Question about Contex Scanning Technology Contex Premier Tx Path-Through Scanner
Contex scanner delivers error code 100-50081
If you reset scanner you can start using it for about 40 min
Replace the lamp of 4230i
Nabil, Check the attached links how to replace lamp.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Contex HD5450 User Manual Replacing The Scanner Lamp unit
Contex FLEX50i User Manual Replacing The Scanner Lamp unit
. ContexParts buy parts and accessories for Contex Vidar and Ideal scanners...
Mar 07, 2016 | Contex H42-6799G513 - Hd Ultra 4230
Contex 4230
If you are looking for the drivers, they can be found at http://support.contex.com/Default.aspx?ID=11086
Feb 03, 2014 | Contex H42-6799G513 - Hd Ultra 4230
Contex SD4490 Scanner
Are you looking for a driver for the SD4490?
Sep 25, 2013 | Contex SD4490 Scanner
I have a Contex Chameleon TX 36" scanner that will not power up...no response of any kind when you turn the power on..does anyone have any suggestions other than calling for service? Thanks, Jon
hello jon, well check if you haveany fuse input around and change it if not check the socket where you pluge the printer if it is alright i think you have to call the service.
Mar 17, 2011 | Contex Scanning Technology Contex Premier...
WINDOWS XP DRIVER FOR A CONTEX tx36 SCANNER
I have broken my genius scanner color page vivid 4XE CD driver,how I can down load it on my PC
Jan 05, 2009 | Contex Scanning Technology Contex Premier...
Camera B error for crystal XL 40
You are right, it is very likely!. These type of scanners either use multiple cameras or use multiple mirrors to break a segment into a focussable area and do electronic stitching. (Electronic stitching is another painful area, the scanner has to 'create' a true image removing duplicate pixels). Also with Lens there is focal length aberration. Please note even the brochure carries the statement, "Torsion stabilised" suggesting that it is succeptible for misalignment. The mirrors are kept in position by rubber pads and tiny springs, but rubber pads being sensitive atmospheric variations, there can be focussing issues. Unfortunately you cant even kick the scanner accidentally or on purpose!
S. Mohan
Nov 15, 2008 | Contex Scanning Technology Contex...
Contex copymate g18 ijet reads 'not ready'
These type of scanners use multiple cameras/multiple mirrors to scan a single line. They also perform electronic stitching. If the mirrors are misalighned during transportation, it is a serious problem.Aligning them at the field level is rather difficult.
S. Mohan
Oct 20, 2008 | Contex Scanning Technology Contex...
Hawkeye CX 36 Large ormat Scanner Drivers
Try this link:
http://support.contex.com/software/widesystemTOOLS/#hawkeyecx36
Sep 19, 2008 | Hawking Contex HAWK-EYE Cx Scanner
Contex Scanning Technology Contex Premier Tx Path-Through Scanner Logo
Top Contex Scanning Technology Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Contex Scanning Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
