
    Sergeant:
  • 431 Answers
Use auto soft to solve this
Posted on Jan 10, 2009
Can not record with mic
For using the mic in karaoke you should mute the mic playback in windows mixer
Jul 06, 2009 | Creative Labs Sound Blaster Live! 24-bit...
Having problems recording and playing back tascam dc-02 cf
I'm assuming you are plugging the left and right outputs from the karaoke machine into input A and B of the Tascam to record the stereo output of the Karioke. The Tascam works with mono only (you recreate the stereo mix at mixdown or when bouncing mono tracks together with the panning set). Therefore you should be assigning inputs A and B separately. You could press assign A and then the record button above track 1 and then press assign B and the record button above track 2. Then arm tracks 1 and 2 (by pressing record above each). When you then press play and record together you'll record input A onto track 1 and input B onto track 2.
Hope this helps.
bd.
Mar 25, 2009 | Tascam 2488 Portastudio Multitrack...
Static feedback on microphone problem
replace the jacks
earth or insulation or shielding problem on the cables
Mar 22, 2017 | Panasonic Computers & Internet
Creative sound blaster live 24 bit soundcard external usb
Explanaition:
This delay you are experiencing is called latency. All equipment or signal processing unit introduces some latency even if extremely low.
Computer tends to be a lot worse than outboard gear.
Solution:
Look for Asio4All, this little driver will help you improve your audio input latency. And remember, the smaller the buffer size the lower latency you get.
http://www.asio4all.com/
Jan 23, 2009 | Creative Labs Sound Blaster Live! 24-bit...
Unable to use Stereo mix recording mode
This is a block at the sound card drivers, most vendors have removed the mixer option on the drivers causing this issue. Contact creative and ask them for a patch or fix to resolve this issue. Your system and card is working as designed with the provided driver / software.
Jan 10, 2009 | Creative Labs Computers & Internet
USB Audio Recording
well its midi keybord u will need sum hi tech gear here mini box usb for your pc to get controller keybord in it thats if it has midi outs most better hi end models all have midi out need to go to guitar center buy usb interface for pc recording ok to put in midi devices ok now if u wanna get crazy u can us eyour headphone out to eth in mini jack into your sound card in but most sound cards dont have software to record only x fi sound blaster higher end models will creative recorder program u can use that to record what u here from aux in jack save as hi end mp3 then drag drop to nero to burn a cd ok got all that
Dec 05, 2007 | Ahead Software Nero 6.0 (60045) for PC
Sound Blaster 5Live .1
Download the driver again. Try the creative labs web site or go to http://www.driversguide.com/
Dec 02, 2007 | Creative Labs Sound Blaster Live! 5.1...
Soundcard
This Sound Blaster X-Fi Vista Installation CD is intended to support X-Fi products bought before a Vista installation CD was available in the box.
It supports the following models:
  • SB X-Fi Xtreme Music (SB0460)
  • SB X-Fi Xtreme Gamer (SB0730/SB073A)
  • SB X-Fi Xtreme Gamer - Fatal1ty Professional Series (SB046A)
  • SB X-Fi Fatal1ty FPS (SB0466/SB0256)
  • SB X-Fi Platinum (SB0460/SB0251)
  • SB X-Fi Platinum Fatal1ty Champion Series (SB046A/SB0256)
  • SB X-Fi Elite Pro (SB0550/SB0510, SB055A/SB0510) This CD does not support the Sound Blaster X-Fi Xtreme Audio range (SB0790/SB0792).
This Sound Blaster X-Fi Vista Installation CD includes a full suite of drivers and applications:
  • X-Fi Mode Consoles (Gaming/Entertainment/Audio Creation)
  • Creative Mode Switcher
  • Creative Audio Console
  • THX Console
  • Creative MediaSource 5
  • Creative Smart Recorder 2
  • Creative WaveStudio
  • SoundFont Bank Manager
  • Creative 3DMIDI Player
  • Creative Diagnostics
  • Creative Entertainment Center
For more information on how to obtain a copy of Sound Blaster X-Fi Vista Installation CD, please refer to our regional sites at www.europe.creative.com or us.creative.com.
Windows XP applications do not work with Windows Vista. When launched, it will display a message "The audio device supported by this application is not detected. The application will exit" even though your Sound Blaster card is working properly.
If you have installed any Windows XP applications for your Sound Blaster X-Fi card, it is recommended that you uninstall these (Windows XP) applications before installing the Sound Blaster X-Fi Vista Installation CD. To uninstall, go to Control Panel, and select Programs and Features, and then choose the applications that you need to uninstall.
Nov 18, 2007 | Biostar P4TPT - Motherboard
Creative Labs Sound Blaster Live! 24-bit External External Sound System Logo
189 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
