Question about KitchenAid KBFS25EWMS - Standard-Depth French Door 24.8 cu. ft. 35
Ice buildup on floor of freezer
Ice builds up on floor of freeze. Removed, and within a week it is back. Eventually stops door from closing securely and leaks onto floor. I can find no drain to clear: floor is solid sheet of plastic.
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
Is the fill tube for the ice maker dripping?
Posted on Nov 27, 2012
  • 3 more comments
  • John Aiken Nov 27, 2012
    The ice maker is turned off, and is not leaking.
  • Richard Roth
    Richard Roth Nov 27, 2012
    OK, you have a blocked drain line in the freezer. You will need to remove the contents and the back panel to access it.
  • John Aiken Dec 01, 2012
    I agree it's likely a drain freeze. Unfortunately, access to remove the panel is very restrictive and I have not been able to remove it. Professional appliance coming tomorrow.
  • John Aiken Dec 18, 2012
    It was a frozen drain. Thawed, bt also had to level refrigerator. Service technician said the installer had failed to level it, and that is why water accumulated and froze before draining. Works ok now!
  • Carol46z Oct 23, 2013
    I had same problem with my Kitchenaid Kbfs25ewms. I removed all food and shelves from top and bottom and poured hot water down the left and right drain holes found below the deli drawer, mopping up overflow with towels. After about 18 hours for complete thaw, I tested the drain by pouring a small amount of water in the same drain holes in the refrigerator section....no water overflowed into the bottom of the freezer. I pulled the refrigerator out and removed the back panel to double check the drain pan. It is now collecting the water!
4 Suggested Answers
SOURCE: water leaking inside of refrigerator from freezer
The defrost drain is frozen, you need to take the cover off inside the freezer and there will be a drain hole probably coverd with ice, you will need to pop most of the ice out first then I use a turkey baster and a tub of hot water. Squirt the hot water in the hole over and over again untill it drains. Then just wipe everything down. Problem solved.
Posted on Mar 18, 2008
  • 1073 Answers
SOURCE: ice maker not working
then you either after doing this have a water to the ice maker problem, or an ice maker issue
go to the water valve and disconnect the small plastic line at the water valve and with a cheater cord connect it to the water valve, naturaly remove the factory connector at the water valve first and plug your cheater cord into the ac if you get water out of the valve the valve is good if you do not the valve is bad
if you get water out of the valve then you have a problem in the ice maker IF the line to the ice maker is clear and no obstructions
Posted on Apr 12, 2008
freetek
  • 5568 Answers
SOURCE: Kitchen Aid bottom freezer has frost/ice buildup
Do you know for certain that the automatic defrost cycle is running at all?
Depending on the model, it should be entering the defrost mode every 12 or 24 hours. If the defrost timer is not easy to see (because of the drawer construction), you should be able to catch it by checking the walls of the freezer at random to see if they are still 'ice' cold or more temperate.
You may definitely have a leak, no argument there, but the defrost cycle may have been masking it while it was still happening by sending the ice/water down to the pan.
Posted on Jan 18, 2009
My Whirpool Bottom Freezer Refrigerator keeps collecting ice at the bottom of the freezer and eventually, every couple of weeks, leaks onto the floor. It does have an ice maker which is not hooked up. We...
The defrosting heating element may have burnt out. Also if the gasket around the door/drawer isn't sealing correctly moisture from the air leaking in could be condensing inside and then freezing causing the build up.
Please rate my response.
Jan 14, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer fan is making noise so I took all food out used a hair dryier to try and melt some of the frost/ice behind the back panel. Before this all the food had frost on them. This is the second time I did...
you need to have someone check the defrost circuit. if the unit does not defrost properly , ice will accumulate on the back panel where the evaporator is, blocking the evaporator fans completely, and the circulation fan will eventually stop working because the ice buildup contacts the blades all the fan motor, and eventually the refrigerator compartment will start to get warmer and warmer because there is no circulation of cool air.
Mar 16, 2010 | LG LFX25960ST Stainless Steel French Door...
I have LG French Door Refrigerator Model LFC25760SB. I have the ice build up problem on the floor of the freezer. Is there a way I can only turn off the Freezer so that it can thaw to resolve the problem?...
George,
The short answer to your question is no. It sounds like you are having the same problem I had almost 1 year ago. The defrost controller in your fridge has gone bad. I have an LFC25760 and had ice buildup in the bottom of the freezer such that water would start leaking onto the floor. The ice buildup in the bottom of the freezer was due to a failing/bad defrost controller. Behind the back white wall in the freezer compartment exists the cooling fins along with a heating element underneath. Due to moisture that comes into the freezer from opening it, frost/ice builds up on the cooling fins. Thus the defrost controller turns on the heating element to melt the ice/frost off of the fins which then drips into a metal pan which channels the water to a drain hole which drops into the drip pan underneath the fridge next to the fan. The problem is that the defrost controller doesn't keep the heating element on long enough or the cooling cycle comes on too soon thereby freezing the water and plugging up the drain, which then causes the melted ice on subsequent defrost cycles to overflow the drip pan and flow into the bottom of the freezer and then eventually onto the floor when the bottom is full of ice. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
When I had the problem and started diagnosing it I opened up the freezer, pulled out the racks, draws, and eventually the door. Then I removed the ice maker and then a few screws and carefully removed the back white wall panel disconnecting the fan and any other electrical connections. Behind the panel you will see the cooling coil/fins, the heating element, the drip pan, and drain hole. Most likely you will see a sheet of ice everywhere. The best way to remove the ice is to boil a bunch of water in a tea kettle and slowly pour it on the ice to get it to melt so that you can start breaking out the pieces. Have a sponge and bucket ready to remove the water as the ice starts to melt. Eventually you should get all of the ice removed and get the drain hole unplugged. After all the ice is removed, you still need to fix the real problem by replacing the defrost controller, using the paper clip trick, or both.
Good-luck.
Jun 19, 2009 | LG LRFD25850 French Door Refrigerator
Ice buildup on the coil and ice buildup on freezer floor
you will have to unclogg it..hot water/hairdryer..flexible tubing to push out the clog. the ice on evap coil bothers me though. do all the coils get frosty white(close the door for 10 minutes then check) I fear they aren't and you have a freon leak.
Jun 13, 2009 | Refrigerators
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Freezer super frozen ice build up too quick
before i would replace the freezer i would make sure the drain is open ,,, the drain is at the bottom in the back of the inside of your freezer and if it freezes up the water builds and cut down the cooling ,,, that is where i would look first.
Larry
Nov 23, 2008 | Freezers
Kenmore, bottom freezer, ice bldup in frzr til leaks on floor
The freezer will defrost itself periodically depending on the run times of the compressor. This is determined by the defrost timer and will shut the unit off and turn on a heater to thaw the frost buildup. The resulting water is then channeled to the defrost pan which rests on top of the condensor coil under the freezer section or on top of the compressor, (depending on manufacturer design). The tubing to the defrost pan could be plugged or kinked off. You may also need a modification kit installed to keep the defrost drain trough from freezing over. I would suggest you consult a local technician for advice in this area. Also, make sure all doors are sealing properly as an air leak will cause excessive frost build up and will have a tendency to freeze before it can all drain out, then any successive defrost cycles will overflow the trough and run out the front.
Nov 14, 2008 | Kenmore 63222 / 63224 Bottom Freezer...
Refrigerator condensation
I have a Kenmore Coldspot Model 70262990. When I get wet shelves (water, not just condensation), I was able to trace my source to the cold air vent from the freezer. In my case, the water melts from the evaporator and collects in the rear lower section of the freezer. It is "supposed" to go down the drain tube. However I had the drain hole freeze over. Then additional water from the defrost cycle would accumulate in the freezer floor (under the plastic floor) and eventually find its way down the cold air vent between the freezer and refrigerator section. You'll need to unplug the unit, take the plastic floor out of the freezer, remove the evaporator panel to access the defrost drain, melt the frozen water (hair drier works nice), and remove all the water (towel/sponge & bucket). Make sure the drain is not frozen and not blocked. Then put it back together and plug it in.
Does anyone know how to stop the drain tube from freezing over?
Good luck.
Mar 11, 2008 | Refrigerators
My freezer is buzzing- loudly!
Sounds like ice buildup around the fan that's inside the freezer.  My lousy GE 3-door did that when the bottom freezer didn't get completely closed overnight, and everything behind the back panel, where the coils are froze up like an iceberg.  I had to take the back panel off and melt it with a hair dryer.
See if you see any abnormal ice buildup, or if the refrig compartment is getting warm.  That's usually a result of ice buildup.   Another cause is a failure in the defrost cycle.  It will freeze up after a couple days. This would usually be the defrost timer.
Oct 23, 2007 | Refrigerators
KitchenAid KBFS25EWMS - Standard-Depth French Door 24.8 cu. ft. 35 Logo
684 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
