Question about Quasar Televison & Video
Dark picture on quasar sp5133b
Tried ajusting brightness picture color and sharpness
  • 26 Answers
There are two possibilities the first is A bad picture tube which would be too expensive to repair or it could be the capacitor in the 220 volt source which is derived from the flyback transformer most likely it is 10MFD @ 350 WV or close to that
Posted on Nov 27, 2012
techman
  • 3130 Answers
SOURCE: dark picture (HELP)
Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
Posted on Mar 20, 2007
techman
  • 3130 Answers
SOURCE: Dark screen/picture.
This 30" flat screen TV set may have a problem in the high voltage circuit of the TV set. You may be able to adjust this by taking off the back of the TV set. Look for the block where the large red wire runs up to the top of the picture tube. On this block will be two controls. one will say screen and one will say focus. Try and slowly turn the control that says screen or S on it clockwise and see if you can make the picture brighter. Turn up the control till you just start to see faint lines in the picture, then back the control down till the lines go away. If the picture does not come up when you turn this up, and all you get is a blank screen, you will need to have this set repaired by a qualified repair person. Good Luck
Posted on Jul 15, 2007
MikeNJ1964
  • 398 Answers
SOURCE: brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Posted on Aug 21, 2007
  • 74 Answers
SOURCE: tv picture is too dark- worked with contrast and
This sounds like low screen voltage(A1)try adjusting the a1 voltage bottom control on flyback transformer if you have a voltmeter, voltage on crt base possible market screen or A1 shoud be beteen 350/500 volts when making adjustment remember to take into account current taken by meter If voaltage will not adjust flyback transformer will have to replaced
Posted on Mar 06, 2010
Raditronic
  • 196 Answers
SOURCE: Quasar 20yr old color tv sound but no picture, is it repairable
try adjust screen up, in you see horizontal line in bottom, the tv have the vertical ic with cold solder or bad.
Posted on Apr 21, 2010
Color is grate on my Sharp 26" TV. However night scenes have become almost too dark to see. I have tried to adjust the settings but no improvement. Is this a fixable problem? Using Comcast Cable a
Check 'brightness' and 'contrast' settings in (usually) 'picture' menu. Use a recording (DVD etc.) of a dark scene to adjust the picture. My TV (not Sharp) has several pre-programmed picture settings. If yours has that, maybe one of them will be good. Otherwise, use manual settings.
Oct 18, 2014 | Sharp Televison & Video
Dark Picture Quasar QC-33SX51H
try to adjust the brightness and if it wouldint do, replave the CRT socket
Mar 30, 2013 | Quasar SP-3220 32" TV
Can take clear sharp pictures outside, but inside it stays dark . the only way to take movies inside is to put the camera on night shoot, why is there a difference, can I set the camera to the right thing...
If you messed with the sharpness and brightness setings (and saved the setings), the problem might be the sensor that senses the light on your camcoarder, or maibe the rooms you're in are just too dark. If it's not that then see if there are any sensor settings you can ajust. if there aren't then it's ether just geting old or the manufacturer decided on the wrong sensor or the wrong settings for the sensor on the camera.
Sep 06, 2011 | Sony Handycam CCD-TRV68 Camcorder
PICTURE NOT AS BRIGHT AS I WANT HAVE TRIED ALL . TV IS HD REAR PROJECTION . I HAVE TRIED ALL AJUSTMENTS,COLOR,TINT,FORMAT,SHARPNESS, BRIGHTNESS ETC. LAMP ONLY ONE YEAR OLD.
Unfortunately there are 2 IC's and a capacitor that can cause this set to be really dark. Without proper troubleshooting it is impossible to diagnose. Have a shop check it out for you. Thanks
Oct 27, 2009 | Hitachi 50UX58K 50" Rear Projection...
Picture djust
Put it in the custom mode.Put the contrast to the max.Put every things in middles may be colors for less.Now u have the desire ajustment u want?
Aug 19, 2009 | JVC AV-27530 27" TV
Sharp 32sf560 TV
Good day
You an adjust the screen brightness on the rear portion of your units flyback. Then the intensity of the color will change.
chris
Feb 02, 2008 | Sharp 32C241 TV
Picture is mostly red
might try to grayscale but that usually means taking the back off and making the adjustments
Oct 30, 2007 | Quasar SP-3233 TV
Sharp
www.asm-service-manual.com/List/TV%20List%20ASM.htm
Oct 22, 2007 | Sharp 32C-240 32" TV
Picture goes dark
1 your problem is in video section 2 if it is ok then check power supply for any components defective.
Sep 15, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Dark picture
I think you have a regulation problem and all the voltage supplies are lower than what they should be,the fact that the picture gets distorted is one thing it lead me to believe that is the problem.This can be caused by a loose conection in the power supply ,I would suggest not to use it until it gets repaired or it might become worst and more expensive.Be careful if you remove the back and try to repair it yourself.
Oct 02, 2006 | Panasonic PT-61G54 61" Rear Projection...
Televison & Video Logo
Top Quasar Televison & Video Experts
Radames Pagan
Radames Pagan
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
