Question about Ibanez Ael20e AcousticElectric Guitar with Onboard Tuner
Ibanez V72ECE hey i bought new ibanez and the tuner not working, i bought new batteries but still cant run. maybe its some way to activate it or its just bad one? rzepa181@yahoo.com plx helpme
    New Friend:
The V72ECE has to be connected to an amplifier before the build-in tuner works.
Posted on Jun 30, 2014
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
Is the tuner showing power. If so pull out (remove mounting screws) and check 1/8 plug from under the saddle pickup.
Posted on Dec 01, 2012
I plugged in ibanez sdgr 5 string bass into a peavey 300 monitor and now the guitar wont work.. can somebody tell me what happened and how to fix it?
I'm pretty sure that model has active - battery powered - pickups, and yours is flat, so no output at all. The battery would be under the smaller cover plate on the back
http://resources.ibanez.com/resourceservicehost/images/Ibanez/web/insets/zoom/SR300SLB_Battery_Box.jpg
Jul 11, 2016 | Peavey Music
Don't know how to turn on tuner
put a battery in your guitar. It goes in the space at the bottom, usually where you connect your cable to your amp.
Then hold the guitar as you usually would.
Look for a little board with buttons on the side of the guitar to turn on the tuner: )
Mar 27, 2014 | Ibanez Talman Acoustic/Electric Guitar
Hi, I have a problem with my ibanez ew20ase preamp tuner, it was working fine yesterday, now today it doesn't turn on at all, I've tried new batteries but to no avail, also, when I amp it up, preamp works...
I can't seem to find info on this preamp but, that sounds like a power supply problem, considering, the tuner is the part of the circuit that would need power. Volume and tone controls don't, unless they are active,(which I've never seen a reason for). I would try a new battery, because I think you left it on overnight, check the slot for corrosion or a loose wire or connection.
Dec 02, 2013 | Music
Ibanez Srt preamp issue
try opening it up and pinching the two prongs around the patch cord to tighten it up. My bass was cutting out for a while and giving out no sound till i did that
Jul 27, 2013 | Music
I have a Ibanez V Series V70CE. It play well. But sometimes when I connect it to the amplifier, there seems to be loose connection and no sound is heard. When I move the wire little bit sound come...
Many try to use poor quality guitar cables and have the problem. The sleeve of the guitar cable plug turns on the battery in the guitar. Always loop the guitar cable through your belt or the guitar strap to avoid the cable wisting the plug in the guitar causing noise and WEAR that wears the plug sleeve to the point it no longer will activate the guitar.
Sep 18, 2011 | Ibanez V Series V70CE Dreadnought Cutaway...
My ibanez Ael20 works for 2 seconds when plugged in and than stops working. I have replaced the batteries.
Make sure you are using a TS type cable (standard guitar cable, not balanced). Make sure the tuner is off as there are modes for tuning that kill the outgoing audio during tuning.
Jun 23, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
Hi, My Ibanez AEL 20 has a preamp - tuner 5AEQ45F. Tuner works but there is no signal in output jack. Guitar is quite new, and the preamp hasn't been used before. Can I get a PCB schematic diagram...
Remember that while in tuner mode, the audio output is disabled. Try additional presses of the tuner button to see if the audio comes back on. Also verify the volume and EQ gains are turned up. Verify the battery is new.
May 30, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
Hello, I have found that Ibanez AEL20 guitars' 5AEQ45F (SRTn) preamp-tuner has a 6V voltage, my AEL20 guitar came with 1,5 V batteries (3V in total). There is no internet source to get the...
There is little data on the internet about this... However my AEL20E uses 2 AA cells. Some older ones may have used a 9 volt battery. Yours should use the 2 AA cells which go into the box right by the XLR output plug.
Feb 16, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
Ibanez intonation problem
Hi there. Use guitar tuner. Pluck string in open position. Tune. Now pluck same string at 12th fret. If tuner says flat, adjust bridge for that string towards neck. Towards bridge if sharp. Repeat procedure until in tune at open and 12th fret. Go to next string and repeat procedure.
Thanks
Paul
May 11, 2009 | Music
Ibanez Ael20e AcousticElectric Guitar with Onboard Tuner Logo
388 people viewed this question
Top Ibanez Music Experts
Michial Gueffroy
Wayne Tolonen
Are you an Ibanez Music Expert? Answer questions, earn points and help others
