Question about GE J Series 18.2 cu. ft. Top Freezer No-Frost Refrigerator TBX18AABWW
I need to disconnect my ice maker from my GE TBX18DI refridgerator has anyone done this?
    Top Expert:
  • GE Master
  • 9,472 Answers
You should be able to reach behind the ice maker and unplug it from the wall.
Posted on Nov 27, 2012
SOURCE: GE top freezer ice maker leak
I have the same problem -
Posted on Aug 11, 2008
jcpark50
  • 52 Answers
SOURCE: GE Profile TFX27PF/TFT27PF Refridgerator
There is a line from the defroster catch pan, up under the freezer, to an evaporation pan, down under the bottom. If it becomes clogged with dirt, bugs, whatever, the catch pan will overflow, and leave a puddle on the floor. Find it and unclog it.
Posted on Nov 07, 2008
tborn6
  • 700 Answers
SOURCE: Ice will not come out of the door. The auger is not turning
take the ice bin completely out and run water in it until all the ice is clear from the auger
Posted on Mar 29, 2009
Healeyman
  • 1198 Answers
SOURCE: Ice maker out, I need a wiring diagram. GE model
I hope you are an electronics major. The ice maker uses the most complicated and heinous electrical theory available. What usuall goes wrong are those hairline contact arms they use. They have assembly tricks only surpassed by the inscrutible oriental puzzle boxes.
For about $150 you can get another.
Posted on Apr 25, 2009
  • 358 Answers
SOURCE: the ice maker on our GE refrigerator does not make ice
1 -Ice maker arm must be down(on position)2-Make sure the water supply line is connected to the fridge3Check if the ice maker is plugged in4The freezer must be working fine for the ice maker to produce ice. After the ice maker stars and calls for water and doesn't get any , the water valve is bad.And if everything above is ok the ice maker needs to be replaced.
Posted on Apr 26, 2009
Ge refridgerator model gh405499
From what I know of ge, ice makers are independent. Mother board has no control over I'm. How old is this fridge. Some of the newer ge are made by Samsung and are control.
Nov 03, 2012 | Refrigerators
How to remove samsung imc701 icemaker from refridgerator
Take out the ice bin, remove the side panel with a screwdriver, press down the lever on the front middle top of ice maker and slide out the icemaker, unplug the wiring on the side, you're done.
Jul 26, 2011 | GE Profile Energy Star? PFSS6SMXSS...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ice maker on the freezer side door stopped working so I changed out the motherboard CCA in the back of the refridgerator & it started working again but the water did not. I need to replace the...
Blake are you talking about the dispenser control board? The ice maker tells the water control valve to come on for the preset amout of time to refill the ice trays most times about 7.5 seconds. and filling ice maker with tap water will test icemaker. If water freezes and the ice dumps the signal is sent to the water control valve Click here=> WR57X10050 here is a service manual=> PROFILE ARTICA SERVICE MANUAL CLICK HERE Have questions you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker makes ice really slowly
perhaps there is not enough water being brought to the ice maker from the inlet valve. you may have to change the valve.
Oct 24, 2009 | GE GTS22 21.8 Cu. Ft. Top-Freezer...
I would like to remove the ice maker from my freezer.
REMOVE THE 2 MOUNTING SCREWS ABOVE THE ICE MAKE,REMOVE THE 1 SCREW UNDER THE ICE MAKER,DISCONNECT THE ICEMAKER JACK AND YOUR DONE,YOU NEED DO NOTHING ELSE,HOPE THIS HELPS,THANKS-MIKE
May 31, 2008 | GE Hotpoint Top-Freezer Refrigerator
Ice Maker Isn't working
water to the foutain is not the same water to the ice maker . ck the dual water valve ..
Mar 25, 2008 | GE PFSS6PKSS
GE Side by Side Not Cooling
Hi , the refrigerator having problem with enfeller fan stuck it needed to defrost manually to drain all ice buildup inlet of refridgerator hole after 3 hour try start refrigerator.
Feb 05, 2008 | GE GSS25JEMWW Side by Side
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
