Is it possible to install this printer on an windows 8 based pc?
SOURCE: infoprint 1412 on windows vista
I have the same problem with my 1412, if you find a driver please emial me.
SOURCE: IBM infoprint 1222 all lights flashing
Go to this site
http://www.lenovo.com/contact/us/en/
and on the right cklick on downloads and follow the instructions and you will bw able to get the driver. Be sure to select the Windows XP or what you have.
Then if you are able to get the drivers,
Normal 0
Disconnect the printer or at least be sure it is turned off. I'd do both and install the downloaded software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: IBM Infoprint 1532
There is probably a small piece of paper in the back of the printer in the fuser. Shutdown the printer and wait a few minutes as this part is hot. You may need to remove a few screws to take off the back cover and check inside the fuser.
SOURCE: WHERE DO I GET THE DRIVERS FOR THE IBM Infoprint
Access this website and you will find a free download link at the bottome of the page for the drivers. http://www.softwaredriverdownload.com/ibm_infoprint_12_driver.html
Testimonial: "Found the drivers. Thanks for everything."
