Question about Acer AL1717 17" LCD Monitor
Screen problem i have an emotions lines on my monitor how can i fix it
    Problem Solver:
  • 6 Answers
On the power supply PCB there are two 220uf 25V capacitors, replace them and it the screen will be clear again. Normally you can straight away see that these two capacitors are leaking.
Posted on Oct 28, 2009
    Sergeant:
  • 431 Answers
Check the signal cables
Posted on Jan 10, 2009
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computers & Internet
Thin black horizontal lines across bottom of screen
Hi there.
I suggest you see my tip on how to fix the lines on your monitor. The fix for horizontal lines is the same for vertical lines. You can read my tip here: http://www.fixya.com/support/r9352105-fix_colored_vertical_lines_lcd_display
Slasher_X
Jul 20, 2011 | HP w17e Monitor
I have an older agneovo f419, she now has coloured lines running vertically up the screen, the longer the screen is on the more lines that come along for the ride. Can I fix the thing 19" are still a bit...
Hi Daz, try another working monitor on your computer and if the lines still appear on another monitor then that means your video card or onboard video is bad.
If you use another working monitor and the lines don't appear then that means that the original monitor has a bad screen and would not be worth the $$$ to repair.
Jan 06, 2010 | Neovo F-419 19" LCD Monitor
Fluctution in samsung monitor
I'm going to take a shot in the dark here and say that by fluctuating you mean it's flashing and whatnot. This can be caused by the lamp dying.
As for the lines on the screen, those are probably dead pixels, which can happen to monitors.
Unfortunately, it isn't exactly cheap to fix a monitor, and you might be better off buying one.
To be on the safe side, try taking it somewhere like Best Buy to confirm what I've said.
Hope this helped :)
Nov 28, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
Line on the Screen
Check for monitor self test feature on your monitor .If problem presist need to replace monitor.
Aug 17, 2009 | Sony SDM-HS73P 17" LCD Monitor
Vertical lines on screen , is there a processor driver download to fix this problem
Vertical lines on a screen is not a processor problem, vertical lines is going to be a problem with the monitor or the video card. Try a different known working monitor on your computer and if the lines go away then you know that the original monitor is bad.
If the lines don't go away then try replacing the video card. If you have integrated video then the motherboard would need to be replaced. A processor driver download is not going to fix a vertical line problem.
Aug 08, 2009 | Dell Computers & Internet
Green vertical line on LCD screen
Is this on a monitor or on a laptop LCD display?
Most of the time it is due to a hardware issue like a video card or the screen itself.
When does the line appear?
A. Is it there even with the monitor or laptop turned off?
B. Is it there during the OS logo / boot screen or does it appear after the OS loads?
C. If it is a monitor, with your system turned off go into the menu of the monitor by using the buttons on the front. Is the line there?
What you can do to try and fix it is.
1. Make sure you have all the latest drivers for your video card.
2. Change the resolution of the screen.
3. Change the frequency of the monitor.
If these do not fix your issue you may want to look at getting or borrowing a video card and replacing it if this system is a desktop. If this system is a laptop and the above does not fix the issue your best bet would be to put up with it or buy a new laptop to be honest.
Jun 19, 2009 | Acer 22" X223w LCD Monitor
Laptop screen blurred, doted lines
HOW TO SOLVE THE PROBLEM OF LAPTOP SCREEN IS BLURD?
Dec 28, 2008 | Computers & Internet
EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Aug 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
On the monitor, only one straight horizontal line display on screen. How to fix it?
Sounds like it's not scanning vertically, probably not worth the money to have a monitor fixed. Time to get an LCD. :-)
Jan 11, 2008 | HP D2835 17 in. CRT Monitor
Acer AL1717 17" LCD Monitor Logo
202 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
