Question about GE Profile PFCS1NJWSS Stainless Steel French Door Refrigerator
Control panel does not work
Refrigerator and freezer work fine. Control panel, ice maker and water dispenser do not work.
    Top Expert:
  • GE Master
  • 9,472 Answers
You will need to replace the display. Here is the part to order.The dispenser panel unsnaps from the door of the unit.
Posted on Nov 27, 2012
Master_Tech
  • 770 Answers
SOURCE: hotpoint refrigerator water dispenser not working, while ice maker, works slower
Check or replace the water filter
Posted on Jan 26, 2008
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
SOURCE: ice/water dispenser control panel
@ Scootertramp
You tell us about this board or that board but never tell us where to located or get at these boards. Would you please clarify that?
My ice and water started dispensing sporadically, though the lights were working fine. After I removed the kick board at the bottom, cleaned out the little connector and put it back together, nothing on the door works. All else works fine.
Posted on Sep 08, 2008
wheelshot
  • 102 Answers
SOURCE: water dispenser doesn't work on ge hotpoint freezer
Here recently I have run into 2 of these units that do this and have found that the dispenser line is frozen in the freezer door. The way to test this is to remove the kick plate under the doors (It is easiest to open both doors to do this) Disconnect the union in the water line leading to the door by pushing in on the waterline and pulling in on the end of the fitting. When the line is apart, close the doors and push in on the paddle as to fill a cup with water. If you get water out of the line under the door then your line in your door is frozen and you will either need to replace your door or let the unit thaw for 24 hours with the doors open. Cheaper to thaw. If no water comes out under the door when paddle is pressed then you will need to replace the water valve as long as you have 120 volts at the valve when actuated.
Posted on Apr 11, 2009
  • 94 Answers
SOURCE: My ice maker on my GE pfs22miwcbb bottom freezer
It's not uncommon for these to outright fail considering their harsh operating environment. However, I have seen issues with automatic ice makers where the eventual buildup of frost can jam the motor or gears. It may simply be stuck. If the device that ejects the ice cubes becomes jamed for any reason, it obviously will not fill with new water. I think your best bet at this point would be to defrost the freezer and see if that works. If not, then try removing the covers from the ice maker to see if there are any obvious signs of breakage.
Posted on Jul 06, 2009
GE Profile PFSS6PKWBSS control panel display does not light up
more than likely the mainboard in the rear of the unit is defective,as the dispenser board gets its power from the mainboard and the dispenser bpoards normally dont go bad
Feb 01, 2013 | Refrigerators
Turn on water light on outside of door
Can be faulty control panel causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Maytag Refrigerators
Control panel
Its faulty control panel, needs to be replaced.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | GE Profile Pfsf6pkw 25.8 Cu. Ft....
Cannot adjust contol to freezer and no sound to the compreeor
May be faulty compressor or issue with compressor control capacitor.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Zanussi Z57 / 3 Bottom Freezer...
Blank screen on gr l 247ni refrigator how to repair
Faulty control panel.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Ice maker stopped working
if the water dispenses from the water dispenser I would say its the. Ice maker control module...try here
www.techray1.com and the link is on the guru guy on the left
Jun 15, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE GSS25SGRE side by side water dispenser...
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
GE Profile PFCS1NJWSS Stainless Steel French Door Refrigerator Logo
514 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
