How to connect nikai lcd to laptop
Want to watch videos by connecting my laptop to my LCD
  • 50 Answers
SOURCE: Using LCD as HP laptop monitor
there is a key on your laptop keyboard that will allow you to switch from built in to external monitor. you need to hit the function key and this one at the same time, this will fix that for you.
(I don't remember which key it is, but it's at near the top left.)
Posted on Nov 18, 2007
  • 43 Answers
SOURCE: Connect LG 42LY95 LCD to Toshiba Laptop
Hiran
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Scott
Posted on Mar 23, 2008
SOURCE: HOW TO CONNECT SAMSUNG LCD TV TO ACER ASPIRE
Atlast I got some help from the right people (Samsung)! I would like to share it with others facing the same problem:
If you are using the D-sub 15 pin jack (VGA Monitor Cable: make sure its 15 pin and NOT 14 pins), follow these steps:
  1. Make sure your TV and computer are off.
  2. Using a 15 pin D-sub (standard) video cable, connect the Video Out jack on your computer's video card to the PC In jack on the back of your TV.
  3. Using an audio cable with a min-stereo plug on one end and two RCA jacks on the other, connect the Audio Out jack on your computer to the left and right PC Audio In jacks on your TV. (Note: If you have your computer connected to separate speakers, you can skip this step)
  4. Switch on the Notebook and Adjust the Resolution (800 x 600 pixels would do). You can go to Control Panel and Adjust the screen resolution. (Keep ‘Screen Refresh rate’ at 60hz in the Monitor Settings)
  5. Switch on the TV and try to Select the Source as 'PC' (you can do this by either pressing the 'Source' button several times on your TV remote or go to the Menu - Setup and Select the 'PC' as source there).
  6. In most cases, after following the above steps, the TV would start to show 'Auto Adjusting' message and it will start showing your Desk top on the TV. But incase it doesn't work, you can do the following:
a. Mostly the problem lies with the VGA cable. Make sure you have the right one (15 pin) and its securely attached at both ends. If you are not using the right VGA Cable, it means that there is no connection between your TV and Notebook. Your TV will show 'PC' in Grey in the Source Input list (Go to ‘Menu’ from the TV remote).
b. Both your Notebook and TV should be switched off when you are connecting the cable otherwise one of them might have a problem detecting the other one.
c. Try Pressing Fn + F5, F6, F7 (depends on which Notebook brand you are using) on your Notebook several times. At times, you will see some signs that the Notebook and TV are trying to connect. Select 'CRT' from list of displays available to you.
Posted on Jul 23, 2008
tray06606
  • 59 Answers
hi if you laptop has the s-video you can connect that to the tv an it would work
Posted on Jan 10, 2009
  • 48 Answers
SOURCE: I want to connect my Toshiba Satellite A305-S6863 Laptop to TV
You have to configure yout laptop to output through the s-video (which does not carry sound, so you need to either use the laptop speakers for sound, or the line output (headphone jack) to the TV).
I don't know if all toshibas are the same, but with mine, if I hold Fn (near the windows key) and press F5, it will change the output, do it a few times until you see a picture on the TV, some settings make this your extended desktop, meaning you can drag a window from one screen to another.
Posted on Apr 28, 2009
Testimonial: "Very helpful and well stated information! Thank you."
How to connect an lcd connector on an lcd for an asus u47?
Watch this YouTube video which explains how to replace the screen.
Oct 17, 2014 | ASUS Computers & Internet
My LCD monitor is white when i work?
I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It's possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you'll have to take apart the display panel because the connector is located on the back side of the LCD screen
Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard
The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video.
Hope it helps, else you will have to send the system for servicing to the manufacturer
Regards
Jan 27, 2011 | Acer Aspire 4315 Notebook
I forget my security code of nikai tv
i want service code for nikai tv
May 16, 2010 | Televison & Video
When I turn on the computer the screen is white but the computer is booting up.
Laptop LCD screen turned completely white
What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following:
When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning.
It’s possible that you have to use a different key combination on your laptop but you get the idea.
I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you’ll have to take apart the display panel because the connector is located on the back side of the LCD screen.
I always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn’t help, most likely you have a problem either with the LCD screen or with the motherboard.
The best way to find out which one is causing the problem is testing the laptop with another working LCD screen. Without this test you’ll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You’ll have to disconnect the video cable from the LCD screen and the inverter board. After that you connect another working screen and test video.
The original screen is white but my test screen works normal and I can see the image. After this test I can tell that the problem must be related to the screen.
After I assembled everything back together and connected the original LCD, it’s still white.
CONCLUSION.
In my case this problem is related to the LCD screen and it has to be replaced.
Jan 14, 2010 | Dell Studio 17 Laptop
HDMI LCD
HDMI is a great idea but has its limits try loading the newest video driver for your laptop from the actual vga card manufacture website not DEll but ATI or Nvidia whichever one came onboard that pc.
Dec 30, 2009 | Dell Inspiron Mini 10 Notebook
I just replaced the LCD screen in my laptop and when I turn it on i get Half the screen blue and half black. I can't watch the machine boot. I was careful with all of the components and cables during the...
reseat lcd cable and lcd inverter. if fails try connecting laptop to external monitor then check if problem still there then replace video card or the motherboard (if video is on-board)
if no problem from the external monitor then replace lcd panel and lcd cable / inverter.
Dec 04, 2009 | Dell Computers & Internet
Connect lcd LE10 32'' model to laptop
connect them via HDMI. Audio and video from your laptop will go the TV. You need an HDMI cable for that connection.
cheers!
Jul 11, 2009 | Panasonic Viera TC-32LZ800 32 in. LCD HDTV
I tried connecting my laptop with the lcd bravio ,i wanted 2 watch a movie on the lcd but couldnt .. ther is no prob with the connection ...i could get the display but couldnt hear anything ..
The audio connection is separate from the video connection.
You need a cable that has a headphone jack at one end and two RCA connectors (the red and the white) at the other end. Connect the audio into the same channel you are using for the video. This would get connected to the headphone jack on the laptop.
Apr 15, 2009 | Televison & Video
Getting audio from a Dell LCD Monitor when connected to a Laptop
connect the audio cable to laptop and LCD monitor...
.35mm male to male jack
connect the cable to your laptops headphone jack and the other end of cable to the monitor
the VGA and DVI cable are for video only
Apr 02, 2009 | Computers & Internet
BLANK LCD
I just had the same thing happen. When i close and open the LCD Panel, the screen will com on for a fraction of a second. can see momentray.
How do i open up this thing and check the lcd connection to the board?
Mar 30, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
