Question about Prima CV2011 TV
I hooked up my tv and I only get sound on the dvd not when I am watching just the tv
I get sound when I am using the dvd but no sound when I want regular tv
    Sergeant:
  • 204 Answers
This makes me believe you have either a bad connection with your coaxial cable to the tuner or the tuner may need serviced.
Posted on Nov 27, 2012
I have comcast cable serice. Do I have to hook up my dvd/vhs recorder to comcast box or just to my tv?
Your tv. You will use your tv "source" to select which input to watch from. Everything goes to the TV. I have a surround sound amp that I run the sound FROM the TV that way if I want it loud I turn that on. It is the only exception.
Dec 29, 2014 | Televison & Video
Surround sound for DVDs.
If your DVD disc supports it, you will have to enable surround sound from the DVD, as well as the speakers.
May 10, 2008 | Koss KS3102 System
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
I have no sound while watching tv. It is hooked up to a satellite system and the other tv/satellite systems are working fine. I have sound while I watch a dvd but nothing while watching tv. Its like the...
I suggest you check the satellite receiver first, you can use the component or HDMI cable for the satellite receiver to check it. If still no sound, the TV main board is defective.
May 13, 2010 | Panasonic TH42PX7 42 in. Plasma TV
Can i connect a coby 5.1 dvd home theater system to a 32 inch vizio and be able to watch tv with the surround sound on. I know the surround sound can play while im watchin a dvd but i would rather just...
you need a logitech sound adapter or game adapter that costs 4-10$ on ebay.
Connect LR channels using an RCA cable and hook up the speakers on the other end of the game adapter
Jan 10, 2010 | Vizio VW32L 32 in. LCD HDTV
No sound
More than likely you need to go into your menu settings. Check to ensure that your TV speakers are enabled. The previous owners may had it hooked to theater system
Oct 20, 2009 | Toshiba TP50G60 50" Rear Projection...
Sound issue
try hooking the system up so that it uses a different channel when in use.
Jan 29, 2009 | Panasonic DMR-ES10 DVD Recorder
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
How to set the telelvision to use a dvd,
On the remote ther is a tv/av button. Turn the DVD on and press play and the press that buttom on the tv remote and you will see your dvd playing. Have a good day.
Aug 04, 2008 | Philips Magnavox 27MS343S 27" TV
Prima CV2011 TV Logo
Top Prima Televison & Video Experts
romy sibug
romy sibug
Jerry Greenberg
Jerry Greenberg
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
