Question about Generac 6051 Guardian Series Air-Cooled 10kW 120/240V Single Phase Steel Residential Generator with Nexus Smart Switch
Generac model 60511 10kw, 240VAC is ok, but 210VAC-gnd and 80VAC-gnd?
I just got the generator installed and when performing voltage checks I discovered there are 240VAC on the phase OK, but when I checked each leg to neutral/ground, I found fluctuating voltages. On one leg, the average was 208VAC, on the other the average was 84VAC. All of these voltages were read under no load conditions. I am reluctant to load the generator until I can verify these are not dangerous conditions. Thanx for any help.
CarlGehrke
  • 169 Answers
SOURCE: Generac Guardian 15kW Generator
That sounds just about right, if the relay contacts get welded together it sometimes takes out the driver on the printed circuit board. As you found out, 12vdc from 23 to 194 makes the transfer switch move to the Generator position, relay not energized makes the ATS move to the Normal position.
You can make a nice test function by installing a 10 amp contact switch in series with either the N1 or N2 terminals. When the switch is open the generator thinks the Normal power has failed.
Regards,
Carl
Posted on Jan 26, 2009
mamicheddy
  • 79 Answers
SOURCE: generac model # 09734-1 no voltage output. would like a manual
Flash the fields. Remove front cover from the generator end. You will see the brushes and rings on the rotor. The ring closest to you is positive and the ring closest to the rotor windings is negative. With a 12 volt batttery and the generator running, place the positive side of the battery to the ring towards you and negative to the back ring. Make sure to use jumpers and keep fingers away from rotating parts and don't get zapped. You should see output voltage increase. If it does, your voltage regulator is bad, if it doesn't your generator end is bad.
Posted on May 07, 2009
  • 384 Answers
SOURCE: 10kw Generac Guardian not cranking, shows rpm sense loss
Sounds like Generator mode switch should be "ON".
Posted on Sep 08, 2009
  • 905 Answers
SOURCE: Generator was running and quit delivering voltage
It very well may have been a breaker that opened up permanently.
But, I bet that the generator was under heavy load for prolonged time, and one / both of the diodes in voltage regulator have opened up. You will have to disassemble the end housing of the alternator to get to these, and then test with multimeter to know for sure.
Of course, your generator may have an electronic controller, and not use diodes / capacitor at all. Since don't have model #, can't be sure.
If engine has dropped much under 1800 (4 pole alternator) or 3600 (2 pole alternator) RPMs, then alternator output would tank or be nonexistent.
Posted on Jan 04, 2010
wentlanv
  • 710 Answers
SOURCE: Just returned from a trip
Hi Scott,
Since the generator starts but there is no power to the control board, there is an electrical problem inside the generator.
First check the circuit breaker at the back of your generator. If the breaker is on, then your generator is in serious trouble.
Call a repairman, but also keep in mind you may need a new generator.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 07, 2011
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    Which would be generic voltage regulator compatible with the generator?
    I need to know the open circuit voltage of the generator, whether DC or AC and then what voltage and current you wish to obtain and regulate to. Thanks
    Feb 16, 2018 | Generac Electrical Supplies
    I have a generac mc alternator model -38 6938 my voltage pulsates underamload just started any ideas
    Cleaned and adjust carburetor per Repair Manual. then adjust governor repair manual and should take care of problem on this old generator.
    https://www.generator-parts.com/manuals/generac-rv/051834.pdf
    Jan 07, 2015 | Generac Electrical Supplies
    Generac troubleshooting
    Check that there is not a switch to activate the panel. Next, there is a fuse for the outlet panel as well or a circuit breaker. Check that. If all of that is good you will have to put a meter on all of the wiring points from beginning to end and find out where the voltage stops. Then you have found the component that went bad.
    Jul 16, 2014 | Generac Generator. GP5500-Watt Portable...
    My generac generator is producing low voltage
    check voltage input at voltage regulator, then check output from
    the regulator.
    Nov 07, 2013 | Generac 5622 GP Series GP5000 6,250 Watt...
    Generac 40kw single phase generator starter engages after 30sec of running
    For the over voltage there is an adjustment on the control board.
    Should be tested with a load something plugged in.
    The hertz might just come on when under load and adjusted too.
    If you need more give a model number and whether it is 13kw or 40kw.
    May 05, 2013 | Generac 13,000 Watt / 13,000 Watt Home...
    New Generac Generator--Battery Goes Dead
    Yes,if its working correctly,you should be getting a reading about 2.5 to 3 volts above the battery voltage rating while its in standby mode.
    Jan 17, 2010 | Kitchen Appliances - Others
    How can the battery charger be changed?
    Yes this is a very simple job to do. there are only 2 small bolts holding it in. Make sure the generator is in the off position and removed the 2- 5amp fuses in the transfer switch for N1 and N2 Use a fuse puller designed for this (you can get at home depot or lowes for around $9-$10) not a pair of pliers or screwdriver, etc... there is 240VAC on these fuses.. N1 and N2 are what ultimately feed the transformer in the generator which steps the voltage down to 24-26 VAC and feeds the battery charger. Other than that its fairly simple, let me know if you have any more questions.
    Nov 26, 2009 | Generac Guardian 0A18010 - battery...
    Guardian generac 10kw model 5502 does not output correct voltage
    the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
    Apr 12, 2009 | Guardian Electrical Supplies
    Generac 6051 Guardian Series Air-Cooled 10kW 120/240V Single Phase Steel Residential Generator with Nexus Smart Switch Logo
    97 people viewed this question
    Top Generac Electrical Supplies Experts
    Craig Butler
    Craig Butler
    dennys23601
    Don  Farrell
    Don Farrell
    Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
